Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 06-09-2002, 03:43 PM   #1
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
Default Lookihg for information on engine build
I have a spare 2.5RS block phase I. I am looking for some advise on building it for a modest turbo block for daily driver. I have not yet chosen a turbo kit. I would like to build the kit to the motor. I am looking to run a constant 10 to 12lbs of boost daily and hit higher boost levels when needed. Is there anyone who I could talk to who would be able to point me in the right direction for my project. Also who is the best internal parts supplier and affordable. I am not looking to build a million dollar motor. Just reliable and capable turbo and motor. There is always time to upgrade when needed. Thanks.
CUNNINGHAM is offline   Reply With Quote
Old 06-09-2002, 04:19 PM   #2
Worst Mod Ever
Member#: 369
12 Vagon
The EJ25 is a pretty stout motor when you replace the rods and pistons.
I would talk to Cobb Tuning (not sure if they sell pistons/rods seperate from their built blocks or not still). I would try RalliSpec next. I think both companies use JE pistons and crower rods.
Expect to spend $1300-$1600+ for pistons, rings, rods, wrist pins and the required machining.
The labor to swap block isn't too bad. Just get the required torque specs and make sure you label everything you take off
FYI you motor may make quite a bit more noise after this upgrade. Mine sounds like a diesel
Good Luck,
AaronB is offline   Reply With Quote
Looking for Advice on Long Term Build Setup jpjester Newbies & FAQs 12 03-12-2010 03:35 PM
Looking for TIPS on a HYBRID build up quikcobra Built Motor Discussion 5 10-06-2008 06:34 PM
SOHC Head Build... Looking for suggestions on what route to go Kostamojen Normally Aspirated Powertrain 34 08-17-2007 02:38 PM
Looking for Information on Bozz Speed Dead-Preza General Community 2 06-30-2002 11:15 AM
Looking for Information AfroAssassin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-15-2002 10:28 PM
