Old 04-29-2012, 11:25 PM   #1
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
holset he351ve @23psi
Default light/push bar
heres a light bar i made for my bugeye. i designed it around the premise of being strong enough to not shake when lights are mounted on it, to help protect my FMIC in lil fender benders, and be semi removable, with plans of also mounting a skid plate to it. this current version is made out of some exhaust tubing, and cost me $20 to make. (cost of metal.)
as it sits now, need to mount my lights still and fab a skid plate for it too.
dirtbikeridr12 is offline   Reply With Quote
Old 04-30-2012, 01:42 AM   #2
E85FTW
Member#: 313807
are you planning on going to war with that thing? haha jk pulls it off quite well!
E85FTW is offline   Reply With Quote
Old 04-30-2012, 08:02 AM   #3
ScoobyNub
Member#: 269662
how is it mounted?
ScoobyNub is offline   Reply With Quote
Old 04-30-2012, 11:41 AM   #4
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
took two 14in pieces of the same tubing and welded them to the sub frame. on the two pieces of the bar that go under the nose i stretched the pipe to slide over its original OD, so the bar simply slides onto the two mounts underneath and bolts secure. there is about 3-4in of overlap that the bar slides on. the setup is strong enough for me to stand on (160lbs)
Old 04-30-2012, 03:47 PM   #5
jfindo884
Member#: 271977
SRP
Hey really sweet looking build!!! I'm planning to make something like this for my STI soon.
Just wondering what the hell kind of exhaust pipe you are using that holds 160lbs??? lol Thats impressive
jfindo884 is offline   Reply With Quote
Old 04-30-2012, 06:42 PM   #6
racepak
Member#: 144903
thats hot!
racepak is offline   Reply With Quote
Old 05-01-2012, 01:03 PM   #7
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
Not bad. But that exhaust tubing will not hold up to much, not to mention the ground clearance you lost.
I built this one out of 1 1/4 .120 CMDOM tubing. It has taken a beating, and still holds up.
http://forums.nasioc.com/forums/show....php?t=2193229
Kris.is.awesome is offline   Reply With Quote
Old 05-02-2012, 06:17 PM   #8
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
didnt built it to battle tanks, but it is just a prototype for now anyhow haha, nice lil bar tho, clean setup
Old 05-23-2012, 04:06 PM   #9
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Gr3en is offline   Reply With Quote
Old 05-23-2012, 06:00 PM   #10
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
nice, i like that a lot actually. but hard for me to hate the price i paid for mine tho hahaha what do you use for mounting points for yours?
Old 05-24-2012, 08:36 AM   #11
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
We used existing sub frame points.
Old 05-28-2012, 04:15 PM   #12
KennyS
Member#: 296586
2002 Impreza Wrx
Custom, Who knows
are you going to weld on the brackets for the lights or not mount lights, either way i give you +1. i like the thick bar on it. if i could give you a suggestion i would try to add some support to the top in the middle. sometimes the light bars like to bounce and be noisy, adding a support bar from the middle to around where the horns go is a good idea.
KennyS is offline   Reply With Quote
Old 05-29-2012, 01:06 PM   #13
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
yea i plan to weld some tabs top center and on the bottom as well for my lights. and if they do bounce i will add support, but since i dont plan on adding a lot, or any really heavy lights i hope it wont bounce much. thanks for the props tho
Old 05-29-2012, 07:54 PM   #14
KennyS
Member#: 296586
2002 Impreza Wrx
Custom, Who knows
Ya this only happens in dirt or really rough roads.
Old 06-04-2012, 04:08 PM   #15
action fab
Member#: 304936
97 GF8 2.5RS
red
I highly doubt it would hold up to much... most exhaust tube is 16-18ga, not much more than the thickness of sheet metal. Although it serves as a good light/lite mount. I don't think it would save much in the event of contact.
For the next go arount source out some 1.75x.120 or 1.5x.120 HREW you could keep the weight well under 25lbs and depending on your mounts, actually have a usable bull bar.
action fab is offline   Reply With Quote
Old 06-10-2012, 11:49 PM   #16
minitaco
Member#: 236998
thick pipe looks great. I wana try something similar that will mate up with my skid plate. Would you say your set up is strong enough to push back light brush? thats all the strenth i need mine for.
minitaco is offline   Reply With Quote
Old 06-20-2012, 02:18 PM   #17
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
yea i imagine light brush wouldnt be a problem. im sure it'll push over pretty small saplings with ease.
Light Bar/Push Bar for 2011 WRX/STI Chuck Annicelli Electrical & Lighting 28 11-13-2011 03:41 AM
Police equipment, Push bars, Random things little Overstock... TheWRXMan Private 'For Sale' Classifieds 0 01-26-2004 12:04 PM
push bars on the rex? Yasin North West Impreza Club Forum -- NWIC 1 07-18-2003 03:13 AM
Outback Push Bar 25RS Legacy Forum 3 01-16-2002 03:50 PM
push bar for a 98 legacy GT purejuju Legacy Forum 2 01-16-2002 03:49 PM
