Old 05-20-2010, 10:42 PM   #1
xandy14x
Member#: 231026
2002 Wrx Wagon
Default New Clutch need help!!
ok so i have a 2002 wrx wagon. i recently put a new clutch and flywheel on it. when i picked it up from the shop it was really easy to push in and let out alot sooner than before. i have driven about 300 miles on it and the pedals back to being stiff. i dont know if its just me used to the pedal now but. also every time i slow down from 2nd 3rd or 4th gear it sounds like the gears are grinding. like gear mesh. it sounds like they are vibrating together and i dont know why. i took it back and he said its normal but i dont think it is. i need some help about this thanks...
xandy14x is offline   Reply With Quote
Old 05-22-2010, 02:43 PM   #2
02 Scoob-TN
Member#: 176010
2005 WRX sdn ver8'ed
Phat-Tuned RIP Bugeye
Lightbulb Could be a few things..
My guess would be the throwout bearing may be rattling a bit or a loose downpipe mount bolt or heat sheild bolt since its happening during decel. Ive done 2 clutch jobs on my 02 and the dumb thowout bearing clips never stay on right so most people dont use em and it causes the t/o bearing to make a lil noise. As long as your clutch is engaging fine, Id roll with it. The t/o bearing may wear out a lil early. The rattle always comes back. You could try the tsk kit that replaces the flawed stock setup.
02 Scoob-TN is offline   Reply With Quote
Old 05-22-2010, 03:32 PM   #3
xandy14x
Member#: 231026
2002 Wrx Wagon
alright thank you
Need new clutch, please HELP! KnightRiderWRX Transmission (AT/MT) & Driveline 3 07-21-2009 03:04 PM
02 WRX need new clutch, need advice wRx137 Transmission (AT/MT) & Driveline 11 01-09-2007 12:51 AM
Need A New Clutch :( Help Jasin_S Transmission (AT/MT) & Driveline 11 01-04-2007 05:03 PM
time for a new clutch!! need help deciding RedSun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-03-2004 03:28 PM
working on changing 02 wrx clutch need help!!!! compton Transmission (AT/MT) & Driveline 4 10-27-2003 09:15 AM
