Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 05-12-2010, 03:10 AM   #1
fuji_production
Member#: 224407
2005 Impreza WRX STI
CGM
Default ecuflash and closed interface
I have this also posted up on romraider, but my problem is i cannot get ecuflash to read my ecu. i can flash to it, test write, read rom, NOTHING. so i did some research and it seems as though i may need to use ecu unlocker? some kind of add on to ecuflash. but eerything is hooked up right ive tried everything possible to get it to work with what i have. please give me your opinions/ideas or even a copy of ecu unlocker if possible. my email is [email protected]
to view my screen shot of ecu flash go here: http:[email protected]/4596345990/
fuji_production is offline   Reply With Quote
Old 05-12-2010, 06:11 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
either access port or ecutek was used prior to you trying
to flash the ecu.
Old 05-12-2010, 10:47 AM   #3
izadoo
Member#: 181467
2004 wrx sti
wrb
had the same problem...bought a new (used) ecu for 50 bucks. been fine for 2 years. the old one is still a paper weight.
izadoo is offline   Reply With Quote
Old 05-12-2010, 11:49 AM   #4
fuji_production
Member#: 224407
CGM
will ecu unlocker not work? and if i do buy a new ecu which do i buy?
Old 05-12-2010, 03:08 PM   #5
unknown001
Member#: 156326
2011 RA
03 bugiftw for the track
ecu unlocker is for evos. what model is your car? usdm,jdm,edm,adm?
unknown001 is offline   Reply With Quote
Old 05-12-2010, 04:41 PM   #6
izadoo
Member#: 181467
2004 wrx sti
wrb
http://www.scoobypedia.co.uk/index.p...patibilityList
nice list of all the ecu's for the cars. I think if you pull the carpet up on the passenger side and unbolt the ecu you can see the model number.
Old 05-12-2010, 04:55 PM   #7
fuji_production
Member#: 224407
CGM
look at the sig. its usdm
Old 05-12-2010, 07:00 PM   #8
unknown001
Member#: 156326
2011 RA
well considering it says international and subaru sells stis everywhere your sig is a little vague. if it is a usdm car you will need an ecu out of an 05. after installing it your local subie dealer will have to marry the new ecu to the immobilizer in your car otherwise you will have a large paperweight.
Old 05-12-2010, 11:45 PM   #9
fuji_production
Member#: 224407
CGM
or i can send it to tactrix
Old 05-17-2010, 10:33 AM   #10
fuji_production
Member#: 224407
CGM
i can pull a learning view from it and reset it through the OP2 does that still mean the ecu is now a paperweight? will tactrix be able to take care of this problem? i think there was an ap before that was not unmarried because the dude left the usb cable in there that looks exactly like the one prepackaged with it and its ziptied. is there a way to resolve this issue?
Old 05-18-2010, 01:27 AM   #11
fuji_production
Member#: 224407
CGM
yump...
Old 05-19-2010, 03:26 AM   #12
fuji_production
Member#: 224407
CGM
heller........
Old 05-19-2010, 11:36 AM   #13
quazimoto
Member#: 70395
Jebeus.........call Tactrix and call Cobb. They can both help you. The ECU is not a paper weight unless it is no longer functioning. That should be a given.
Old 05-19-2010, 01:31 PM   #14
SueBaroo
Member#: 140838
2002 WRX Wagon
03WRX/06STi/07FOZ/08LEG
Cobb charges $100 to unlock your ECU. Tactrix can do it for $75 (04+ USDM STi's).
My car is locked from an EcuteK tune, so I just bought an ECU for $75 off of Car-parts.com, referred from a member on here. You can search year, make, model. Basically the site is a huge junkyard network. The shops all have phone numbers and you call them to place an order. Pretty useful for parts!
SueBaroo is offline   Reply With Quote
Ecuflash and Romraider for Windows 7 PhDinOMG Engine Management & Tuning 6 12-15-2009 03:27 AM
Ecuflash and RomRaider for Windows 7 PhDinOMG Newbies & FAQs 10 11-28-2009 08:32 PM
ecuflash and ecuexplorer don't see the ecu ShellBullet Open Source Reflashes 8 07-11-2009 01:33 PM
Tuning help/hints.. ecuflash and enginuity Timmay81 Commercial ECU Reflashes 10 12-07-2007 03:30 AM
ECUFlash and the ST darksands Engine Management & Tuning 4 12-09-2005 12:15 AM
