Closed Thread
Old 03-06-2013, 07:28 PM   #35201
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Nice! Hoping to run into you at some IAG/Mach V events this year :P
Smurftastic is online now
Old 03-06-2013, 07:29 PM   #35202
RALLYT-WRX
Member#: 9369
F#ck U & Your Stance
BLOD
Originally Posted by AutoPrue View Post
So i think I have another front seat lined up but sadly not a prodrive. Also might be getting a set of Takatas.
Nice. Takata's are next on my list. I want another seat of seats as well but sadly I'm too fat for anything JDM. Lol So I will have to stick to my Corbeau's.
RALLYT-WRX is offline
Old 03-06-2013, 07:30 PM   #35203
RALLYT-WRX
Member#: 9369
BLOD
And I hope to be at some of those meets. After its tuned I hope to drive my car more often.
Old 03-06-2013, 07:40 PM   #35204
AutoPrue
Member#: 115459
2002 WRX Sedan
Atomic Orange
I wish i was closer that way Ive bought so much stuff from mach v over the years.
AutoPrue is offline
Old 03-06-2013, 08:14 PM   #35205
DaveyPetey
Member#: 239944
2002 WRX Sedan
Originally Posted by brett192 View Post
Maybe if you were using a JDM scoop with the stock splitter, the turbulence from the air hitting the misplaced splitter (only being 1/2 way up in the scoop) might make for less airflow. I think I remember someone mentioning this before.
I have a JDM scoop with stock splitter and IC, haven't modified the splitter at all but when I go for a spirited drive and feel the IC, it's cold to the touch. Then again I am in Canada and it's winter.
Hmmmm. I don't see how the taller splitter could cause any sort of effective turbulence as they sit in the same plane vertically. What I really want to know is if the lower scoop actually feeds more air into the splitter, or of it's really just the splitter that does the vast majority of the air direction. What I really need is a picture of a bug with a splitter with no scoop on.
DaveyPetey is offline
Old 03-06-2013, 08:20 PM   #35206
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
I was referring to the stock wrx splitter only extending like half way up into the JDM scoop. Incoming air will become turbulent because it's getting trapped in the gap between splitter and scoop, I believe the turbulence may decrease the actual airflow through the intercooler.
Sorry, kind of hard to explain. But here's the gap I am talking about:
The process west splitter doesn't look like it extends as high as the stock one, so maybe it relies more on the actual scoop to direct air? Maybe I'm completely wrong here.
brett192 is offline
Old 03-06-2013, 08:37 PM   #35207
Smurftastic
Member#: 243697
02 | BLOD Founding
I will trade you a Mach V meet for a Wicked Big Meet lol...
Old 03-06-2013, 08:54 PM   #35208
AutoPrue
Member#: 115459
2002 WRX Sedan
Atomic Orange
Lol that might work when does mach v hold them?
AutoPrue is offline
Old 03-06-2013, 09:22 PM   #35209
ehawthorne521
Member#: 149686
2002 My name is Evan
and I am an Autoholic
Sorry to just jump in out of nowhere, thought I'd throw in my two cents. I believe the idea of the splitter is to direct the air over the intercooler more evenly and also prevent it from going over the top of the TMIC. The reason for the taller splitter in the JDM scoop is to direct the air more evenly over a larger TMIC I think. I also think the JDM splitter has a larger opening over the intercooler. The process west would probably be similar as its made for their larger intercooler.
I have a Zero/Sports splitter for the JDM scoop which uses the scoop and the splitter itself to direct air.
Here are some pics, I hope some of this helps
You can see only two splitter fins on this except there are three openings, it allows for a larger opening over the intercooler.
This you can see how the splitter uses the scoop to direct air along with the splitter.
ehawthorne521 is offline
Old 03-06-2013, 10:39 PM   #35210
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
I think I gotta unsubscribe to this thread because all you guys make me want to buy more parts for my car when I should be doing maintenance or paying bills.
WRX_02_227 is offline
Old 03-06-2013, 10:59 PM   #35211
NOTanEVO
Member#: 210790
Originally Posted by coqui2004miguel View Post
Still have things to finish up but here she is so far with the front lip in black.
Tire specs anyone?
