Old 06-09-2002, 09:32 PM   #1
adamsrs
Member#: 3768
Exclamation Defi Gauge Question..Important! Thanks!
I have just recently installed a set of Defi Link EGT gauges. THey are 52mm and have a black face....well my Boost gauge is GREAT, but the EGT and the Fuel Pressure one are not perfect..they needles wiggle...im confused as to why though. THe ONLY thing that i did was cut the daisy chain and extend it becuase i have the Boost gauge in the a pillar and the fule pressure adn EGT in the center console...any ideas as to why the needles wiggle? Thanks a LOT!
adamsrs
adamsrs is offline   Reply With Quote
Old 06-09-2002, 09:44 PM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
wiggle? like how much?
cause I don't see it..
JenisonWRX is offline   Reply With Quote
Old 06-09-2002, 10:00 PM   #3
adamsrs
Member#: 3768
The EGT wiggles quite a bit! Like 1/8-1/4 of an inch....and the Fuel pressure about 1/16" could the Daisy chain extensions be causing this? The lack of insulation, the lack of conduit...doesnt make sense.....PLEASE HELP! I cant tell if my EGTs are 1500 or 1700 some times it moves so much!
adamsrs
Old 06-09-2002, 10:30 PM   #4
silvercharged
Member#: 19295
Defi gauges need a GOOD ground, in my experience, to work real well. Try running the black ground wire from the power harness directly to the negative terminal on the battery. This may help.....
silvercharged is offline   Reply With Quote
Old 06-09-2002, 10:40 PM   #5
adamsrs
Member#: 3768
Ok, thanks.......but this still makes no sense because the boost gauge reads perfectly! Im pretty confused...
Old 06-09-2002, 11:35 PM   #6
Kcz
Member#: 2038
2000 RS-T
Silverthorn Metallic
I had the same problem. Make sure the egt cable is secure and not bouncing around in the engine bay. I zip-tied mine in about three places and the needle isn't jumping all over the place now.
Kcz is offline   Reply With Quote
Old 06-09-2002, 11:44 PM   #7
adamsrs
Member#: 3768
So i need to tie down the actual EGT cable....?not the wiring harness? That sounds too easy! How would that make sense though.....please explain
adamsrs
Old 06-10-2002, 06:40 PM   #8
Kcz
Member#: 2038
2000 RS-T
It doesn't make sense, just try it, mine works perfect now. Just secure the steel braided line that goes to the probe. I just moved the cable around and it would work for a little while and start bouncing around again. Then I just zip tied it down real good.
Old 06-10-2002, 07:05 PM   #9
adamsrs
Member#: 3768
And you did this on a DEFI gauge? Ok, i will try it...but what about where the wire is too long...i had to loop it up....have any pics?
adamsrs
Old 06-11-2002, 12:08 AM   #10
Kcz
Member#: 2038
2000 RS-T
Yeah I have the DEFI boost and egt guages. I'll try to get some pics.
Old 06-11-2002, 12:20 AM   #11
Kcz
Member#: 2038
2000 RS-T
I think what is causing it is the small harness that is about 2ft. from the probe. I don't think they chose a very good connector. Make sure that harness isn't moving around too much.
Old 06-11-2002, 05:06 PM   #12
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
The boost gauge is mechanical, isn't it? I am assuming the EGT and fuel pressure gauges have senders. I bet it is a bad connection on one of the wires, power, ground, or signal.
wcbjr is offline   Reply With Quote
Old 06-29-2002, 12:00 AM   #13
foofoo
Member#: 20658
Hey guys,
I know this thread is getting pretty long but I too have the same problem with my Defi gauges. I also have an important question for all of you. I also have a 60mm tach gauge that would only go up to 5k. This is what would happen. I would start the car and the tach gauge would read the rpm's exact. Then when I gave it some gas the needle would start to bounce like crazy ( when I started to go over 3k ). I would take my car to a track and rev it up over 6k but my Defi tach would only go up to 5K. Finally after I did a run I would hit the peak button and the tach would show 11k. YEAH WHATEVER!!! The highest I would take it is like 72k. Has anybody else had this problem with any of there gauges??? Also, the dealer I bought this from doesn't know exactly what to do. Should he call Defi directly and ask for a version II as a replacement. Hope you guys respond to this question.
foofoo is offline   Reply With Quote
Old 07-01-2005, 02:19 PM   #14
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Sorry to bring up a old post. My EGT is having the same bouncing problem... Anyone found a remedy?
Big-Sexy907 is offline   Reply With Quote
Old 08-12-2005, 11:52 AM   #15
Seranin
Member#: 54409
2006 Forester
Ditto with my Boost gauge... seems either grounding or securing cabling?
Seranin is offline   Reply With Quote
defi gauges questions dodiox Electrical & Lighting 13 03-01-2006 05:05 AM
Defi gauges questions subablunc Newbies & FAQs 9 01-06-2006 08:52 AM
defi gauge question awdguy Newbies & FAQs 2 06-17-2004 10:17 AM
Defi gauge question datwrx Southern California Impreza Club Forum -- SCIC 6 12-26-2003 04:03 PM
DEFI Gauge Question! adamsrs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-10-2002 11:16 PM
