Closed Thread
Old 07-12-2013, 07:36 PM   #42301
1breel
Member#: 189314
2002 GGSTi
01G
redline.it but the link doesn't work anymore. there use to be a lot of info
1breel is offline
Old 07-12-2013, 08:32 PM   #42302
07imprezRS
Member#: 164302
2011 STi Ltd Sedan
DGM & 02 WRB WRX
Originally Posted by AutoPrue View Post
I lovr the look of the black mirrors on the s202 out of all the things ypu could dislike on a stripped down performance oriented bug.
Black mirrors > pee pee fogs lol
I guess I'm just being picky but for the amount of money one spends on an STi or "S" series car in japan the least they can do is have paint matched parts like mirrors and or side skirts if applicable since the s202 didn't come with side skirts. It really doesn't add much weight. I suppose we all have our own opinions.
07imprezRS is offline
Old 07-12-2013, 08:53 PM   #42303
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
Originally Posted by 1breel View Post
all the ones I saw already LOL thanks for googling that for me.
I want variable type. I found a few that are in production still... just hoping for a cheaper alternative and something that looks nice too LOL
iNfEk is offline
Old 07-12-2013, 10:59 PM   #42304
lino129
Member#: 251820
Rally Blue
So, guys, other than my coolant leak which I have yet to track down. Whilst driving my car today I noticed a very high pitched whine coming from basically right in front of me. And this one I KNOW what it is, it's the right side bolt of my BPV. I know the hole is mostly stripped but i can get some threads to catch but not very much, basically to the point that it holds on but doesn't HOLD if that makes sense, I could just keep turning it all day long. I even went out and bought longer bolts, still no dice.
So what are my options? Try to get another even longer bolt? Try and re-tap the threads in the hole? Or am I f***d and might as well buy a new TMIC and turn the APS piece into some kind of art like the TD04 sitting on the floor next to me awaiting me turning it into a lamp?
lino129 is online now
Old 07-12-2013, 11:05 PM   #42305
blubug_768
Member#: 324962
02 WRX
does anyone know where to get an s7 wrc style spoiler, or who makes one?
blubug_768 is offline
Old 07-12-2013, 11:09 PM   #42306
RedRexOttawa
Member#: 250455
SRP Stage 2
I really like this shot
RedRexOttawa is offline
Old 07-12-2013, 11:11 PM   #42307
projectQWKSLVR
Member#: 285270
03 WRX
Heli-coil should do it.
projectQWKSLVR is offline
Old 07-12-2013, 11:26 PM   #42308
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
High pitched noise usually is exhaust leak when you boost. More so from the up pipe. I'd try to thread it again if you can. If not you'll need to go bigger on one side. Be careful since you can **** **** up more here. APS piece? What're you talking about. The BOV?
You need to fix one thin at a time. Leaking fluids are more important than a sound. Start with one thing and STOP jumping around!
iNfEk is offline
Old 07-12-2013, 11:58 PM   #42309
lino129
Member#: 251820
Rally Blue
I will look into that. Thanks man.
Well I would hope its not an exhaust leak, Its a brand new TBE, of course that doesn't mean anything either I could have effd something up there, But I don't think so. The sound is literally right in front of me when I'm driving, looked up a couple youtube vids of the same EXACT sound, and they all say the fix they found was a loose bolt, and I KNOW I have a loose bolt. So I'm almost 100% sure that's that problem.
The "APS piece" I mention is the TMIC itself. I'm not trying to sound like I'm jumping around I know it seems that way. I KNOW the leaking fluids is more important than a tiny vac leak. I took off the coolant reservoir to turbo hose today, its pretty chewed up on the inside. And left some rubber gunk on the reservoir nipple when I took it off. Tomorrow I will take off the turbo line and see if its clogged up. Which wouldn't really explain the leak, but would probably explain the boiling coolant feeling I got after I drove it around the block today.
I'll stop clogging up the thread with my words now. Apologies.
