Old 01-24-2013, 04:44 PM   #11351
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Warning: wheel fitment question ahead:
Originally Posted by Psychoreo View Post
year: 2004
model: WRX wagon
wheel model: R1
wheel size/offset: 18x8 / +40
tire brand/model: Federal 595
tire size: 215/40/18
suspension: Epic Springs/GR-2's
alignment: Factory spec
fender mods: Sedan fronts, rolled rears
spacers: yes/no? size? no
Should it fit?
Psychoreo is offline   Reply With Quote
Old 01-24-2013, 04:59 PM   #11352
SG02WRX
Member#: 151814
I think you should post in this thread, and someone will reply shortly.
http://forums.nasioc.com/forums/show....php?t=2208775
SG02WRX is offline   Reply With Quote
Old 01-24-2013, 05:29 PM   #11353
Psychoreo
Member#: 79643
2015 WRX STI
I did. My quote is from that thread.
Old 01-24-2013, 05:57 PM   #11354
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
The offset may push it a little close to the rear fenders, but you shouldn't have a problem.
flat4LGT is offline   Reply With Quote
Old 01-24-2013, 06:00 PM   #11355
leach0789
Member#: 210903
2013 MS3/Turbo Miata
Nitrous Rhodes
You'll probably be okay with 215s. I'm going to run 17x8 +48 with a 235/45/17, but will be rolling my fenders.
leach0789 is offline   Reply With Quote
Old 01-24-2013, 06:01 PM   #11356
Psychoreo
Member#: 79643
2015 WRX STI
I had the wheels on with 205/45's (I think) and there was no issue. I just know the federals run wide
Old 01-24-2013, 06:40 PM   #11357
dave_88
Member#: 65864
WRX gone; hate the
Honda forums so much.
you'll be fine; especially with a 215 wide, if anything, you'd need to roll the rear fenders completely flat.
dave_88 is offline   Reply With Quote
Old 01-24-2013, 08:33 PM   #11358
crxgator
Member#: 39017
2000 Audi S4, 323iT
definitely fine since the rears are already rolled.
i had 245/40 on my 17x8 + 42 on my old wagon.
crxgator is offline   Reply With Quote
Old 01-24-2013, 11:35 PM   #11359
jimbosv650
Member#: 261307
04 wrx wagon
I'm at 215/40 on an 8.5" +35 wheel, and Eibach prokit. Rear fenders used to cut the tire a bit on bumps. Rolled them flat and I've never had a problem since.
jimbosv650 is offline   Reply With Quote
Old 01-25-2013, 01:17 AM   #11360
Scotty Dosent Know
Member#: 252642
2006 WRX Wagon
My wife was running 17X9 +44 with a 245 on her wagon. Rear fender lip rolled flat, stock front fenders.
Scotty Dosent Know is offline   Reply With Quote
Old 01-25-2013, 09:36 AM   #11361
Eppo
Member#: 102436
2003 WRX
Nice wagon
Eppo is offline   Reply With Quote
Old 01-25-2013, 09:39 AM   #11362
kirshnerd
Member#: 310645
No problems with rubbing the suspension? I'm about to set up 17x9 +43 and I was warned I'd need spacers to avoid my coils.
kirshnerd is offline   Reply With Quote
Old 01-25-2013, 11:17 AM   #11363
Scotty Dosent Know
Member#: 252642
2006 WRX Wagon
No problems rubbing the suspension. The car was on ST Coilovers which are smaller in diameter than stock suspension so with drop springs and a shock probably would not work.
Car did rub sometimes on big bumps but I attribute that to the ST suspension being really soft, my wife wanting the car really low (That picture is raised up from where she wanted it and still low IMO) and fenders not really rolled. Fronts were un touched and rears were rolled semi flat no pull what so ever.
Rolled fenders, slightly stiffer suspension or a little more ride height and it would have been fine.
What wheels are you running that are 17X9 +43? Her Works were +44 and I think Rota offers some 17X9 in a +42?
Old 01-25-2013, 11:23 AM   #11364
kirshnerd
Member#: 310645
Xxr 522's. Hopefully picking them up next weekend.
I'll be running the car as low as I can that's still dd-able. Fortune 500's with camber plates front and rear. No crazy camber is the goal. The rears are already rolled to about 50degrees (from flat) but I might just re roll them flat to be safe.
Old 01-25-2013, 12:08 PM   #11365
Scotty Dosent Know
Member#: 252642
2006 WRX Wagon
These 2 wagons are what made me go 17X9 with a 245. Black wagon was local to me and was a DD on Tein SS coilovers. Blue one was setup by wheel dude....not sure of suspension but there is a whole thread about it.
http://forums.nasioc.com/forums/show....php?t=1714612
This guy is also put on Work CR Kai 17x9 around same time I did
http://forums.nasioc.com/forums/show...7&postcount=64
Hope that helps, dont think you will need spacers. Fenders are rolled pretty good on the silver wagon which probably goes a long way to running minimal camber.
Hope the owners dont mind me posting these
Old 01-25-2013, 12:19 PM   #11366
03boxer4
Member#: 66622
2002 WRB wrx - Sold
Big White Jeep Unlimited
this looks like unibomber or ferg, cant remember who has it.
03boxer4 is offline   Reply With Quote
Old 01-25-2013, 02:01 PM   #11367
kirshnerd
Member#: 310645
Great info! I've been researching and collecting specs for a while. I think I should be fine without spacers, but I plan on going a little lower than you so I'm thinking 235's instead a of 245's for a touch of stretch. Def gonna re-roll and make it flat in the rear. Maybe even a very slight pull to play it safe.
Old 01-25-2013, 02:40 PM   #11368
Shanaru242
Member#: 344828
2007 Outback Wagon
New here.
My wagon:
Shanaru242 is offline   Reply With Quote
Old 01-25-2013, 02:53 PM   #11369
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
New shoes...18x8.5 55 245/40/18, no spacers and clears Brembos.
Fierysun is offline   Reply With Quote
Old 01-25-2013, 04:00 PM   #11370
03boxer4
Member#: 66622
2002 WRB wrx - Sold
STI wheels?
Old 01-25-2013, 04:03 PM   #11371
Fierysun
Member#: 82745
2005 Subaru STI
Originally Posted by 03boxer4 View Post
STI wheels?
Yes, 2011 STI wheels.
Old 01-25-2013, 06:01 PM   #11372
brent_chastang
Member#: 200670
02 wrx wagon
brent_chastang is offline   Reply With Quote
Old 01-25-2013, 07:08 PM   #11373
dave_88
Member#: 65864
WRX gone; hate the
oh man, those brakes.
to stick with the wheel theme of this page, specs on wheels/suspension(camber?)?
Old 01-25-2013, 07:40 PM   #11374
jpm115
Member#: 328360
2003 VF34'd WRX
jpm115 is offline   Reply With Quote
Old 01-25-2013, 07:54 PM   #11375
mac1124
Member#: 286146
2003 2.5 TS Wagon
Blue Ridge Pearl
The '11 STi wheels look great on a bugeye!
mac1124 is offline   Reply With Quote
Calling All Wagons wagonmasta General Community 133 07-10-2014 06:13 PM
Calling all wagons -whos running 18's quickgtp Tire & Wheel 19 04-01-2013 01:23 PM
Calling All Wagons girl Member's Car Gallery 29947 05-20-2010 11:44 AM
calling all wagons subineer Brakes, Steering & Suspension 11 09-28-2002 01:23 AM
