Old 03-06-2011, 05:42 PM   #1
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
Default BB32's/redgauge ej22e turbo build thread
Hola,
I turboed my ej22e about 5 months ago(2011), she died a month ago so........
This is whats happening right now ( I have no idea what im doing ) so any tips would be awesome!
Im almost done rebuilding both heads.
I torqued the crank and am waiting for acl race bearings in #3
Putting ej22t pistons and water pump.
Wrx 10mm oil pump
Stock rods with acl race bearings too
Turbo
[email protected]
RRFPR
WRX 440 top feeds
WRX intercooler
Suspension
04 Wrx struts with 04 STI Springs
Exhaust
2.5 Vibrant resonator and muffler(1046) Catless
It's cheapishly loud and droney. Not very deep. It sounds worse in person. It's not total crap.. Just definently not the deepest cleanest boxer sound. It sounds generic. There's some dude from WA on here that loves it and always recommends it.
Also my friend has a hks(carbon something something) turbo back. Not the sexiest out there. I'd go cobb if I did it again with a good resonator. Maybe even stock sti
In the process of ghetto porting
FWIW my reflections:
Totally worth it. Without tuning it wasn't the best at idle'ing, but never left me stranded. I was 18 at the time and didn't know much, so it wasn't perfect by any means. I think I turbo'ed it for under 1k and rebuilt it for that much.
What I would have done differently(few years later):
Wideband. I never knew my afr and didn't even understand the importance. I wasn't the driver when the piston broke, but I imagine it was way lean.
I have an aem failsafe afr and boost/vacuum gauge. It's friggin awesome.
If you want to turbo your car because you don't have money to do a wrx engina swap.. Do it! Full wrx swap included wiring/ecu would be a good choice, but then you don't learn everything first hand.
RedGauge is offline   Reply With Quote
Old 03-06-2011, 05:46 PM   #2
Jagular1785
Member#: 194452
The Mr.
Wizard
Was wondering when you'd start a thread. What all do you have left to fix?
Jagular1785 is offline   Reply With Quote
Old 03-06-2011, 06:24 PM   #3
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
I finished the wiring and cv joints on the tranny that I just swapped in.
I need main bearings, timing belt, and 4 valve seals. After that I should be good to go!
I got my clutch for 40$ too <3 I think it was a gator clutch. 150 new. Organic. It was toast when I swapped back to an auto to sell it. Like 15k after install I think...
Old 03-06-2011, 06:27 PM   #4
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
I dont get how to use plastigauge.. I do, but it just doesnt work right. So I torqued them to 33ft/lb's. Is that not a good idea? Standard bearing size too.
Old 03-06-2011, 06:49 PM   #5
Jagular1785
Member#: 194452
The Mr.
Wizard
You need to torque it down to spec to get the right measurement.
Old 03-06-2011, 07:30 PM   #6
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
Thats what ive done. Many times. It just smears it. (I dont turn the rod)
Old 03-06-2011, 08:06 PM   #7
Jagular1785
Member#: 194452
The Mr.
Wizard
if it moves at all, it will smear. Even a tiny bit will mess it up. I would try to brace them somehow just to make sure it doesn't move. is the crank sitting in the motor or seperate?
Old 03-06-2011, 11:16 PM   #8
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
seperate
Old 03-06-2011, 11:31 PM   #9
Jagular1785
Member#: 194452
The Mr.
Wizard
Makes things easier to work with that way, the trick is to keep the rods from moving. I found doing one at a time was the best way.
Old 03-07-2011, 01:03 PM   #10
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
So I put the rod on
put the plastiguage on the end where the cap will go
put the rod cap on
torque it
take the cap off.....
Is that right?
Old 03-07-2011, 01:12 PM   #11
Jagular1785
Member#: 194452
The Mr.
Wizard
I find that it would be easier to put the gauge in the cap or rod first, then torque it down. If you try to put it on the crank, it would be a little more difficult to position. But either way, yes.
Old 03-09-2011, 12:46 AM   #12
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
I torqued it to spec and moved on.. That sealed power **** would not work. I put my block together tonight! heads tomorrow..
Any suggestions? I have no idea what im doing until I read it in the manual.
I almost dont want to use nasioc anymore because of its censorship!
Old 03-10-2011, 10:57 PM   #13
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
Old 03-10-2011, 10:58 PM   #14
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
Going to portland for the weekend, so wont be done till late next week. my 5mt is installed too.
Check out babybalugas build thread on legacygt (it's me). There's a lot more info.
Old 10-25-2014, 11:03 PM   #15
RedGauge
Member#: 269978
99 turbo legacy
sandstone metallic
I get a lot of pm's here and since I never log on they're not responded to in a reasonable amount of time. Youtube is the swiftest way to get a hold of me with any questions. Find me through that video^^ Weirdauto
Check out this thread as it contains way more info:
http://legacygt.com/forums/showthrea....html?t=156502
My very slow build thread 05BluePearlGT South West Impreza Club Forum -- SWIC 17 08-14-2007 04:41 PM
Jutboy's EJ22(T) Build Thread Jutboy Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-07-2007 07:52 PM
A check-my-PC-build thread, with extra cookies. gongzero Off-Topic 13 01-29-2007 12:23 PM
Wh'appen to Tai Chih left the building thread? blaster88 Mid Atlantic Impreza Club -- MAIC 12 11-09-2001 04:26 PM
