Old 05-17-2010, 06:48 PM   #1
IGotMeThis
Member#: 240098
1999 Boosted Legacy
Default HELP!!! Turbo blowing oil
Okay .... so i have a 1999 subaru legacy with a ej257 block and NA ej25d heads and my problem is i am on my 3rd turbo and i blow oil pass the seals my TD04L turbo ... i have a -4an stainless steel inlet non restricted ... a 5/8 rubber outlet hose to the oil pan and longest ive had a working turbo was 3 weeks and then one day blue smoke from the compressor blowing oil and on the exhaust side blowing whipped whitish in color oil ... i have done mostly everything but restrict the lines any ideas?
IGotMeThis is offline   Reply With Quote
Old 05-17-2010, 07:06 PM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
restrict the lines.
Old 05-17-2010, 09:28 PM   #3
IGotMeThis
Member#: 240098
1999 Boosted Legacy
any ideas what size restrictor?
or where i could find one
Old 05-18-2010, 10:27 PM   #4
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
What oil and what oil pressure are you seeing? If you are blowing oil past seals either the seals are defective, there is not enough oil flow, or the pressure is way too high. Normally don't see seal failures on regular TD04 turbos and they don't need restrictors. VF journal bearing turbos are much more likely to run through seals in "normal" use.
A restrictor is going to lower oil the flow and increase the bearing temps... You are going the wrong way i think.
-soobaviator
soobaviator is offline   Reply With Quote
Old 05-19-2010, 01:59 AM   #5
IGotMeThis
Member#: 240098
1999 Boosted Legacy
i am usen 10-30 and i do not kno my oil pressure due to no gauge yet but i have a oil pump go to 7000rom so around 71psi at 7000rpm is when i beat on it which ive yet to do but at 2.5k it starts blowing oil so bad seals?
Old 05-19-2010, 08:29 AM   #6
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
So if I understand correctly you have had two other turbos with the same issue?
The actual orifices that send oil to the bearings are very small and perfectly fine for the pressure you are running. Are you sure there is no restriction on the drain side? What about crankcase pressure, have you done a compression and leak down test on the engine?
If oil is coming out of the turbo then the seals are done and need to be replaced. This is an inexpensive fix on a TD04 turbo if that's all that is wrong with it.
Check the motor coondition to make sure you don't have high crankcase pressure that's keeping oil in the turbo too long.
Old 05-19-2010, 06:27 PM   #7
IGotMeThis
Member#: 240098
1999 Boosted Legacy
i have 2 other turbos but their for my other car and i know they have bad seals. but this one i think it does because it never held oil but im thinking it was my motor not my turbo. what would you consider high pressure? and ill check everything else
Old 05-19-2010, 08:33 PM   #8
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Wait, I think I remeber the TD04 having the restictor built into the banjo bolt on the top. Could just be forgetting but I'm pretty sure I remeber it there so you might still need one?
-soobaviator
Fongers is offline   Reply With Quote
Old 05-20-2010, 09:35 AM   #9
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
Possibly so I'm going to check it as I have a bunch of old banjo bolts sitting around somwhere. When I build turbos I use an oil and water line kit with SS oil lines and new banjo fittings. I've done dozens of them with no issues with oil seals on freshly rebuilt turbos. I'll look at it and post up some pics to compare.
Even so it's not like he's running a BB turbo that needs very little oil. I believe something may be going on where the oil is not getting out of the center housing easily enough.
There's not a real practical way to test crankcase pressure and I have no idea what the pressure in the crankcase should be. You need to check cylinder compression and that will tell you if you have a potential excessive blow-by issue that could be contributing to the problems you are having.
Old 05-20-2010, 11:29 AM   #10
IGotMeThis
Member#: 240098
1999 Boosted Legacy
okay ill look and check for the obvious like gas in the oil and stuff like that i do not have a compression tester but my friend does so i will borrow his and ill post up.
Old 05-20-2010, 06:34 PM   #11
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
The td04 uses a restrictor inside the banjo bolt.
I am willing to bet you are blowing out the seals because of too high an oil pressure.
