Closed Thread
Old 05-15-2010, 10:50 PM   #1
midwestmonster
Member#: 54390
2016 Sti w/nav
CWP
Default Locks, Radio, Dome Lights not working after stereo install
Please help. Hope I just blew a fuse....but after installling Kenwood radio, I must of did something wrong, because now Dome lights, radio, and power locks from key fab don't work.... I read somewhere it might be a big ACC fuse under the hood. Any ideas?
I already checked the fuses inside and were all good. Thanks.
midwestmonster is offline
Old 05-16-2010, 12:52 AM   #2
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Fuse #8 (20 Amps, in the panel under the hood) provides power for the +12 V Battery/Constant (memory) wire -- Yellow wire on aftermarket harnesses.
That fuse also powers:
  • Clock
  • Keyless Entry Control Module
  • Body Integrated Unit
  • Brake lights
  • Interior lights -- dome, spot map, and trunk
(and probably a couple of other things)
Basically, these are things that need power even when the ignition key is off. Some of those circuits have additional fuses after the main 20A fuse.
SVXdc is offline
Old 05-16-2010, 01:01 AM   #3
midwestmonster
Member#: 54390
2016 Sti w/nav
CWP
Thanks man! 20A under the hood fixed it labeled "backup". Very odd, but it is what it is. LOL. I also found this link.
http://www.wrxtuners.com/forums/f72/...use-fyi-28179/
Thanks again man!
Old 12-30-2014, 02:07 AM   #4
KreparAZ
Member#: 326853
2012 WRX
Satin White Pearl
Default wooohooo
just saw this post now. after hours and hours of looking. googling. testing fuses and learning to use a multimeter. seriously almost my entire day.had a battery fail too during all this and boy am i proud i finally stumbled upon this. thank you SVXdc! i dont know why i didnt think to email you or message you. i got my stereo harnesses from you. i blew this fuse adding additional lighting to my hatch since my light is covered by my sub.
  • Clock
  • Brake lights
KreparAZ is offline
Closed Thread
Interior dome light not working BOOST3DWRX Electrical & Lighting 1 08-06-2007 08:11 PM
radio lights not working...after gauge install WRXEcho Electrical & Lighting 0 09-26-2006 05:50 PM
Shift light/beep not working after TT install polyamorous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-26-2006 01:11 PM
Radio and clock not working after cluster install jdm_wrx Electrical & Lighting 1 12-12-2005 03:56 AM
Dome light not working NGNIOUS Electrical & Lighting 3 06-29-2004 02:39 PM
