Closed Thread
Old 12-01-2011, 01:59 AM   #17126
Murat
Member#: 251074
lmao
That's a good one Erik
Murat is offline
Old 12-01-2011, 02:15 AM   #17127
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
Originally Posted by Lacrosse View Post
I saw it and hit the brakes which sent me into a slide. I pointed the car away from the cat and when I tried to correct basically nothing happened because I was in a total uncontrolled slide. That's why my wheel hit the curb at an angle instead of straight on, because I was trying to counter steer out of the slide.
It was a pretty ****ty situation. Lucky there wasn't a car comming the other way...
So how much damage did that cat...errr i mean curb end up causing for you?
Jackie leggs is offline
Old 12-01-2011, 03:43 AM   #17128
nyorciari
Member#: 194853
2002 Bugeye -Sunroof
MBP (SQC#289)
Oops.
nyorciari is offline
Old 12-01-2011, 03:47 AM   #17129
aeion
Member#: 182114
1996 Nissan HARDbody
1931 Ford Model A
Can we see unedited shots of that car please? The blurriness hurts to look at
aeion is offline
Old 12-01-2011, 07:51 AM   #17130
FastAdams
Member#: 280714
1998 Look below.
98 rs 99 forester
Originally Posted by barnburner
^correct.
Chatter when down shifting and completely off of throttle.
Even the slightest touch of the throttle makes it stop.
I have the same issue. And when I start off in first if I don't have high enough rpm it will violently shake the entire car
FastAdams is offline
Old 12-01-2011, 08:20 AM   #17131
Quadsbc
Member#: 170415
2002 Hardware store
bumper clips, that is all
Abs fail
Quadsbc is offline
Old 12-01-2011, 08:27 AM   #17132
Lacrosse
Member#: 263633
1999 FRC
Originally Posted by Quadsbc
Abs fail
Yeah, I'm more of a triceps guy to be honest.
Lacrosse is offline
Old 12-01-2011, 08:51 AM   #17133
ibrake4ducks
Member#: 255281
2002 WRX v7 STi Swap
WRB - STi Mikey Tuned
damn man thats rough, a similar thing happened to me last winter except the wheel didn't fold in like that on my car it just caused some other issues that weren't obvious at first and progressively got worse over time.
ibrake4ducks is offline
Old 12-01-2011, 09:37 AM   #17134
NOTanEVO
Member#: 210790
ayo calv, think his username should be iswerve4cats!
NOTanEVO is offline
Old 12-01-2011, 11:31 AM   #17135
Pencils
Member#: 152726
The 2003 pwrFAP
thing
i dont think i posted this picture here
Pencils is offline
Old 12-01-2011, 01:32 PM   #17136
aeion
Member#: 182114
1931 Ford Model A
Looks awesome pencils!
aeion is offline
Old 12-01-2011, 01:34 PM   #17137
Pencils
Member#: 152726
The 2003 pwrFAP
thing
i think i'm gonna order the replica JUN bumper soon. the paint on my front bumper is cracking very bad now. poor paint job from the previous owner.
Pencils is offline
Old 12-01-2011, 01:45 PM   #17138
aeion
Member#: 182114
1931 Ford Model A
I think.....you should
aeion is offline
Old 12-01-2011, 01:48 PM   #17139
JON-E25WRX
Member#: 225389
03 WRX MBPwidebody
rotated 35R VOLTEX bugeye
that'd look way good
JON-E25WRX is offline
Old 12-01-2011, 02:00 PM   #17140
SubaruDemon
Member#: 97460
Originally Posted by SimonTuffGuy View Post
Searched back on some of your posts, but didn't see anything there... Specs on those wheels/tires? Those would look awesome on my Wagon.
They are XXR 522 18x8.5 +48 on Falken Ziex 512 225/40/18. The wheels would sit flush on your wagons narrow body. It will definitely look good!
Originally Posted by Subieeeeeeee View Post
correct, i have a lightweight aluminum flywheel. why?
The whirring sound is from the lightened fly wheel. "The engine acclerates slightly at every cylinder firing. The heavier the flywheel, the more this is damped out. THe vibration gets into the gear/bearing/thrustplate lash in the tranny and any loose stuff in the pressure plate, and makes the noise."
SubaruDemon is offline
Old 12-01-2011, 02:33 PM   #17141
Subieeeeeeee
Member#: 294820
2002 Bugeyeeeeeeeeee
WRB <3
that makes sense, thanks for explaining
Subieeeeeeee is offline
Old 12-01-2011, 02:40 PM   #17142
03sleeperwrx
Member#: 297660
i was told when i had my tranny worked on not to put a lighter flywheel on cause the subaru transmission is based on the durability of the flywheel and and it being able to hold the power
03sleeperwrx is offline
Old 12-01-2011, 02:58 PM   #17143
morph1n3
Member#: 149742
2002 gears go
weeeeeeeeeeeeeeeeeeee
Originally Posted by blakkboxer View Post
i wish son!!
my reverse is teh only ppg gear jk
morph1n3 is offline
Old 12-01-2011, 03:00 PM   #17144
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
By who?
Byzantium is offline
Old 12-01-2011, 03:31 PM   #17145
caesar
Member#: 30745
SRP Greddy(R.I.P)
Bugeye & '99 LandRover D2
Luv it........
caesar is offline
Old 12-01-2011, 03:38 PM   #17146
akfmx
Member#: 226059
Icy Silver
Legacy
Fiberglass
akfmx is offline
Old 12-01-2011, 04:04 PM   #17147
Pencils
Member#: 152726
The 2003 pwrFAP
thing
Originally Posted by akfmx View Post
Fiberglass
the replica one is that flexible abs plastic material.
Pencils is offline
Old 12-01-2011, 04:36 PM   #17148
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Originally Posted by mikepdx View Post
I was a little hesitant, but I bought a set off of eBay for around $100 for the pair. They are an exact fit and have glass lenses, not cheap plastic ones. Even came with new bulbs! I also bought some yellow Lamin-x film, so they hopefully don't break again. They made it through a rainy Oregon fall and have not fogged a bit!
Yeah, the OEM ones from subarugenuineparts.com are kind of pricey, plus I have all the wiring already, just need new lamps. Most of the higher quality OEM replica fogs I have seen on ebay are made by Depo, what about yours?
brett192 is offline
Old 12-01-2011, 04:59 PM   #17149
Silver Sedan
Member#: 259220
2005 RWD STi
Silver Sedan is offline
Old 12-01-2011, 05:01 PM   #17150
dytoni
Member#: 302644
This thread oozes awesome.
dytoni is offline
Closed Thread
the Bugeye thread 5spdfrk Member's Car Gallery 18633 05-20-2010 12:18 PM
Where's the bugeye lip thread?! yankdanger Interior & Exterior Modification 0 04-06-2009 09:43 PM
