Old 05-17-2010, 05:09 PM   #1
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Default Sniper1rfa's most kick butt ball joint removal tool
So Sniper emailed me and said he had something for me to try out. He has a new ball joint extraction tool.
He sent us one to try out, and it arrived today. So..... to try it out we grabbed a spare upright with the most rusted, gnarly ball joint we could find here at the shop.
Removed the pinch bolt
Did NOT spread the cleavage
Did NOT spray in lube
installed Sniper's tool.
Couple of wrenches
Good bit of twist
POP it came right out
This dude is AWESOME!
Old 05-17-2010, 05:24 PM   #2
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
w00t!
sniper1rfa is offline   Reply With Quote
Old 05-17-2010, 05:33 PM   #3
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Link?
boost junkie is offline   Reply With Quote
Old 05-17-2010, 05:49 PM   #4
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
They have the tool, so pictures are on them. I'm ordering up some stock tonight to make a handful. They should cheap enough to buy even for a single use.
Old 05-17-2010, 07:00 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
I'll post some pics tomorrow. It really is badass!!
Tony
Old 05-17-2010, 07:17 PM   #6
trick3d
Member#: 202146
2010 evoru
GG
I love you guys working together to make things easier!!
trick3d is offline   Reply With Quote
Old 05-17-2010, 07:51 PM   #7
wrxracer519
Member#: 149890
09 Forester
Green
Can't wait to see these. Ball joints are a PITA in new england. Have ended up pulling the knuckles off my car to replace them on the bench.
wrxracer519 is offline   Reply With Quote
Old 05-17-2010, 08:36 PM   #8
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I must know what this tool is.
Old 05-18-2010, 10:39 AM   #9
Turn in Concepts
Member#: 93646
Many Track Records
Pics.
Rusty ball joint.
The tool.
Tool installed
Backed it off to check progress. Works quite well.
That's it.
Old 05-18-2010, 10:43 AM   #10
TheNailman
Member#: 133676
2005 WRX
badass.
TheNailman is offline   Reply With Quote
Old 05-18-2010, 10:54 AM   #11
toflaherty
Member#: 212765
2003 WRX
wow, incredible.. my ball joints took probably at least 4 hours per side.. had to completely remove the knuckle from the car, wedge the slide open, and spin it forever with vice grips while spraying a ton of pb blaster in there, and it was still the biggest PITA ever..
awesome, incredibly simple idea.. not to mention, although usually when replacing ball joints you don't care about destroying them, but this makes that unnecessary.. good job
toflaherty is offline   Reply With Quote
Old 05-18-2010, 11:01 AM   #12
5spdfrk
Member#: 46407
blew
Freakin' awesome! Great idea mang.
5spdfrk is offline   Reply With Quote
Old 05-18-2010, 11:06 AM   #13
kpluiten
Member#: 120273
06 WRBWRXWGN
Dang. I did something similar and it broke the ball joint. The threaded part pulled out of the cup leaving the cup in the knuckle. I ended up having to use a hack saw to cut the cup through the gap in the knuckle and then use a hammer and chisel to crush the cup inward until it came free.
I should say that this knuckle was in a wreck and the ball joint was in bad shape so it was probably damaged causing it to separated. It would probably work just fine on unwrecked ball joints.
Depending on price, I'd probably buy one of these to keep in the tool box.
Old 05-18-2010, 11:39 AM   #14
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
So simple, yet so smart. I'll take one when they're ready.
Old 05-18-2010, 11:58 AM   #15
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Interested! Want to buy the tool!
Dentt42 is offline   Reply With Quote
Old 05-18-2010, 12:24 PM   #16
flyinghighlm
Member#: 156235
2002 Subaru WRX Wgn
I would sign up for one, any idea on potential cost?
flyinghighlm is offline   Reply With Quote
Old 05-18-2010, 12:56 PM   #17
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
F'in brilliant man. Elegant, even. Subscribed so I know when I can buy one.
motohippy is offline   Reply With Quote
Old 05-18-2010, 02:06 PM   #18
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
sell these kits!
chimchimm5 is offline   Reply With Quote
Old 05-18-2010, 02:13 PM   #19
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Another thing to add to TIC's burgeoning online catalog. You could do a combo pack with Whiteline Roll Center kits.
Arnie is offline   Reply With Quote
Old 05-18-2010, 02:58 PM   #20
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
You got lucky. When i did mine (and got the idea for this) i was looking on ebay at replacement knuckles the day after i started.
The production version will work without even removing the boot.
Can you describe exactly how it broke? Like, did the ball/taper/thread unit literally pull out of the socket, or is there some other bit?
Don't know if i can do anything about that.
Old 05-18-2010, 04:12 PM   #21
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
I love it!
rexworx is offline   Reply With Quote
Old 05-18-2010, 04:26 PM   #22
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
So this is going into production
happs subi is offline   Reply With Quote
Old 05-18-2010, 04:37 PM   #23
Turn in Concepts
Member#: 93646
Many Track Records
OH SNAP!! That's a good idea!
We're working out details.
Old 05-18-2010, 04:49 PM   #24
dunk
Member#: 15359
Clever.
Duncan
dunk is offline   Reply With Quote
Old 05-18-2010, 06:07 PM   #25
Turn in Concepts
Member#: 93646
Many Track Records
Originally Posted by dunk View Post
Clever.
Duncan
You still on a boat or are you back on land now?
The ULTIMATE Ball Joint Removal VIDEO! Remove with Ease! (2004 WRX in video) Bad_T Brakes, Steering & Suspension 46 05-18-2015 09:51 AM
Ball joint removal video chimchimm5 Brakes, Steering & Suspension 2 10-31-2009 03:17 PM
Ball joint removal, need help Big-E Service & Maintenance 5 12-21-2008 06:55 PM
ball joint removal tool? emyselfandi Legacy Forum 3 05-20-2006 08:01 PM
ball joint removal vtownrida Brakes, Steering & Suspension 12 11-16-2005 09:32 AM
