Old 05-20-2010, 06:48 PM   #1
speedymaker
Member#: 162070
2005 VF48 wrx wagon
Default Clutch slip problems on my swap
Ok, so I have an 05 wrx engine swap into my 05 rs.....I am still using the rs transmission with the rs flywheel and a spec stage 2+ clutch/pressure plate.
I went to a td05-16g and various other mods and cannot seem to get the clutch to hold the power. I previously had an exedy oem replacement clutch but due to the upgraded turbo, I went ahead and swapped to something heavier duty. Had the flywheel resurfaced of course also. Now when I get on it the clutch continually slips. The clutch is rated to hold 390 ft lbs so where am I going wrong?
I broke in the clutch and have had the tranny out twice since the swap to figure out what the problem is but it will not hold power. Any ideas?
If you need any other information, please ask, I don't know what all would be relevant for this problem.
speedymaker is offline   Reply With Quote
can a clutch slip depending on outside temp WRrexu Transmission (AT/MT) & Driveline 70 06-29-2010 01:37 PM
What clutch to use in my swap? DegNY Transmission (AT/MT) & Driveline 4 11-20-2009 07:25 PM
clutch slipping - what are my options stil2stock Transmission (AT/MT) & Driveline 3 10-30-2007 04:18 PM
Which clutch and flywheel for my swap AllSeven Transmission (AT/MT) & Driveline 1 02-26-2004 06:43 PM
I have the terrible Cold clutch shudder problem with my 2001 RS scootr Normally Aspirated Powertrain 16 12-21-2000 11:53 PM
