Old 05-17-2010, 09:44 PM   #1
Danomite
Member#: 190449
2008 RAW motor/Ah2nD
Default Top mount oil cooler with fmic? results?
I am in the market for an aftermarket oil cooler and ran across the b-line top mount for people with a fmic. I was woindering if anyone here used one or has one and how much it helped being under the hood scoop. Or if the location had an ill effect/heat soak because of the location. I am kinda leaning towards the tmoc as it does look badass!!
B-Line Motorsports - Oil Coolers
As of now my car doesn't even have an oil cooler. My engine builder says the stocker isn't necessary as it only heats up the oil and doesn't really cool it at all. I just don't feel comfortable driving without one especially after noticing how thin my oil was after chewing a bearing on my built motor. You could barely tell there was oil on the dipstick. My next rebuild shold be done soon but then again i feel that some form of oil cooling is needed in my case.
Danomite is offline   Reply With Quote
Old 05-18-2010, 12:05 AM   #2
Got Boost?
Member#: 113096
06 sti
would be interested to see a pressure gauge with that hooked up. that would be the highest point oil would need to be pumped to
Got Boost? is offline   Reply With Quote
Old 05-18-2010, 12:31 AM   #3
scuba2708
Member#: 227872
2013 BRZ Limited
Galaxy Blue
hmm....very interesting
scuba2708 is offline   Reply With Quote
Old 05-18-2010, 12:34 AM   #4
Danomite
Member#: 190449
I know you need to add around another qt of oil to fill the cooler.
Old 05-18-2010, 01:03 AM   #5
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
I suggest reading:
http://forums.nasioc.com/forums/show....php?t=1982852
Somehow I doubt an oil cooler is for you, and somehow I think Subaru's engineers know more than your mechanic.
Byzantium is offline   Reply With Quote
Old 05-18-2010, 01:56 AM   #6
Danomite
Member#: 190449
at the least i think i will get another stock cooler. I still have my old onebut it is from a motor that popped a ringland and I'd rather not risk reusing it just in case there's any metal in there.
Old 05-18-2010, 01:59 AM   #7
Byzantium
Member#: 207826
85k 2002 WRX
That's a good idea.
B-Line top-mount oil cooler installed DroppedClutch Water/Methanol Injection, Nitrous & Intercooler Cooling 23 05-30-2009 08:42 AM
Top mount Oil cooler/tran cooler ColesSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-31-2006 08:10 AM
Top mount oil cooler? midnightsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 08-14-2006 01:48 AM
Top Mounted Oil cooler stevo2234 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-16-2005 06:35 AM
Top-Mount Oil Cooler? dl337j00 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-27-2005 09:31 PM
