Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 05-19-2010, 01:19 AM   #1
NWSTi-wa
Member#: 245786
Default Engine troubles HELP!
So last friday I was driving my 04 sti over stevens pass and my check engine light came on and about 5 minutes after that my car lost power well at least the turbo. There was no boost but the engine itself still ran. I had no choice but to limp it back to my house but I was wondering what the deal is? There is no abnormal noise or smoke from the tailpipe or engine bay. The car did make a couple weird noises right before it went out but after that it made no weird noises at all. The check engine light is on and the cruise is on that's it. Also the wastegate is tight.
Any info would be great!
NWSTi-wa is offline   Reply With Quote
Old 05-19-2010, 02:06 AM   #2
skatevolcom06
Member#: 199522
2004 Impreza STi
PsM
Check and see what your code is causing your check engine light to come on. That will tell you alot!
Also did you make sure all of your fluids are good?
skatevolcom06 is offline   Reply With Quote
Old 05-19-2010, 02:16 AM   #3
NWSTi-wa
Member#: 245786
I am getting it scanned tommorow. I had it scanned previously and the dealership said somthing about a oil pressure regulator valve? I cant quite remember but they said not too worry about it and to put some more oil in it and it will be good. it was a quart low. So I did and about a day later, it was a quart low again. BUT there were absolutely no leaks coming from the car. Nor was there any black/white smoke coming from the car. Then a day later everything went away, no check engine light or anything. car ran great. Then a week later this happend. And at that time all fluid levels were good.
Old 06-12-2010, 08:25 PM   #4
justchillax808
Member#: 177287
Chapter/Region: HIIC
2006 STi
steel gray
Do a compression test
justchillax808 is offline   Reply With Quote
HELP 2006 engine troubles subywuby45 Service & Maintenance 5 02-21-2008 09:38 PM
Engine Trouble Help brianswagon Factory 2.0L Turbo Powertrain 2 09-12-2006 01:40 PM
engine trouble, help legacydreamz Legacy Forum 6 04-08-2006 11:07 AM
need some subie help,engine troubles... Vidiotgamer Factory 2.0L Turbo Powertrain 8 10-29-2003 04:30 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain 3 01-14-2003 09:04 PM
Message Board Statistics All times are GMT -4. The time now is 10:05 AM.
