Old 06-10-2002, 01:38 AM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Exclamation For those that don't have a stock FPR, what did you put in its place??
I'm trying to figure out how to put something where the stock Fuel pressure regulator went. for those that have got rid of it, what did you put there? is there a way to hollow the FPR out or something? please let me know. I need to know by tomorrow (Monday!) Thanks
Eric
Eric SS is online now   Reply With Quote
Old 06-10-2002, 10:07 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Yeah, you could hollow the stock FPR, though I'm not sure how well it'd perform with the diaphragm removed or something. I would just machine a piece to fit in there, if you have access to something like that. Or get a tube that fits in there, put an o-ring or two on it, then make a plate that fit over the tube and screwed to the FPR mount on the rail, and weld them together appropriately.
Forgot : Weapon-R supposedly has a piece that you can put in place of the stock FPR to put their FPR on... no idea if you can buy it seperately or not though.
Old 06-10-2002, 10:58 AM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Using the Vishnu Supplied FPR (comes with fuel rails)...
kastle is offline   Reply With Quote
Old 06-10-2002, 10:59 AM   #4
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Also, you can use the SVX FPR... many people have done that while using a RRPFR.
Old 06-10-2002, 11:12 AM   #5
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Mazda 626.
Jon Bogert is offline   Reply With Quote
Old 06-10-2002, 11:16 AM   #6
Delicious Tuning
Member#: 1990
Cool
Aeromotive has one which can be bought online at Summit Racing...
Part Number #, AEI-13109
If you are looking for the adaptor to the fuel rail, pm me. Working on getting them.
Also if you are running the Link Plus you do not need to change the stock FPR. Though the only drawback of it is that you may not be able to flow enough fuel through it, at higher flow rates, once you get bigger injectors, but I am not sure how that works. I am pretty sure the Aeromotive will run fine at any level.
Delicious Tuning is offline   Reply With Quote
Old 06-10-2002, 02:08 PM   #7
adamsrs
Member#: 3768
So is it bad to run an adjustable SARD FPR without the stock FPR?
adamsrs
adamsrs is offline   Reply With Quote
Old 06-10-2002, 02:15 PM   #8
Rovah
Member#: 1375
2003 WRX Rally Car
I'm still trying to figure all this out on my RS-T. Tried the parallel fuel line mod with the Vortech SMFU as the only FPR. Didn't work well. Had a local guy cut off the stock FPR off the fitting and braze on a 90 degree hose barb. This works well to replace the stock FPR.
Problem was the car wouldn't run in that configuration(with Walbro pump). Put the lines back to stock with the stock FPR and it runs fine. SMFU is now sitting downstream from the stock FPR.
Talked to the tech dept. at Vortech and he told me to install the higher rate spring in the kit to see if I couldn't get a better base fuel pressure. I've installed the spring, but haven't had the time to remove the stock FPR again to try it.
FWIW, both the Cartech and Vortech SMFU should be able to replace the stock FPR and provide for more fuel bypass to the tank with the high flow pumps. However, I don't know anyone that's using one as a standalone unit. I'm going to keep trying!
Also, I'm seeing 100% duty cycle on my stock injectors using the injector duty cycle gauge from Racer Parts Wholesale. Anyone with any thoughts on this? Do I need Sti injectors now? When driving, it feels like a fuel cut off.
Cheers! John
Rovah is offline   Reply With Quote
Old 06-10-2002, 06:15 PM   #9
Delicious Tuning
Member#: 1990
What injectors are you running at what PSI? Anything above 3 PSI and you are probably maxing out your stock 280cc injectors. So you will need to upgrade those pretty soon.
As for the Vortech SFMU, I have never gotten that to work ever and from the sounds of things no one ever has and never will. That FMU was made for Mustangs in mind, which have a totally different flow characteristics, fuel pressure, 8 injectors (much bigger) instead of 4, WAY BIGGER fuel lines, more fuel flow. So more than likely that is why it is not working like we want it to. I have tried everything with that damn SFMU and it will nto work as a stand alone.
You will need to run a FPR like the one I listed above with the SFMU located after it.
But on the upside you can get rid of the SFMU as soon as you get standalone engine management.
Old 06-10-2002, 10:52 PM   #10
Rovah
Member#: 1375
2003 WRX Rally Car
Skywalker,
I haven't given up on the SMFU yet. Almost, but not yet. I installed the higher rate spring and will attempt to use it as a stand alone again this weekend and post what happens. At least I know it's working alright in it's current position downstream from the stock FPR and can return to that setup.
I can't think of any physical reason that we can't use the damn thing by itself, but no one has seemed to be able to make it happen!
I definitely need some new injectors.
Cheers! John
Old 07-03-2002, 02:03 AM   #11
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
Rovah, did you figure anything out with the Vortech unit?
ChicksDigWagons is offline   Reply With Quote
Pre-Columbine people: What did you do in school that would get you expelled today? Strider Off-Topic 83 11-14-2007 09:01 AM
For those that don't know what the "D" means for D-day Stroke Off-Topic 12 06-04-2004 08:39 PM
WRX was put in its place (not). OrionAK Alaskan Impreza Club Forum -- AKIC 24 09-23-2003 11:44 AM
What did I put in the pressure plate that I can't get back out?? GregUnd Texas Impreza Club Forum -- TXIC 3 12-13-2002 07:59 PM
For those that don't like new WRX: bodykit!!! Stickee General Forum Archive 43 09-09-2000 12:59 AM
