Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 05-17-2010, 07:26 PM   #1
ASF Machine
Vendor Sales Rating: (3)
Member#: 236349
1993 Impreza
OD Green
Default ASF Product Pre-Release E85 Ethanol Pistons
ASF Machine Forged Pistons for E85 by Ross Racing
2618 Alloy
C/R 10:1*
Bore Sizes Pretty Much Any...99.75, 100, (99.5, 100.5 & 101mm etc for you sleeved folk)
This is the old forging...
This is the new Forged Side Relief hotness:
Forged out of 2618 T-61 aluminum, the Ross FSR pistons features an in-board pin boss that accepts a shorter, lighter pin. The pin boss supports the skirt area and piston head with strategically placed strut and web that result in an extremely stiff, yet lightweight design.
E85 Ethanol blend is approximately 105 octane r+m/2 but closer to an effective 110-115 due to the cooling effects of the alcohol as well.
This can sometimes lead to odd characteristics such as poor cold start, spark blowout and cylinder quench at higher RPM.
A qualified tuner can help with these issues through adjustment of ignition timing and fuel mapping, for the most part but why not build your engine to optimize the characteristics of the fuel you use?
You wouldn't run gasoline in your Cummins Diesel would you?**
Benefits include much improved off boost torque and throttle response, better cold start, improved piston life in ceramic-coated severe duty applications and better fuel economy.
More info on E85 in Hotrod's FAQ
http://forums.nasioc.com/forums/showthread.php?t=803341
*Available in other compression ratios
**Can be used judiciously with pump gas in a "flex/dual fuel map" type situation.
__________________
[B][COLOR=Blue]970.242.0919[/COLOR][/B]
[B]Complete Builds, Cylinder Head Work, Porting & Polishing, Block Cleaning, Decking, Sleeving & Sizing[/B]
ASF Machine is offline   Reply With Quote
Old 05-18-2010, 07:33 AM   #2
25rsti
Member Sales Rating: (130)
Member#: 166324
is there anything wrong with running these pistons on regular 93? for the occasional e85+meth?
Old 05-18-2010, 10:22 AM   #3
ASF Machine
Member#: 236349
1993 Impreza
OD Green
"**Can be used judiciously with pump gas in a "flex/dual fuel map" type situation."
That said, I am really only recommending these to guys that are on E85 at least half of the time.
__________________
Old 05-18-2010, 10:49 AM   #4
jdblock
Member Sales Rating: (8)
Member#: 235211
2004 STi
Are these just a higher compression piston, or is it the coating that is special? Do you need to balance the rotating asembly when installing these?
jdblock is offline   Reply With Quote
Old 05-18-2010, 11:56 AM   #5
ASF Machine
Member#: 236349
1993 Impreza
OD Green
The standard duty is a higher compression piston built like a brick house.
The severe duty has a ceramic heat barrier crown in addition to the higher CR & brick house-rally-car-inspired slug design. We've implemented the heat barrier into the severe duty design due to anecdotal evidence we and other have witness during autopsies of some engines that were running E85, built and stock: ring land issues were not the norm in these failures.
Above is an early iteration of our E85 piston, this application was an 11.2:1 high altitude drag car.
As for balancing, these sets are weight matched, most forged rod sets are as well. The factory crank is usually extremely close but getting those last one or two grams dialed in never hurts. So no you shouldn't have to rebalance.
Old 05-18-2010, 05:43 PM   #6
jagstyle
R.I.P.
Member Sales Rating: (6)
Member#: 155186
2007 STI
price?
jagstyle is offline   Reply With Quote
Old 05-18-2010, 06:54 PM   #7
jdblock
Member#: 235211
2004 STi
I'm planning on a 2.0 block with 2.5 crank, can you get me some pistons that would work with this, including the coating? What rods would yourecommend also? X2 for price (PM)? Package deal?
Old 07-24-2010, 04:11 PM   #8
ASF Machine
Member#: 236349
1993 Impreza
OD Green
PM'd you.
There will be 3 sets of these in use at high altitude soon.
__________________
Old 11-22-2010, 01:15 PM   #9
ahowell
Member Sales Rating: (3)
Member#: 152106
'96 One More Part
For State Of The Art
I have a set of the 10:1 CR and I couldn't be happier!
ahowell is offline   Reply With Quote
Old 11-22-2010, 05:37 PM   #10
GrimmSpeed
Vendor Sales Rating: (212)
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
What makes a piston e85 compatible vs other aftermarket forged pistons? What part of these helps optimize the characteristics of the fuel?
Mike
__________________
| AIM: GrimmSpd | Phone: 612-379-0000
Email:
GrimmSpeed is offline   Reply With Quote
Old 11-22-2010, 07:19 PM   #11
FunkDoctorSpock
Member Sales Rating: (1)
Member#: 196559
04 Sti
subject to change.
^ my question also.
FunkDoctorSpock is offline   Reply With Quote
Old 11-22-2010, 08:09 PM   #12
crashtke
Member#: 120912
E85 likes higher compression. In fact it has been tested in NA motors up to 17:1 compression ratio. My particular engine, I am building at ~9.5:1 compression.
crashtke is offline   Reply With Quote
Old 11-27-2010, 06:51 PM   #13
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Mike
The higher compression flat top design to compliment the slower burn is the main thing that makes this an E85 piston. In addition to the flat top which should result in better flame propagation and quench than a given dish.
The ceramic coated crown is simply an added safety measure upon customer request.
__________________
Old 11-29-2010, 06:39 PM   #14
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Dyno numbers are trickling in....
E85 Pistons in an EJ255 swapped into a 96 OBS with a VF39...
E85 Pistons in an ASF E85 spec sleeved longblock sporting an ATP 35R...
__________________
Old 03-03-2011, 12:48 PM   #15
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Bump for the new FSR forging.
__________________
Old 07-21-2011, 12:55 AM   #16
watercooled
Member Sales Rating: (18)
Member#: 109051
04 WRX
answered my own question haha thanks
watercooled is offline   Reply With Quote
E85 Ethanol in Subaru's trininox General Community 9 10-28-2005 12:07 PM
Pictures of subaru concept cars/pre-release cars? HolyCrikey Member's Car Gallery 10 10-13-2004 06:16 PM
Pat Richard Pre-Release Rally of New Zealand Bill Westhead Motorsports 1 04-09-2003 02:18 PM
WRX pre-release info from down under Lovejoy General Forum Archive 2 10-13-2000 10:54 AM
