Old 05-17-2010, 11:15 AM   #1
jsavage
Member#: 15699
02 wrx
Default Two leaking rear main seals in a year?? Leaking Head Gasket...Oil Pressure Issues???
During a tranny rebuild 5 months ago I also had a new clutch installed (remachined stock flywheel and exedy stage 1) because the shop said it was covered in oil from a rear main seal leak (they also replaced the seal). Thought I would be trouble free for a long time, but after 2,000 miles the clutch began slipping. The local shop who did the work blamed me for either not knowing how to drive or abusing the clutch, both of which were untrue...salt in the wound guys, thanks!
I used the clutch until it wouldn't hold anymore ~ another 4,000 miles and did the clutch replacement myself this time (after spending $5,000 and getting a transmission that worked worse than when I brought it in, I was unwilling to put it in someone else's hands at that point...my friend let me use his shop, lift, and tools, so it was an easy choice). During the replacement I noticed a rear main seal that was leaking again. After ~ 6,000 miles....? I was glad to know why the clutch was slipping, but now I'm wondering if I have some kind of oil pressure problem. I don't have any engine internal mods, but have just about everything else modded. 02' WRX with 140k, running 500cc injectors (pinks), walboro fuel pump, VF34 turbo @ 1.5 Bar boost, all pipes are aftermarket, larger intercooler and custom tuned CPU. Nothing that would really throw a flag (to me at least).
So, either the original shop did a poor job with the rear main seal install (which is hard to believe, would be difficult to mess that up)...and it's a $8 part, so I'm doubting they lied about replacing it. My head gaskets are also leaking oil a little, so now I'm thinking i may have a high oil pressure problem...? Thoughts??? I do have an oil pressure gauge...I haven't got to reef on the car yet due to breaking in the new clutch, but around 3500 RPM I can get the oil pressure up to 7-8 BAR. Is this high?
BTW, I did go back to the shop and tell them I found out why the clutch was slipping. They didn't seem to care and didn't apologize or anything for my situation. Definitely will not be giving them my money anymore.
Impressive to me is that my original clutch set up (ACT lightweight flywheel and ACT HD clutch) held incredibly strong even when it was "soaked in oil" as the shop had told me...And this clutch had lasted 10's of thousands of miles in this condition. I was reluctant to change it because it felt so great, but I figured it was way cheaper to change it then, while they had the tranny out, then it would be later if it were to start failing. Whereas the exedy only lasted a few thousand of miles, which much less oil on it (only a few thousand miles of leakage on the clutch)... Really speaks to another reason why getting a slightly heavier clutch can be advantageous.
jsavage is offline   Reply With Quote
Old 05-17-2010, 12:36 PM   #2
rkramer
Member#: 118209
2002 WRX Sedan
how much oil are you putting in when you change it? The PSI you are seeing is normal for relatively new, cold oil.
Old 05-19-2010, 05:23 PM   #3
jsavage
Member#: 15699
02 wrx
Whatever the owners manual says...can't remember off top of my head...4.2 quarts or something? Maybe that's my old STi number...
Either way, it's between the dots on dip stick and after oil change and refill I always check next time I get the car up to temp.
Any other ideas other than high oil pressure, on why a rear main seal would be bad after 8,000?
Old 05-21-2010, 10:55 AM   #4
jsavage
Member#: 15699
02 wrx
bump
Old 05-21-2010, 11:06 AM   #5
Haelan
Member#: 151045
2013 Subaru STI
CBP
Checked the condition of the PCV? I would think the dipstick would pop up before the rear seal blew though if it was bad, but it's worth checking.
Haelan is offline   Reply With Quote
Oil leak from rear main seal area? cueball89 Normally Aspirated Powertrain 4 11-29-2009 08:28 AM
Is this my rear main seal or oil seperator plate leaking? mc2 Normally Aspirated Powertrain 8 03-18-2009 06:28 PM
oil leak front main seal? burm Service & Maintenance 3 04-15-2008 01:03 AM
MAIC! Need install help: rear main seal in Legacy Siper2 Mid Atlantic Impreza Club -- MAIC 15 09-16-2005 08:12 AM
rear main seal replacement?+ flywheel and pressure plate bolt torque? Haase14 Transmission (AT/MT) & Driveline 7 01-17-2003 10:42 AM
Message Board Statistics All times are GMT -4. The time now is 07:15 AM.