Dutch Scooby lover is offline   Reply With Quote
Old 05-20-2010, 07:07 PM   #12
IGotMeThis
Member#: 240098
1999 Boosted Legacy
when cold start up i do not have any blue smoke come out after i cleaned my intake out and my intercooler due to them being fulled with oil
i just put a lesser oil squirter turbo on with a nos jet as a restrictor and it seems like im burning oil still but i am willing to bet thats just all in my exhaust
i am going to try a weird idea i got from my dad and go to home depot get a clear vinyl 5/8's line and run that as my return line and see if it is backing up or anything (not my permanent line just to see run cold to warmed up due to that fact it will melt)
Old 05-25-2010, 09:21 PM   #13
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
I guess it's semantics but I never thought of the TD04 having a 'restrictor' in the banjo bolt. I have always thought of the bolt as having a metered orifice. Call it what you like here are some pics of the banjo bolts I have used on many many turbos without issue.
Old 05-26-2010, 12:15 AM   #14
IGotMeThis
Member#: 240098
1999 Boosted Legacy
i dont know i know now im not burning any oil with the restrictor im pretty sure it is due to the fact that i have a 2.0 turbo on a 2.5 block and the pressure differences
and i have that exact bolt in their
Old 05-26-2010, 12:17 AM   #15
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
Isn't that the same.
Restrictor = a metered orifice
If you get a bolt from a hardware store with the same thread/pitch the hole is much larger, so I believe the bolt is important for the functioning of the turbo.
All turbo's (non-BB)that I ever bought came with new lines, but all re-used the stock bolt.
Old 05-27-2010, 12:58 AM   #16
IGotMeThis
Member#: 240098
1999 Boosted Legacy
Well i took my turbo back exhaust off and ran alcohol thru it to kill my oil infection and now im not burning any oil with a restrictor and -4an lines and stock bolt
Old 10-05-2010, 02:54 PM   #17
Brou4164
Member#: 247046
2008 LegacyGT spec.B
Grey
Bump for exact solutions.
I've got 08 LGT spec. B with:
FP Green HTA (less than 2k miles, 3.0" inlet, supporting FP free-flow oil line)
Crawford Catch Can
Stock Block
Perrin Up/Mid/Down-Pipes
Perrin FMIC
TiAL 44mm Wastegate (Replaced same time as FPGreen HTA)
Perrin BOV
TGV deletes
PCV reinstalled (under guidance from Forced Performance 500mi ago)
Cat deletes
Royal Purple 15w40
AquaMist HFS-5
New spark plugs (installed under 1k miles ago)
Carbon clean service
Compression Leakdown test done: 0%
I'm losing 1qt every 300 miles. Smoke under heavy acceleration & then when I let off.
I've been advised that it's a crankcase pressure problem, but it hasn't changed with the reinstall of the PCV.
I don't know where else to look, I'm not getting any solutions.
Hope someone on here can give me guidance!
Brou4164 is offline   Reply With Quote
Old 10-05-2010, 09:39 PM   #18
TheLadiesMan
Member#: 98674
1990 Skyline GTR
'03 Mustang Mach 1
Do a compression test.
When I had this issue my rings/ringlands were blown.
Im not sure if that means you haven't done it or you did it and it was 0%.. which I'm not sure how thats a measurement of compression :P
TheLadiesMan is offline   Reply With Quote
Old 12-01-2010, 10:16 AM   #19
Brou4164
Member#: 247046
Grey
Compression was "new car" level according to the mechanic, thus 0% problem there. He did both cold & hot compression tests.
I'm looking for actual advice please, not just useless comments....
Old 12-01-2010, 11:00 AM   #20
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
ok, did you have a leakdown (%) or compression (psi or some form of pressure) test done?
It sounds like a ringland or turbine oil seal issue from what you're saying. Neither of which would be right if you test value is true and the turbo is new and healthy.
0% leakdown is rather impressive considering the stock block and the mods you have. I want to call BS on the mechanic doing his job properly or at all.
1qt/300 miles is way too much for a leaky valve seal(s) if you ask me.
When did your oil consumption show up? before or after the turbo install? When was the compression or leakdown test done?
P.S. Why such heavy weight oil for a stock engine?
Old 12-01-2010, 01:40 PM   #21
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
What oil pump, and/or oil pump modifications are you using?
KillerBMotorsport is offline   Reply With Quote
Help!!! Turbo keeps blowing up! stang95 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 10-05-2007 11:36 PM
help..Turbo Oil Leak? 1VIPWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-10-2006 07:25 PM
2.0L Turbo OEM Oil Filter Help sunder74 Service & Maintenance 3 11-06-2005 05:03 PM
PROBLEM NEED HELP Turbo XS H-RFl Blow-off Install on 05 STI TimL Engine Management & Tuning 8 10-12-2004 09:56 AM
blowing oil through a turbo? milkman Normally Aspirated with bolt-on Forced Induction Powertrain 20 06-25-2002 06:29 PM
