Old 05-18-2010, 09:46 PM   #1
Roy
Member#: 32241
1998 Impreza L Coupe
white
Default 98 Impreza Coupe Questions
Some questions regarding my 98 Impreza Coupe with the 2.2 engine.
Overfilled the oil today during an oil change. Cold oil level is up to the "notch" on the dipstick for hot oil.
Will it hurt to leave it that way or should I drain 1/2 quart to avert blown seals and other problems???????????
Is there supposed to be a splash pan beneath the radiator and front of the engine?
My 98 doesn't have one (lost by PO maybe?) while my son's 05 WRX did have one.
Drive belts for the alternator, AC, etc. are squealing at idle & low speeds. Belt dressing momentarily stops the noise.
Other than new belts is there a way to eliminate the squeal?
Thanks,
Roy
Roy is offline   Reply With Quote
Old 05-18-2010, 11:04 PM   #2
cmiovino
Member#: 134005
2004 WRX Premium
I'd drain it and fill to specified levels. Can't be too careful.
It could lead to blown seals as you said. It could also lead to less lubrication and low oil pressure... things you don't want to mess with. Or it couldn't since 1/2 quart isn't that much overfilled. I'd just redo it so it's 100% ok, others might not agree.
I don't even know if my '98 came with the splash pan you're talking about. It should be fine.
Old 05-22-2010, 10:23 PM   #3
Roy
Member#: 32241
white
Bit the bullet and drained 1/2 quart of the new oil out. All is OK now.
Also put new belts on for the A/C and alternator. Now the horrible squealing at idle and low speeds are gone.
Thanks,
98 impreza coupe interior partout + more k3lh3 NWIC Private Classifieds 15 02-02-2010 09:19 PM
98 Impreza Coupe Tire Fit? Roy Tire & Wheel 0 12-15-2008 09:54 PM
WTB 98 impreza coupe bulkhead subajay Private 'Wanted' Classifieds 2 04-28-2008 02:42 PM
Wtb 98 impreza coupe door wiring harness subajay Private 'Wanted' Classifieds 3 04-13-2008 08:44 AM
WTB: 98+ Impreza Coupe/Sedan RS Prophecy3 Canada Region Private Classifieds 0 04-13-2006 12:29 AM
