Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 05-30-2012, 08:49 PM   #126
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
I've got a 16 psi map for that setup. Have you seen my baja tuning thread on romraider?
2.5 turbo hyped is offline   Reply With Quote
Old 05-31-2012, 08:21 AM   #127
lumpy
Member#: 28410
2012 Impreza Sport
Honestly have not been to romraider in a while. Forgive my ignorance for some of the following questions, I am just trying to work through this...
- In order to use a map like yours, all that I would need is a tactrix cable and a laptop, correct? Is there more that I need?
- I have an electronic boost gauge that I have yet to install, and that would certainly be recommended if I were running a non-stock map. Do you also have a wideband O2 sensor? If so, is it really necessary? I can't have my vehicle be a rolling Christmas tree with a zillion gauges in it, since I occasionally have clients in my car and I need to fly under the radar a bit.
I also have a VF-39, a STi intercooler and a Walbro 255 sitting in my basement. I may or may not decide to install them depending on the answers to the questions above. I am leaning towards doing the uppipe and downpipe and calling it "done".
lumpy is offline   Reply With Quote
Old 05-31-2012, 09:03 AM   #128
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
walbro is a must, wb o2 highly recommended, buy a vag com cable not tactrix. Tactrix is basically the same thing rebadged. I dont have any maps that do not require logging at least 1 meg and at least 1 2k to 5k pull in 3rd. No way around that. I will buy the vf 39 from you.
Old 05-31-2012, 09:11 AM   #129
lumpy
Member#: 28410
2012 Impreza Sport
Really, I would need the Walbro just to run the downpipe and uppipe? Maybe I am misunderstanding.
I'll let you know on the VF-39. I have not completely buried the idea of installing it yet.
Thanks for the info!
Old 05-31-2012, 12:07 PM   #130
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Walbro is cheap insurance on any subie. They are only 90 bucks shipped.
Old 07-17-2012, 03:59 AM   #131
optikul81
Member#: 248698
2005 Baja Turbo
Default Baja + VF39+STI TMIC = Sexy!
I would HIGHLY recommend installing that vf39 and sti tmic..
optikul81 is offline   Reply With Quote
Old 07-19-2012, 04:27 AM   #132
jrigby
Member#: 256134
2005 Baja Turbo 6MT
Originally Posted by honda killer View Post
2009 STi struts will fit the Baja, without any fabrications....
Just be aware that the ride hight will drop a couple inches.
has anybody ever taken the time to confirm/deny this? Looking at pictures this looks possible.
jrigby is offline   Reply With Quote
Old 02-06-2013, 10:10 PM   #133
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
I would love to know since I could get some gravel/rally coilovers and it should raise up the baja
SedonaScooby is offline   Reply With Quote
Old 02-07-2013, 07:49 AM   #134
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Yes, they will fit. Here is the deal. I have a 2005 STI and the front coilovers match up perfectly except for the camber plate. It is at a 45 degree angle from where it should be so you get a camber/caster adjustment combo. For the rears I had a stock strut off of a 2009 sti. I held it up and it did in fact match up, however I did not bolt it on to confirm this. It was visually the same though.
I am going to be running a set of dominator tracks (americantracktrucks.com) on the baja this next winter so I fabbed up some 4" lift plates for both my STI and the baja. This way I don't have to screw around with the coilovers I can just bolt the lift plates on, load up the tracks and head to the snow. One could use the lift plates just for a lifted look on the baja although I think the axles would have to be longer at some point.
On a side note BC racing makes coilovers SPECIFICALLY for the baja now. I wish I would have bought those rather than the ISC kit which is basically a 2009 STI coilover kit.
Old 02-07-2013, 05:35 PM   #135
SedonaScooby
Member#: 143522
98 Forester L (RIP)
Think those coils raised up to nearly max height would actually raise the baja??
Old 02-07-2013, 05:54 PM   #136
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Hell no. There is not a coilover setup out there that is made to raise/lift the baja unless you find a rally setup for a 2009 sti and then you are talking 4-5k for a setup. I made lift plates like I said.
