Old 06-10-2002, 01:48 AM   #1
Poe
Member#: 12628
2002 Impreza WRX
Default Going out of country for 1 month... need to disconnect battery?
i'm going to be leaving the country on wednesday... and will be gone for a month. should i disconnect the battery since the car won't be driven? if so... just the negative? just the positive? both?
Poe is offline   Reply With Quote
Old 06-10-2002, 06:46 AM   #2
mitch808
Member#: 10228
2002 Subaru WRX
I think a good healthy OEM battery can handle that, or even a good Optima battery. If you ran a Dynabatt, I'd have to say dissconnect it.
There is nothing wrong though for piece of mind to dissconnect it while your away. If anything, when someone tries to steal your car(heaven forbid) they wont be able to start it
When all else fails, get your money's worth... ROADSIDE ASSISTANCE
mitch808 is offline   Reply With Quote
Old 06-10-2002, 08:29 AM   #3
Austin
Member#: 7089
2016 STi
Default Re: Going out of country for 1 month... need to disconnect battery?
You really don't need to, for the reasons Mitch said. If you do, though, you just need to break the circuit, meaning disconnect either the positive or the negative. As the negative terminal is easier to get at, it's usually the favorite.
Austin is offline   Reply With Quote
Old 06-10-2002, 08:57 AM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
also, disconnecting the negative terminal is safer. If the positive is floating around, and for some reason it slips and hits ground somewhere, the battery is now shorted and you have a big problem. If the negative lead is loose and hits something, nothing happens.
nhluhr is offline   Reply With Quote
Old 06-10-2002, 09:37 AM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
I WOULD disconnect the battery's negative terminal. There are quite a few electronic gadgets in the WRX (clock, ECU, trip odometer, stereo, alarm, etc.) that continue to draw a small amount of current from the battery even after the key is removed from the ignition. It's never fun when you get home after flying all day and the long drive from the airport to find that your car won't start so you can get to the grocery store and buy some fresh milk.
Jon [in CT] is offline   Reply With Quote
Old 06-10-2002, 10:08 AM   #6
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Other than the fact that you'll have to reset the clock and radio, there really is no reason NOT to, and there are a few reasons you should (see above), so you might as well.
If you do, definitely disconnect the negative. Current flows negative to positive, so the ideal way to break the circuit is at the negative terminal.
Narcisse91 is offline   Reply With Quote
Old 06-10-2002, 01:47 PM   #7
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
I didn't drive my WRX all winter long, and in the spring it started right up. If you have a manual there's nothing to worry about anyway, just put it in gear give it a push and it'll start.
kenshiro is offline   Reply With Quote
Old 06-10-2002, 01:52 PM   #8
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
I think he was looking for GOOD advice, not what to do if you don't care about the car.
Wife going out of town for a few days - WWOTD? Jard Off-Topic 50 11-27-2007 08:49 PM
Necessary to disconnect battery for ECU swap? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-17-2004 01:35 AM
Taking out sub, need to disconnect amp? dman918 Car Audio, Video & Security 2 01-23-2004 02:56 PM
Trannyless For 1 month! Need One ASAP! VtecThisWRX North West Impreza Club Forum -- NWIC 2 10-30-2003 06:22 PM
