Old 05-16-2010, 07:48 PM   #1
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Default GT40R twin scoll 604 WHP at 1.8bar
Many of you may not have seen my thread so i thought id also post a new thread for the power figures.
On VP109 race fuel we made 604 WHP @1.8 bar and 711 nm WHP torque. This is compared to the 579 WHP 1.9bar on the conventional high mount GT40R turbo setup.
Dyno was done in 5th gear to get 1:1 ratio on an STI 6 speed gearbox
The only difference between the two graphs (see below) of each setup is the new turbo setup was a true twin scroll low mount GT40R, 4" exhaust off a 3.5" dump; properly ported heads. Everything else on the setup was identical.
Only running 1.8 bar boost with this setup, as tuner says that the tune is very happy at this level and didnt want to start hurting the setup. Could easily smash 2.5 bar but there is really no point, at this power level should be well into the 10s no need to get another 50whp..
Event: dyno pull
Ambient Temp: 24 Degrees celcius
Elevation: 31.5 m above sea level.
Weather: nice sunny day
Car: 2004 STI
Tuner:Sean ASG
Dyno Info: Dynopack
Transmission: 6 SPEED DCCD 05 STI
Gear: 5TH
Peak HP at RPM: 603.7 hp at 7100 rpm
Peak Torque at RPM: 710.5 nm at 4750 rpm
Baseline hp/tq for a stock on same dyno: 180-200 WHP Stock STI
Target Boost: 1.8 bar
Target AFR: 11.5
Fuel: VP109 race fuel
Engine/Power Modifications: see build thread http://forums.nasioc.com/forums/show...470621&page=54
Driveline Modifications: see build thread http://forums.nasioc.com/forums/show...470621&page=54
Suspension Modifications: see build thread http://forums.nasioc.com/forums/show...470621&page=54
Other Modifications:
On with the graphs:
Power vs Torque
Power vs Manifold pressure
Power vs Air fuel ratio
New VP109 tune (low mount turbo difference/heads) vs Old VP109 tune Power vs Torque
New VP109 tune (low mount turbo difference/heads) vs Old VP109 tune Power vs Manifold pressure
tino is offline   Reply With Quote
Old 05-16-2010, 07:59 PM   #2
gene4ace
Member#: 108210
WOW nice work!!!! FTW
gene4ace is offline   Reply With Quote
Old 05-16-2010, 08:05 PM   #3
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Sick!
godforbid67 is offline   Reply With Quote
Old 05-16-2010, 08:38 PM   #4
CosworthSTI77
Member#: 195473
2007 STI
Awesome Tino, I bet that is a crazy ride with that power band !
CosworthSTI77 is offline   Reply With Quote
Old 05-16-2010, 08:49 PM   #5
DTSTI
Member#: 129832
2005 STI
GT4094r
Which 40r is this?
DTSTI is offline   Reply With Quote
Old 05-16-2010, 10:14 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
Originally Posted by DTSTI View Post
Which 40r is this?
Yes, curious which turbine housing you went with. Also any pics(or direct links) of the header/turbo setup?
Thanks, and congrats that is sweet!
Ben
Old 05-16-2010, 10:35 PM   #7
tino
Top Scoob 019
Member#: 43630
Its a GT4088R with 1.06 rear housing
Heres the link to my build and heres some pics
http://forums.nasioc.com/forums/show....php?t=1470621
Old 05-16-2010, 10:39 PM   #8
WRX SEX
Member#: 212171
08 SSM WRX
MSPT Tuned: 254whp/343wtq
ballin
WRX SEX is offline   Reply With Quote
Old 05-16-2010, 10:52 PM   #9
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
wow...incredible.
Steve.804 is offline   Reply With Quote
Old 05-17-2010, 01:00 AM   #10
atprex
Member#: 227601
that baby pullin right to redline!.. awesome work brother
atprex is offline   Reply With Quote
Old 05-17-2010, 01:06 AM   #11
AceV
Member#: 243264
Unnnnnfffff......wow!