The coilover kits that both isc and bc racing make for the baja at the highest safe setting still lowers the vehicle 1" below stock. On the isc setup you have no choice but to lower the baja 4" because there is not enough adjustment on the rear coilover to go any higher. I believe the kit ISC uses is made for a 2009 sti for this reason.
There is not a day that goes by that I don't regret buying the isc kit for the baja. I should have bought the bc racing setup.
Old 02-07-2013, 05:56 PM   #137
SedonaScooby
Member#: 143522
98 Forester L (RIP)
I'm looking for a lift for my 06 baja turbo 5 speed...figured I would ask. Guess I will stick with strut blocks, springs, and bigger tires...
Old 02-25-2013, 10:11 PM   #138
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
I just bought an 05 Baja Turbo 5speed and tried to swap my Kartboy short shifter from my 04 WRX and it does not fit (section for bolt it wider). Probably going to modify it to work but just thought I would post up my finding.
JungleFevre is offline   Reply With Quote
Old 02-25-2013, 10:32 PM   #139
Benhart21
Member#: 149617
There's two different widths. One for the regular shifter and one for the factory short shifter. I bought the Forester version for mine and they send me the wide spacer when I needed the narrow.
Benhart21 is online now   Reply With Quote
Old 02-25-2013, 11:44 PM   #140
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
So what are you going to do? I think I'm going to grind it down to make it work, however, the WRX one is even shorter than the Forester one. Not sure if it will be too short or not.
Old 02-26-2013, 12:36 AM   #141
Benhart21
Member#: 149617
I just emailed Kartboy and they sent me the proper one, but that was years ago when I bought it. The difference between the WRX and Forester shifters is the length. The Forester one is 2" taller.
Old 02-26-2013, 11:40 AM   #142
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
So do you think it would be too short to properly shift gears?
Old 02-26-2013, 02:14 PM   #143
Benhart21
Member#: 149617
Probably not, but it'll just be very stubby sticking out of the console.
Old 03-16-2013, 10:37 PM   #144
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
Which install kit do Baja Turbo's use with the Walbro 255?
Old 03-16-2013, 10:55 PM   #145
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Are you serious? You don't need an install kit, just swap the pump.
Old 03-17-2013, 12:28 PM   #146
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
I'm taking about the new filter etc. It comes with the pumps. When I swapped the one on my WRX, I swapped the harness, filter, and tubing.
Old 03-17-2013, 02:12 PM   #147
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Like I said, the pump is a direct fit. Wiring harness and all.
Old 03-18-2013, 08:37 AM   #148
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
Forget about the walbro's because they whine too much and second, there are a bunch of complaints about reliability. I believe asians are supplying fake pumps into the market. Just have to look for a verified vendor.
I installed an aeromotive fuel pump and runs like a oem but a higher capacity than a walbro, like i need it, and its been installed for a while and i cannot say nothing bad about the reliability or Whine. Do some research before you pay.
Sorry 2.5 my opinion is directed to jungle. I grabbed the wrong quote box
Last edited by Baja_Gernaut; 03-18-2013 at 08:41 AM. Reason: Too early on the forum
Baja_Gernaut is offline   Reply With Quote
Old 03-18-2013, 08:56 AM   #149
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
No worriez. I think I am going to upgrade to the aeromotives as well for peace of mind.
Old 03-18-2013, 11:48 PM   #150
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
I ran a Walbro on my WRX and never had a problem (didn't seem to whine at all). Kept a bunch of stuff from the WRX to go on the Baja (68hta, STI tmic, UP, Hallman Pro, etc). Just need a DP, fuel pump, and injectors. Anybody swap to top feed injectors on their Baja's?
clutch and flywheel what works with what?!?! scobaru Subaru Conversions 10 01-06-2005 10:21 PM
What Works with Borla Hush? HerculesPeanut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-28-2004 04:21 PM
ej20's and what works with what scobaru Subaru Conversions 4 10-24-2003 07:28 PM
Advan RG works with what brakes??? Subaruist Brakes, Steering & Suspension 1 10-22-2002 11:23 PM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:55 AM
