Old 05-18-2010, 05:26 PM   #1
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
Default Wideband O2 sensor and separate wiring/gauge
I got what appears to be a standard wideband O2 sensor, i was told it was from a WRX or something, its 6 wires (maybe 5, but definitely not a 2/3 wire sensor). It looks the same as the ones that come with the AEM wideband kits.
So my question, can I use this sensor and just wire up a cheaper AFR gauge to it somehow without having to buy the whole kit? is that even possible? or for example would an AEM wideband only work with the wideband kit gauge and wiring? it seems like I could just get a gauge, tap into 12V and run wires for signal. but i dont know if it needs a controller box or something.
someone school me on how wideband wiring works please
EDIT: or do i just need one of these to plug into my O2 sensor that i have?
http://www.innovatemotorsports.com/x...cat=262&page=2
elislider is offline   Reply With Quote
Old 05-18-2010, 05:28 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
the narrowband gauge is made to process .1-1v, so wideband won't work.
the sensor AEM uses is a VW, with a resistor circuit or something installed at the sensor plug.
eg33GC is offline   Reply With Quote
Old 05-18-2010, 05:31 PM   #3
elislider
Member#: 133923
03 Legacy GT wagon
what narrowband gauge are you referring to. ive been reading on the AEM site and it seems the controller is the part i didnt realize i needed, and what makes it expensive
Old 05-18-2010, 05:33 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
about any narrowband that only has wires for 12v,-,ilum, and signal.
Its just translating voltage to a corresponding LED.
FS: (FL) PLX Wideband O2 sensor and wiring javasti Engine/Power/Exhaust 2 03-18-2010 02:14 PM
can i zip tie second o2 sensor and put wideband o2 in that spot? sidwin AccessPort 2 02-11-2008 06:18 PM
FS Bosch wideband o2 sensor LSU 4.2 5 wire hector Engine/Power/Exhaust 4 11-11-2007 12:55 AM
WTB: Knock Link with sensor, and a wideband o2 sensor with monitor SolidSnake Private 'Wanted' Classifieds 2 05-04-2006 09:30 AM
Wideband O2 sensor and Helix V2 dp JDM 3SGTE Engine Management & Tuning 7 03-03-2005 09:24 AM
