Closed Thread
Old 04-25-2011, 10:01 AM   #9126
Twrexx2
Member#: 250077
2003 Stage2 bug
96 L Stage rally prepped
^^damn thats bright. I likes it
Twrexx2 is offline
Old 04-25-2011, 10:01 AM   #9127
lowrider89
Member#: 143022
2005 modded S4
quadsbc, Just need to state that I love your car
lowrider89 is offline
Old 04-25-2011, 10:17 AM   #9128
Quadsbc
Member#: 170415
2002 Hardware store
bumper clips, that is all
I hope you are refering to the s2k retroed pic and not the blinding garage light.
Thanks! I guess you can really tell it started as a normal bugeye then turned into a monster.
Quadsbc is offline
Old 04-25-2011, 10:42 AM   #9129
Pencils
Member#: 152726
The 2003 pwrFAP
thing
Originally Posted by iNfEk View Post
exactly... Fortunately we are the few that like to be a little different sometimes LOL. I'm still debating
Do it already!
I'm starting to run out of ideas to be different
Pencils is offline
Old 04-25-2011, 11:58 AM   #9130
STI_KLR
Member#: 189660
'02 WRX
Element Tuning Race Team
Well, this is the result with just forcing the bumper on that last 1/2" or so. The back of the bumper where the gap is showing is ziptied on. Tried to get it as close as possible, but that's as far as it was willing to go.
Maybe when I have more motivation this weekend I'll take it all back apart and see what's what. But for now it'll do so I can continue with some testing to make sure all it as it should be.
STI_KLR is offline
Old 04-25-2011, 12:04 PM   #9131
barnburner
Member#: 220484
2003 PSM WRX - Sold
2006 Pink STi
^ just run bolts on the inside or clips on the outside to draw them together.
Quads, didn't you have clips?
Someone in this thread had clips.
some searching should yield helpful results.
barnburner is offline
Old 04-25-2011, 12:09 PM   #9132
STI_KLR
Member#: 189660
'02 WRX
I thought about doing the quick release clamps on the sides to bring them together, but that depends It'll do for now. Just happy to drive her again! Only < 3 weeks till the tune.
STI_KLR is offline
Old 04-25-2011, 12:25 PM   #9133
barnburner
Member#: 220484
2003 PSM WRX - Sold
2006 Pink STi
Bolts as a quick fix then! (can't see em)
As long as not a lot of force is required to close it...
However, If you need to use a lot of force to close the gap I would do more trimming. You might get dimples/flexing or other weird stuff going on with those clamps in that case.
Old 04-25-2011, 12:40 PM   #9134
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Originally Posted by Quadsbc View Post
So you haven't seen the fog light output by themself? Yes they are called Fog lights however the light pattern is very flat and wide. They do not scatter light everywhere like aftermarket fog kits do. There are 4 bolts on your fog lights, 3 are mounting points and the other is an adjustment screw. You can adjust your beam up and down.
I know I run the fogs all the time. Good and bad weather. The extra light is really nice at night. I use some 55w yellow fog bulbs. They are bright and do not reflect as much as a white bulb.
Fogs are much wider than driving lights. I think that's why they make feel like they have a good cutoff.
You can see an apparent cutoff with the fogs, but you still have plenty of light going upwards. You can clearly see that by turning them on and looking at road signs, threes etc. there is a small amount of light added light everywhere, not just in the lower wide band where the light is actually intended to go.
Not a big deal with the bubls the foglights are made to handle because they don't produce enough light to be significantly blinding. But if you 3x the light output of course you end up with huge amnount of light in that same upper area.
Fred
frederik is offline
Old 04-25-2011, 12:44 PM   #9135
PBGuts
Member#: 280784
I want a bugeye so bad!
