Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 05-14-2010, 08:55 AM   #1
tramix
Member Sales Rating: (4)
Member#: 148317
1998 Subaru Impreza
Brilliant Red
Default FS: (NJ) 06 STi 6speed swap
Comes with
06 STI 6speed with shifter assembly ~30kmiles
WRX rear diff with proper plate to accept STI driveshaft
STI driveshaft
If you have any questions feel free to ask
-vince
tramix is offline   Reply With Quote
Old 05-14-2010, 08:55 PM   #3
wrxmase
Member Sales Rating: (15)
Member#: 118179
97l cpe&sdn10LGTab
03sti yella 11 2.5i dgm
also where in jersey and did you have this in your car
wrxmase is offline   Reply With Quote
Old 05-15-2010, 01:09 AM   #4
bugeye1257
Member Sales Rating: (8)
Member#: 188598
soo tempted right now! can you get pics of the trans?
bugeye1257 is offline   Reply With Quote
Old 05-15-2010, 01:16 PM   #5
tramix
Member#: 148317
1998 Subaru Impreza
Brilliant Red
the setup is still in the car. The plate is from an R180...removed and installed onto the r160 for a factory bolt-on solution. I will include the slave and shift fork
car isnt running anymore. Had the setup for about 2 months
Old 05-16-2010, 02:35 AM   #6
wrxmase
Member#: 118179
97l cpe&sdn10LGTab
but it is all in perfect working condition
Old 05-16-2010, 02:36 AM   #7
wrxmase
Member#: 118179
97l cpe&sdn10LGTab
where in nj are you
Old 05-16-2010, 07:07 AM   #8
RedRex26
Member#: 133418
2006 DOM3 XTR WRX TR
SRR 407whp 365wtq ppg'd
what else would be needed for this to bolt up to an 06 wrx
RedRex26 is offline   Reply With Quote
Old 05-16-2010, 10:21 AM   #9
IIdiceII
Member Sales Rating: (88)
Member#: 90438
how did this work? the sti tranny and wrx rear have different final drives correct?
IIdiceII is offline   Reply With Quote
Old 05-16-2010, 03:35 PM   #10
Jubert69
Member Sales Rating: (23)
Member#: 167739
04 WRX
ej207 spec C 18g
Rear diff.
If you have an 02-05 WRX, they will be the same. With this setup, IIRC you won't be needing anything else, although I would advise upgrading to the STi Clutch setup. You can reuse your clutch slave cylinder and front axles if they are male.
Jubert69 is offline   Reply With Quote
Old 05-17-2010, 08:53 AM   #11
tramix
Member#: 148317
1998 Subaru Impreza
Brilliant Red
The setup works.
Also you can have either style axles as I have gone through the trouble of installing axle stubs for female axles. If you have males, just remove the axle stub.
The setup comes with a rear diff so anyone without a 02-05 wrx can use this setup.
Old 05-17-2010, 09:40 AM   #12
RedRex26
Member#: 133418
damn if this is available by my next paycheck i'll take it. which rear diff would i need to buy to throw this on my 06
Old 05-17-2010, 11:25 AM   #13
tramix
Member#: 148317
1998 Subaru Impreza
Brilliant Red
lol...are you reading at all. It comes with the rear diff to install and use.
Old 05-17-2010, 12:48 PM   #14
wrxmase
Member#: 118179
97l cpe&sdn10LGTab
Where in jersey are you
Old 05-17-2010, 10:13 PM   #15
RedRex26
Member#: 133418
haha epic fail sorry bout that its been a long day.
Old 05-18-2010, 12:51 AM   #16
wrxmase
Member#: 118179
97l cpe&sdn10LGTab
why was this taken out of car
Old 05-18-2010, 12:52 AM   #17
tramix
Member#: 148317
1998 Subaru Impreza
Brilliant Red
pending sale
Old 06-03-2010, 08:46 AM   #18
tramix
Member#: 148317
1998 Subaru Impreza
Brilliant Red
SOLD!!! Thanks for playing
FS: (NJ) 06 STI 6speed swap tramix Drivetrain 24 06-02-2010 11:54 AM
You got the "200" STI 6speed swap lists now, how do you install? wrx03.4wz Transmission (AT/MT) & Driveline 9 07-16-2009 11:32 AM
08 sti 6speed swap DausWRX Transmission (AT/MT) & Driveline 14 05-10-2009 11:55 AM
Dowel Pins? STI 6speed swap. AWNOPEEL Transmission (AT/MT) & Driveline 3 05-18-2008 03:18 PM