AceV is offline   Reply With Quote
Old 05-17-2010, 02:17 AM   #12
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
Your car is disgustingly sick man. Truly an incredible build. Congrats.
evan_impreza is offline   Reply With Quote
Old 05-17-2010, 02:41 AM   #13
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
any plans to turn the motor higher than 7500?
All4bSpinnin is offline   Reply With Quote
Old 05-17-2010, 02:51 AM   #14
tino
Top Scoob 019
Member#: 43630
Thanks for the replies guys.
yeh mate the rev limit is set to 8200 currently just not shown on the dyno plot.
Old 05-17-2010, 03:08 AM   #15
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
That is insane, I Dont even plan to go that high on the power, but really makes me concider a Turbo setup like that
seanathanq83 is offline   Reply With Quote
Old 05-17-2010, 03:33 AM   #16
GeneralTJI
Member#: 152680
Good Lord that thing is beautiful
GeneralTJI is offline   Reply With Quote
Old 05-17-2010, 04:04 AM   #17
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
1 Bar on a GT40 at 4k RPM... most 3076 don't hit 1 bar by 4k RPM. Low Mount craziness...700 RPM spool gain?
Concillian is offline   Reply With Quote
Old 05-17-2010, 05:13 AM   #18
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Amazingly good powerband! VERY impressive for such a relatively old turbo design that some have descarded as ancient or surpassed...
I'am starting to like the 40R more and more.
Yes, I noticed too. Is that all to be contributed to the twin scroll set-up you'd say?
Beetspeed is offline   Reply With Quote
Old 05-17-2010, 05:58 AM   #19
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
What's impressive is the spool gain between his 2 plots, but comparing this car to anything else on NASIOC with a 3076 really isn't fair. I know what you meant, that it spools like a 30r, but look at his setup. NOTHING on NASIOC like it.
Truly an incredible build. His main thread is well worth going through...
Tino, I would've liked to have seen how the ITB's came out. But with that being said I have no complaints regarding how the car came out!
Edit: Also is this after you took that cat out?
KP is offline   Reply With Quote
Old 05-17-2010, 07:38 AM   #20
Pavlo
Member#: 23015
95-> GC8
Black, blue and blue
Hi Tino,
I see you finally gave in went with the frotn mounted turbo! I have always found it worked really well, not just for the power but also the flexibility.
Well done.
Paul
Pavlo is offline   Reply With Quote
Old 05-17-2010, 07:54 AM   #21
xsblack
Member#: 26530
2004 Sti
JBP
Tino, you are an inspiration to everyone. It is really good to see all the hard work and time paying off for you. Keep pushing the envelope!
xsblack is offline   Reply With Quote
Old 05-17-2010, 09:01 AM   #22
norexyet
Member#: 39149
11 elantra
yea i said elantra
Fantastic! Looks great tino.
norexyet is online now   Reply With Quote
Old 05-17-2010, 10:47 AM   #23
bertune
Member#: 107290
Nice Tino, nice!
bertune is offline   Reply With Quote
Old 05-17-2010, 10:51 AM   #24
cpturbo
Member#: 49175
2004 STI
Default the McLauren F1 of GD Subaru STi
It is now official that you have the best GD on this board! no doubt in my mind. I will PM YOU !
cpturbo is offline   Reply With Quote
Old 05-17-2010, 10:58 AM   #25
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Tino that is an awesome build! How do you get the oil to to drain out of the turbo?
slowmike is offline   Reply With Quote
Differences btw single and twin scoll GT35 nacho6706 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 05-29-2009 05:35 AM
STI GT40R Twin scroll CAPTIN INFERNO Engine/Power/Exhaust 27 04-27-2008 02:05 PM
STOCK Twin Scoll DownPipe navihawk Private 'Wanted' Classifieds 0 09-21-2007 01:34 AM
Tim's custom fabbed twin scoll setup- aspiringrex North West Impreza Club Forum -- NWIC 21 01-26-2007 12:44 AM
full v8 twin scoll on ebay is a smashing deal. supermoose Subaru Conversions 20 10-10-2005 12:27 AM