NOTanEVO is offline
Old 03-06-2013, 11:14 PM   #35212
ScoobySubyDoo
Member#: 329311
2003 WRX
Satin Black
265/45?
ScoobySubyDoo is offline
Old 03-06-2013, 11:20 PM   #35213
con10der8
Member#: 165107
2003 wrx ;)
black/BLUE
con10der8 is offline
Old 03-06-2013, 11:53 PM   #35214
Smurftastic
Member#: 243697
02 | BLOD Founding
Epic.
Old 03-07-2013, 01:04 AM   #35215
wrxspeed56
Member#: 207065
2002 wrx
instagram @wrxspeed56
Con10der8 killing it as usual get rt5 s and match me
wrxspeed56 is offline
Old 03-07-2013, 01:12 AM   #35216
yetogetanrs2
Member#: 153106
Originally Posted by scoobywagon02 View Post
Long way from home, but this looked like a pretty good spot for a picture.
YO WHAT You doing driving in my back yard.
that's funny. I live about 15 min from there.
yetogetanrs2 is offline
Old 03-07-2013, 01:14 AM   #35217
burgerwhat
Member#: 217135
2003 Impreza WRX
Midnight Black Pearl
Lovely.
burgerwhat is offline
Old 03-07-2013, 01:18 AM   #35218
CalvinT
Member#: 329025
2002 WRX Wagon
I have the PW TMIC and splitter. I also have the JDM STI scoop and splitter.
The PW splitter is for the stock USDM scoop, not the JDM scoop. Kevin at PW says to use the JDM STI splitter if you have the JDM STI scoop. The JDM splitter doesn't completely cover the PW intercooler, but it's close.
I figure I'll go with what Kevin says. Flatiron has the JDM scoop, splitter and gasket. Rallispec imports all three and has a few other splitters.
The PW splitter has holes for three spray nozzles. the JDM kit with gasket has one hole. The splitter is aluminum. There's also a JDM STI splitter that has two holes, it's made of steel.
CalvinT is offline
Old 03-07-2013, 01:20 AM   #35219
Flat Face
Member#: 275220
2000 Bugeye
Blue Ridge Pearl
Originally Posted by silverF4turbo View Post
Still*amazing to see that car can pull all those miles! Subarus = industrial strength build quality
my battery's dead so I can't get a pic of my KM's but I'm at 380000+
Flat Face is offline
Old 03-07-2013, 07:50 AM   #35220
freeride2.5
Member#: 79582
2000 Flared RSTI
Sedona Red Pearl
Winter is fun!
freeride2.5 is offline
Old 03-07-2013, 10:22 AM   #35221
scoobywagon02
Member#: 317757
2002 Impreza 2.5TS
Savanna Green
Vacation lol, been going to Florida for ages, but I've never actually driven over it, just seen it from a distance. So I figured, hey that fishing pier/bridge looks like a good location for a photo op.
scoobywagon02 is offline
Old 03-07-2013, 11:28 AM   #35222
2002Dubx
Member#: 177337
1 Dirty Old
Bugeye and an Xterra
So what you're saying is we are neighbors... Suby meets at 49th st QSL on Thursday nights bish. Get on it.
2002Dubx is offline
Old 03-07-2013, 11:29 AM   #35223
2002Dubx
Member#: 177337
1 Dirty Old
Congrats Smurf on Top Scoob!!!
2002Dubx is offline
Old 03-07-2013, 11:36 AM   #35224
Smurftastic
Member#: 243697
02 | BLOD Founding
Thanks man Glad to be able to hold it down for you guys but could never have done it without help from the Bugeye friends I've made over the last few years.
Changes are coming... trying to do a few things before Summer hits.
Old 03-07-2013, 11:52 AM   #35225
WRXTacy419
Member#: 57345
2006 Evo9 Impreza2.5
Originally Posted by awdbrian View Post
Hey everyone i haven't been on here in a while so i figured i post a few photo's
This is legit, the best looking bugeye I've ever seen, props for a clean ride!
WRXTacy419 is offline
Closed Thread
the Bugeye thread 5spdfrk Member's Car Gallery 18633 05-20-2010 12:18 PM
Where's the bugeye lip thread?! yankdanger Interior & Exterior Modification 0 04-06-2009 09:43 PM
