South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 05-21-2010, 05:09 AM   #1
Deuce Cam
Member#: 130444
'85 AE86 GTS
Default HELP! Snapped throttle body bolt :(
Well in the midst of returning my car to stock I did something really stupid.
Well am I screwed or what ? These bolts are really small. I can handle average stuff but this is out of my league. I'm hoping the manifold doesn't have to come off.
Deuce Cam is offline   Reply With Quote
Old 05-21-2010, 05:18 AM   #2
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
take a dremel with a thin cutting wheel and cut a slot into the bolt, making a flat head screw, then use a flat head screwdriver to remove it.
I would cut right through the highest part to have the most material to grab with teh screwdriver.
Don't be afraid to cut into the manifold a tiny bit, it's gonna "hurt" it.
Put some penetrating lube on it first to make it easier to come out.
Also if you have torch of some sort, maybe heat it up a little.
bobturismo is offline   Reply With Quote
Old 05-21-2010, 05:24 AM   #3
Deuce Cam
Member#: 130444
'85 AE86 GTS
Interesting idea. I hope you meant it's not going to hurt it.
What are my options if that doesn't work? I'm a little worried a screw driver might strip it because there's not much material there.
Old 05-21-2010, 05:36 AM   #4
SubeSTIle
Member#: 80736
1999 FXT White
E85 is for girls
vice grips? or you can get an easy out tomorrow and drill out the center of it
SubeSTIle is offline   Reply With Quote
Old 05-21-2010, 05:42 AM   #5
Deuce Cam
Member#: 130444
'85 AE86 GTS
Will an easy out work on something that small?
Old 05-21-2010, 05:51 AM   #6
bobturismo
Member#: 42145
6-4 jockin da bish-
Too small for vise grips.
I'm sure they sell some sort of bolt extracting kit at harbor freight.
Push comes to shove, you drill out the middle of it and it will unscreww real easy.
Yes, I meant NOT hurt it, sorry.
Old 05-21-2010, 11:33 PM   #7
Deuce Cam
Member#: 130444
'85 AE86 GTS
I am one lucky mother****er! Last night I shot the stud with PB blaster just once in anticipation for the eventual attempt to remove this.
I was just discussing the issue with my mechanic friend over the phone and for some reason I felt compelled to try loosening it by hand, it came right out . The Pb really helped because when I initially tried with some pliers yesterday it wouldn't budge.
Help identifying throttle body gasket gling Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-14-2008 10:53 AM
help throttle body bolt stuck... just spinning?? ej25_TS Normally Aspirated Powertrain 8 08-25-2007 01:53 PM
help removing throttle body bolt higgins14 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-22-2007 10:04 PM
need help asap!!!...throttle body? autocannon05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-19-2007 02:35 PM
Throttle body bolt PARANOID56 General Community 3 08-20-2003 05:48 PM
