Old 05-19-2010, 02:27 PM   #1
mtbiker278
Member#: 242578
2010 WRX
Spark Silver
Question 9011 HIR bulb for foglights?
I just finished reading a bunch of stuff about bulbs and what's available (stickies included).
Would HIR bulbs be a bad idea for fog lights? I know they generally scatter light low and wide, but i wasn't sure if replacing 9006 bulbs with trimmed 9011 bulbs would throw up too much glare. If there would be glare would putting a yellow film over the lens help?
thanks for the help!
mtbiker278 is offline   Reply With Quote
Old 05-19-2010, 05:24 PM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Wirelessly posted (Phallic Tractor: BlackBerry9630/5.0.0.497 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Are your fog lights using 9006 bulbs already? They shouldn't be.
Also, as long as there is some sort of shield over the tip of the bulb, you should be fine as far as glare goes. Yellow Tint will defeat the purpose of having more light.
XanRules is offline   Reply With Quote
Old 05-19-2010, 05:29 PM   #3
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
PS: to answer your question in short, yes, they're a bad idea for fog applications.
Old 05-20-2010, 10:42 AM   #4
mtbiker278
Member#: 242578
2010 WRX
Spark Silver
everything is still stock. I was just wondering for future replacement.
Old 05-20-2010, 12:50 PM   #5
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
You shouldn't have 9006 bulbs in there.
But if you do, I wouldn't recommend HIRs.
Old 05-20-2010, 03:37 PM   #6
mtbiker278
Member#: 242578
2010 WRX
Spark Silver
Could you please explain why they are a bad idea? Road Glare? extra watts? it'll open up a black hole?
thanks!
PS- the 9006 bulbs are the stock spec'd bulbs.
Old 05-21-2010, 06:32 PM   #7
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Do the factory fogs have any sort of shield over the bulbs? If they do, go for it.
Old 05-21-2010, 07:08 PM   #8
MikePiper1
Member#: 206162
2013 STI Sedan
ISM
I installed HIR's in my fogs and I was not impressed. There was hardly any difference between stock and the HIR's. Save your money and put HIR's in your high beams They are a major improvement over stock highs.
MikePiper1 is offline   Reply With Quote
Old 05-21-2010, 09:01 PM   #9
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Troof.
Old 05-21-2010, 09:58 PM   #10
mtbiker278
Member#: 242578
2010 WRX
Spark Silver
MikePiper1 - were they 9012 HIR or 9011 HIR? I ask because the 9012 bulb has maybe 50% more light output than the 9006 where as the 9011 bulb have something like 110%.
Old 05-22-2010, 02:07 AM   #11
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
The difference is the base. You will not be able to physically fit a 9011/hir1 bulb in your 9006 housing.
Cheapest place for HIR bulbs? mummer43 Electrical & Lighting 20 12-01-2009 02:04 PM
Osram H3 bulbs for foglights geddesk2 Exterior/Styling 8 01-23-2008 05:26 PM
85watt bulbs for foglights jpsimon Electrical & Lighting 12 05-26-2005 12:20 PM
If you own a 04+ you really need to try the 9011 HIR bulbs BIGSKYWRX Interior & Exterior Modification 11 10-11-2004 09:21 AM
Yellow Bulbs for foglights cammy712 Interior & Exterior Modification 16 05-14-2001 09:45 PM