Old 07-13-2013, 12:03 AM   #42310
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Turbos get hot. I hear my fluid boil sometimes on a hard run. Just don't lose sight of what's important and get the car running right and don't call it quits.
iNfEk is offline
Old 07-13-2013, 01:55 AM   #42311
hotpapaya
Member#: 339092
Snapped a picture this morning before I headed to work.
Greetings from Canada
hotpapaya is offline
Old 07-13-2013, 03:37 AM   #42312
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
just got this hood today, tried to gloss wrap it and fail stupid hard -______-
need to pick up my v1 lip and paint this mama!!!!
bbun is offline
Old 07-13-2013, 04:22 AM   #42313
KGwrx
Member#: 268868
good stuff bun^ where are you getting the paint done at?
KGwrx is offline
Old 07-13-2013, 04:26 AM   #42314
Silver Sedan
Member#: 259220
2005 RWD STi
Silver Sedan is offline
Old 07-13-2013, 06:44 AM   #42315
1breel
Member#: 189314
2002 GGSTi
01G
I even went through the other two previous laptops to see if I saved anything on them and came up empty handed. Sucks because there use to be a bunch of cool little DIY's on that site.
1breel is offline
Old 07-13-2013, 07:00 AM   #42316
1breel
Member#: 189314
2002 GGSTi
01G
buy the complete heli-coil kit for the OEM bolt size. it will have the drill-bit, tap, heli-coil and tool. use thread locker to install. Pull the IC off to tap. hold the IC bolt hole down and blow out after tapping. This way you get any trash out being that shavings aren't conducive to longevity. Use a new gasket and use the proper torque on the bolts.
1breel is offline
Old 07-13-2013, 07:04 AM   #42317
1breel
Member#: 189314
2002 GGSTi
01G
He can't help it, he bought a cluster****. I on the other hand created mine
1breel is offline
Old 07-13-2013, 08:02 AM   #42318
RJSMITH
Member#: 347474
2002 wrx,01 L coupe
mbp,sr
wrcspares sells em among others depends wether u want carbon or fiberglass. be prepared to fork over some money for one they aint cheap
because bugeye thread heres some phone pics I need to get a real cam
soon to have this bad boy on her
RJSMITH is offline
Old 07-13-2013, 09:29 AM   #42319
SubieYourSelf203
Member#: 324083
2002 WRX Wagon
Man, that car is clean... I personally would leave the front end just the way it is. Maybe just a front lip to set it off... Very nice though
SubieYourSelf203 is offline
Old 07-13-2013, 09:38 AM   #42320
AutoPrue
Member#: 115459
2002 WRX Sedan
Atomic Orange
You dont want one.
AutoPrue is online now
Old 07-13-2013, 11:10 AM   #42321
silverF4turbo
Member#: 20492
4 -valve Derper
Let's JDM styling!
There's some possibility it won't be a direct fit if that's a genuine S7 bumper (don't know for sure but I know the s7 grill/hood lines where the two meet are a little different from production model). But PLEASE make it work/modify to get that to fit. Incredibly badass part that will look amazing
silverF4turbo is offline
Old 07-13-2013, 11:48 AM   #42322
RJSMITH
Member#: 347474
2002 wrx,01 L coupe
mbp,sr
burn up have these also with bellof hids
thanks for the comments its really kind of a beater rotted qtrs. an rust on roof dents an dings an my driver doors wadded but I love her with her flaws
RJSMITH is offline
Old 07-13-2013, 02:24 PM   #42323
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
=\ oh well. They still make the knock link in a newer version might look into that. The price tag though is kinda high just for a light. We will see
iNfEk is offline
Old 07-13-2013, 05:53 PM   #42324
DreamEvil
Member#: 186435
2005 STI
New gauges
DreamEvil is offline
Old 07-13-2013, 06:19 PM   #42325
Tsujen
Member#: 269643
15 WRX Limited
You testing them out while driving to get gas? lol they look good!
Tsujen is offline
Closed Thread
the Bugeye thread 5spdfrk Member's Car Gallery 18633 05-20-2010 12:18 PM
Where's the bugeye lip thread?! yankdanger Interior & Exterior Modification 0 04-06-2009 09:43 PM
