Old 05-16-2010, 01:57 PM   #1
VMI06WRX04
Member#: 99374
2004 WRX
WRB LISC #68
Default Need help, electrical problem.
So my cigarette lighter and side view mirrors dont have any power going to them... Also my airbag light is on. Im guessing its an issue with a fuse but I have no clue where to start. This is a 2004 wrx... anyone have any clues?
VMI06WRX04 is offline   Reply With Quote
Old 05-16-2010, 02:30 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The lighter and mirrors are on the same circuit so it's probably that fuse. Look in the fuse panel under the driver side dash, behind the little coin tray (you have to pull the tray out to get to the fuses). There is a diagram showing which fuse is which, it's also in your owners manual.
The airbag light is unrelated, for that you need to find out what airbag code is set. A dealer can read the code with a Tech 2 or you can follow the procedure in the service manual to put the system in diagnostic mode and read the code through flashes of the light. One clue is whether your horn and cruise are working, if they aren't or are intermittent as you turn the wheel then your problem is a bad clockspring.
Old 05-16-2010, 02:38 PM   #3
VMI06WRX04
Member#: 99374
2004 WRX
WRB LISC #68
thank you! that was very helpfull, i am going to start troublshooting it all now and will let you know how it turns out!
Old 05-17-2010, 04:02 AM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
It looks like fuse #4 in the dash panel is the correct fuse for those things you mention are having trouble.
i need help electrical burning. MIKENICE456 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-04-2005 02:40 PM
Need Help! Electrical problem eclone Subaru Conversions 4 01-02-2005 12:43 PM
Urgent help! Electrical problem? V8ETR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-27-2002 10:46 PM
HELP! Electrical Problems... eastbaysubaru Service & Maintenance 2 12-23-2001 12:11 AM
('93-'01) Please help - Electrical problems Boeleni Impreza Forum 2 04-08-2001 08:53 AM
