#1 |
Member#: 256615
Bought some perforated tube and fiberglass packing material earlier last week. Stuff finally showed up today. I machined a die early this week to have the 1.5" tube thats used for the dual dumptubes on a full-race setup (38mm ewgs) so that they have a smooth transition to 2" which is the OD of the "muffler" section and to have a overall cleaner appearance. Cleaned it all up after cutting and forming and welded it all together. Here is the outcome-
#2 |
Member#: 233501
Vehicle:07AD 337/335SAXWAGON 99 outback sport |
Looks awesome, I'm intrigued to hear what one would sound like.
#3 |
Member#: 250910
Vehicle:2002 WRX Blue |
Beautiful work, but I'll keep my open dump tube.
#4 |
Member#: 256615
Installed a pair of these on a full-race equipped car. Install wasnt too bad and went fairly smooth. Now initially i thought the mufflers were gonna help a lot, but after building them i started to have my doubts on how these were realistically going to affect the level of obnoxious noise ewg's make. There is 12" of perforated tube and packing material, but the 1/4" of space around the perforated tube is what gave me doubts on the effectiveness of the muffler. But after a quick spin to test them out I was very happy with the outcome. Mufflers exceeded my expectations and do a great job of making things sounds good.
#5 |
Member#: 201416
Vehicle:1998 Impreza L White |
It may just be the angle, but those look like that hang really low!
#6 |
Member#: 141952
Vehicle:03 emo 8/2011 wrx |
I like the little supertrapp disc muffler, it also dissapates the exhaust out of the sides so it doesnt bounce off the road.
#7 |
Member#: 141040
Vehicle:07 2.5i wagon UGM |
Man, i've wanted to do this forever...
Dual exhausts with one central dinky EWG one. You never see a car with 3 exhaust pipes. ![]() |
#8 | |
Member#: 256615
Overall the packaging of everything went well, considering I had to fit 2 small mufflers in there. |
#9 | |
Member#: 277987
W. Canada
#10 |
Member#: 256615
just a 3" dp
#11 |
Member#: 242850
Vehicle:2010 wrx blue |
very nice!! I made my own chambered style ewg muffler for my honda when I had an external dump. It made a huge difference in noise reduction. You could still hear it but, it wasn't obnoxious anymore
#12 |
Member#: 256615
Went from 102db @50ft before mufflers down to 91db @50ft after muffler install.
#13 |
Member#: 172486
Vehicle:95 V4 STi-RA swap Stage 49.8 |
Wow! 11 decibels is a lot. It's like going from an Invidia N1 exhaust to a standard muffler.
#14 |
Member#: 167794
Vehicle:2004 WRX Wagon daily 91 miata. because racecar |
I just run a small supertrap on my dump tube. It works great, and lets me adjust the sound level by adding or removing discs.
#15 |
Member#: 127359
Vehicle:2006 WRX TR CGM PPG's,Polka pickled,ewg |
Beautiful work...I have seen guys use dirt bike/motorcycle mufflers coming off the wg before but nothing quite like this! Good job!
#16 |
Member#: 100834
BAIC
Vehicle:2006 Subaru STI Steel Grey Metallic |
You can hear what it sounds like here:
And scroll though my other recent vids to hear it with the open dumps. Thanks again for the mufflers! They worked out PERFECTLY. And these are not directed straight at the ground. I requested a slight downward angle just so they weren't blowing at the ground or at my car, because yes if they were turned down to the ground the sound would just bounce back and i'd still be over my sound limit. |
#17 |
Member#: 201416
FYI...to all the fabricator guys out here...I'd be willing to pay someone to fab me an EWG muffler for my dump pipe.
It's the P&L EWG Set-up, and my dump pipe is not as close to the downpipe as in this thread. http://www.iwsti.com/forums/vendor-g...group-buy.html If anyone's interested, and needs measurement, I can get the info ASAP. Thanks, BTD. |
#18 |
Member#: 100834
BAIC
just pm Tigwerks he'll do it i'm sure
#19 |
Member#: 201416
Thanks!
Will do. |
#20 |
Member#: 159738
SCIC
Vehicle:2004 WRB STi Full Race TS, BW 8374 EFR |
What car is that on? I assume it's a Full Race twin scroll header/up pipe with twin Tial mvs waste gates? How much to make me a set?
#21 |
Member#: 256615
I couldnt actually make a full working set, only the mufflers. No way of knowing how to make the dumptubes to fit someones actual setup.
#22 |
Member#: 183529
Vehicle:i wanna help teh haters ... love life ... |
does it hang lower than the subframe?
#23 |
Member#: 100834
BAIC
The mufflers themselves don't hang lower than the subframe, but the turndowns I have on the ends do by an inch or so.
#24 |
Member#: 232430
RMIC
Vehicle:555 I haz 5 Subarus GC8/GF/SG/GD sedan & wag |
Why not just run the dump tubes into the Down Pipe?
#25 |
Member#: 124581
Dumping the wastegate back into the downpipe or even further down the line in the exhaust creates a swirling gasses action creating a little back pressure....or you can just say "because race car." Either work really.
| Thread Tools | |
| Display Modes | |
| Anyone put a silencer or small muffler on their EWG dump? | Defiant Autospeed | Factory 2.5L Turbo Powertrain | 206 | 05-03-2013 02:23 AM |
| 1.5" Muffler for EWG? | RainMaker | Factory 2.5L Turbo Powertrain | 4 | 06-21-2012 06:57 PM |
| muffler for EWG dump tube | jaegmeister | Factory 2.0L Turbo Powertrain | 20 | 07-11-2011 11:43 AM |
| FS : HKS Carbon Ti Muffler- SOLD | aaron0815 | SCIC Private Classifieds | 30 | 06-20-2011 03:08 PM |
| How much will a small muffler quiet down an EWG? | scooterforever | Factory 2.0L Turbo Powertrain | 4 | 03-22-2007 01:16 PM |
