Old 05-14-2010, 10:06 PM   #1
last lemming alive
Member#: 139465
2011 STi Limited
Satin White Pearl
Default Need advice on weather or not to install my Whiteline sway bar or wait.
Ok, Im in on the group buy for the Bilstein struts and Yellow springs from GTWorx and according to the 'worx a 22mm front and 22mm rear bar set up should work great. So I ordered Whiteline 22/22 adjustables. Today I received the 22 rear but the 22 front is on backorder. My question is will I upset the cars handling too much if I just put the back on now and set it to the softest setting. Im itching to find out. As I recall the OEM bar is a 16mm on 2009 WRX's and a 22mm is a big jump from 16mm.
And along the same line of questioning, if you have a Whiteline 22mm adjustable swaybar is the softest setting equivalent to a 22mm non-adjustable or is it the medium or hard setting?
I seem to recal a Whiteline (or maybe it was another manuf.) chart of % increases for various bar sizes. Does anyone else recall thisa and know where to find it?
last lemming alive is offline   Reply With Quote
Old 05-15-2010, 01:08 AM   #2
teiva-boy
Member#: 22825
Go ahead and put it on, play with the different settings, from soft to firm, nothing can go wrong except an over zealous driver.
teiva-boy is offline   Reply With Quote
Old 05-15-2010, 04:40 AM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
put it on.
the fewer thing you change at once, the more you learn about car setup.
jamal is offline   Reply With Quote
Old 05-15-2010, 06:46 AM   #4
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Put it on for sure.
JDwhiteWRX is offline   Reply With Quote
Old 05-15-2010, 08:43 AM   #5
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
you can put it on but get a feel for it before you drive the car hard becausethe car is going to be a lot more prone to oversteer
jdmboy is offline   Reply With Quote
Old 05-15-2010, 09:13 AM   #6
last lemming alive
Member#: 139465
2011 STi Limited
Satin White Pearl
well I guess I'll put it on now and see how it goes!
GM BCS: To install or not to install? Blown95ImpalaSS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-04-2006 07:04 PM
Need to sell my front sway bar trevman2 Alaskan Impreza Club Forum -- AKIC 1 07-11-2005 11:32 PM
To install or not to install? Mikeyrad Brakes, Steering & Suspension 16 06-28-2004 07:32 AM
Where to buy a Whiteline sway bar? GUS WRX Brakes, Steering & Suspension 2 03-02-2003 01:25 PM
Problems with my Whiteline sway bar Zephyr Brakes, Steering & Suspension 7 06-21-2001 03:37 AM