PBGuts is offline
Old 04-25-2011, 12:57 PM   #9136
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
it's like less then a 10 dollar mod at Home Depot/Lowes just look for the draw hasp latches, another benefit for having quick release is when you blow a piping off it's 10x easier to get the bumper off
blakkboxer is offline
Old 04-25-2011, 01:15 PM   #9137
Pencils
Member#: 152726
The 2003 pwrFAP
thing
thinking about doing some sort of latching so i can quickly remove my bumper so i can get into my driveway with my new diffuser
Pencils is offline
Old 04-25-2011, 01:30 PM   #9138
frederik
Member#: 64405
2003 WRX Sedan
WRB - Cobb Stg 2
Haha yeah, I was wondering why he put those latches on, but it makes perfect sense now now that you say it. I think that is Yanos car.
edit: forgot to remove the pic from the quote!
frederik is offline
Old 04-25-2011, 01:30 PM   #9139
iNfEk
Member#: 21339
Chapter/Region: HIIC
2002 LHD STI V7 6MT
[email protected] EJ205 4EAT
Lol so you guys lovin or hatin hehehe
iNfEk is offline
Old 04-25-2011, 01:34 PM   #9140
kscasper13
Member#: 143711
2002 2.5, 6 speed
APS Bugeye
this is the same problem i was having, it was touching at the bottom of my APS, and wouldn't secure on the sides by the wheel-wells. i would cut it back more here where it's touching, and it should mount fine.
kscasper13 is offline
Old 04-25-2011, 01:39 PM   #9141
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
You'll need to either mark that area and take down that part or progressively cut small amounts of the bumper then test for a perfect fit
iNfEk is offline
Old 04-25-2011, 01:41 PM   #9142
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
I can already tell that its the pipes that are the problem not the front or any trimming. The front bottom pipes are hitting the inside of the bumper at the lowest spot where there is that small opening. Look there. Like i said before, I just did this with the exact same intercooler and this was the problem. The bottom driver side pipe was the problem. It stuck out too far and hit the bumper. It looks like the driver side fender to bumper gap is worse and thats where i had to cut the pipe.
crpwrx is offline
Old 04-25-2011, 01:43 PM   #9143
con10der8
Member#: 165107
2003 wrx ;)
black/BLUE
con10der8 is offline
Old 04-25-2011, 01:57 PM   #9144
barnburner
Member#: 220484
2003 PSM WRX - Sold
2006 Pink STi
^rad.
nice balance of both form and function.
makes me want to put my rack/trays back on.
Old 04-25-2011, 03:04 PM   #9145
JohnnyWas
Member#: 91010
2002 Subaru WRX
OG Blueberry
can't wait to get a nice roof rack for bike trips this summer - that photo rules
JohnnyWas is offline
Old 04-25-2011, 03:07 PM   #9146
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
will banging it with a hammer help?
Old 04-25-2011, 03:14 PM   #9147
triple O-G
Member#: 224889
'02 WRX
[/IMG]
triple O-G is offline
Old 04-25-2011, 03:27 PM   #9148
DumbstixLars
Member#: 205942
2003 WRX
2007 2.5i Wagon
Went on a cruise with some local guys Saturday. They took a ton of pics, I was the only bugeye out of 12 cars.
I found out real quick I want better brakes and need better tires.
DumbstixLars is offline
Old 04-25-2011, 04:15 PM   #9149
ZIP23
Member#: 67003
2015 WRX
nothing fancy just wanted to post my car
ZIP23 is offline
Old 04-25-2011, 04:29 PM   #9150
iNfEk
Member#: 21339
2002 LHD STI V7 6MT
Originally Posted by Pencils View Post
Do it already!
Exactly what am I doing is the problem LOL.. I may go back to black but as I've stated... it'll be a gloss black or similar. I got lots of ideas how to be different but I lack the funds to make it happen sometimes LOL. I'd love to have chameleon wheels like you but don't want them to be damaged by brake dust and harsh/not so harsh chemicals when I clean them.
iNfEk is offline
Closed Thread
the Bugeye thread 5spdfrk Member's Car Gallery 18633 05-20-2010 12:18 PM
Where's the bugeye lip thread?! yankdanger Interior & Exterior Modification 0 04-06-2009 09:43 PM
