Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 06-09-2013, 09:43 PM   #126
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
For you turbo ej22 folks.. will a 2002 impreza downpipe (aftermarket) fit the BG Outback?
I assume if I get a catless one I would have a CEL issue.. so my only option is a cattted downpipe?
SubaruImpreza_power is offline   Reply With Quote
Old 06-15-2013, 01:07 PM   #127
mutydog
Member#: 319484
1998 OBS-T
black/grey
Hey,
Eg33GC was right about my fuel cut issue! i spent way too much money upgrading my fuel pump and getting an fmu, when all i needed to do is buy some $10 ngk bkr7e-11 spark plugs!!!!!! i had 5's in, so it was getting way too hot in the combustion chamber, and thats all it was!!!!
Originally Posted by eg33GC View Post
youre probably getting knock. 4000 is prime territory for detonation.
whats your em?
mutydog is offline   Reply With Quote
Old 07-11-2013, 04:38 PM   #128
Gokart38
Member#: 313730
I have a 1995 impreza L I recently pull the 1.8 out dropped a 2.2 in. It is stock bottom end, new rebuilt heads which I done myself. I've got a vf39 turbo, sti intercooler, Perrin up pipe invidia down pipe, wrx injectors with rails, walbro 255 fuel pump. I just need to find a oil supply line where could I find one? It's the only thing keeping me from turning the key
Gokart38 is offline   Reply With Quote
Old 07-12-2013, 11:04 AM   #129
squarebush
Member#: 173656
T off the oil pressure sensor located under the alternator. Just make sure you leave enough clearance for adjustment of the belt. You can easily get the hose you need to run to the turbo from that location
squarebush is offline   Reply With Quote
Old 07-12-2013, 11:06 AM   #130
squarebush
Member#: 173656
There are some great kits on eBay for the feed and return. You can use the standard banjo or go to a 90* fitting
Old 07-13-2013, 07:08 PM   #131
Einobaka
Member#: 69126
1998 2.5 RS
There's also another block plug towards the rear you can take out for oil reference and thread in a 1/8" NPT plug that you can buy from Subaru
Einobaka is offline   Reply With Quote
Old 07-15-2013, 02:13 PM   #132
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Look at post 73 in my journal. This kit will work but I don't think you can fit it under the alternator. I am going to put it in the galley in the rear on top of the block. Either that or hack up my power steering bracket and put it in the front
http://www.rs25.com/forums/f145/1901...outback-8.html
geronimo81 is offline   Reply With Quote
Old 08-02-2013, 03:37 PM   #133
The22Buildist
Member#: 352547
99 Impreza L Wagon
ill be in the club soon! im going big with:
99 EJ22E Block
Block Sleeves
O Rings
TD05H 16G Turbo
650cc Injectors
Forged Pistons
Forged Rods
ACL Bearings
EJ25D Heads
255LPH Walbro FP
5 Speed WRX Trans
WRX FMIC
WRX Water Pump
WRX ECU
Professional Tune
and a few more toys. All ready to stuff in/on this week.
The22Buildist is offline   Reply With Quote
Old 08-03-2013, 04:26 AM   #134
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
99 EJ22E Block
Block Sleeves
O Rings
TD05H 16G Turbo
650cc Injectors
Forged Pistons
Forged Rods
ACL Bearings
EJ25D Heads
255LPH Walbro FP
5 Speed WRX Trans
WRX FMIC
WRX Water Pump
WRX ECU
Professional Tune
What brand are the pistons and rods? Curious to know which 25D heads you're using too?
i_c_the_light is offline   Reply With Quote
Old 08-04-2013, 12:52 PM   #135
squarebush
Member#: 173656
that looks like a good build. I might end up with something like that in the future. Right now I am gearing up to put a 255 in my car that i am borrowing for a few years. It is fully built and should be go for literly any power you want just pick a turbo. I plan on de-tuning it to around 300whp for reliability
Old 08-05-2013, 02:51 PM   #136
The22Buildist
Member#: 352547
99 Impreza L Wagon
that sounds safe, you're obviously more responsible than me lol. what turbo setup are you thinking for it?. im going to push my semi-closed 22 to about 400whp. many drivetrain/suspension upgrades to come
Old 08-05-2013, 02:55 PM   #137
The22Buildist
Member#: 352547
99 Impreza L Wagon
ive done some research and I was originally going to use 99 rs heads but I found out those are basically the same and wouldn't lower compression to(a boost friendly level) what I need. so im going with some newer 2.5 wrx/forester heads. and the pistons and rods are forged wisecos rated to hold 500whp to be safe for my 400.
Old 08-05-2013, 07:29 PM   #138
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Those would be EJ255 heads then. Which makes sense now when you say you are using a wrx ecu.
Old 08-05-2013, 07:57 PM   #139
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG,FMIC, Big turbo
If anyone needs EJ25D heads, I have some completly rebuilt that dont need. I took them out of a 1998 RS and had them rebuilt and never used them. I include the cams and even the intake manifold with all sensors if you need it. They look great and all checked out. New seals, decked, pressure tested and lapped valves. PM me if interested
emsmap is offline   Reply With Quote
Old 08-06-2013, 03:13 PM   #140
squarebush
Member#: 173656
vf39 will get me to 300-320whp all day long on an engine like that.
Old 08-09-2013, 09:11 AM   #141
PinkSTI550CC
Member#: 331903
Thats funny that i found this thread, because it is my current project!
EJ22E Phase 2 Short Block
EJ207 Rods
ACL Race Rods Bearing
ACL Race Main Crank Bearing
Wiseco 97.5MM 8:5:1 Piston (same as a EJ205)
EJ205 Head, Waterpump, Oil Pump....
TD05H 18G
STI Pink 565CC
Zero Sports Equal Leight Header
STI Version 6 Type RA Downpipe (3'' Catless)
Turbo XS AxleBack
Fidanza Lighweight Flywheel
4 Pot 2 Pot Brakes/ Hawk HPS Pads and Premium Disc
4.44 JDM Transmision From STI Version 4
Thats all the parts i aquired for now!
PinkSTI550CC is offline   Reply With Quote
Old 08-09-2013, 03:32 PM   #142
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
EJ207 Rods
TD05H 18G
STI Pink 565CC
Turbo XS AxleBack
I envy you. In New Zealand we never got the phase II EJ22.
Old 08-09-2013, 03:57 PM   #143
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
I don't think I've added my contribution yet. This is what it will be:
EJ22E block
EJ20H heads
EJ20G intake manifold
EJ20K throttle body modified for EJ20G TPS
EJ20H intercooler
EJ20G injectors
EJ22T head gaskets
EJ20G wiring
EJ20G Legacy ECU with GrpN ROM chip.
I'm not sure of the turbo yet.
The engine is assembled and working in Legacy right now in N/A form. The ECU doesn't seem to mind the extra displacement, and the torque has increased significantly. There are hills that on original 20D I would have to drop a gear. With the 22D I don't have to, it still accelerates up the same hill in the same gear.
What I want to do next is turbocharge it, get everything related to the FI side of things working right and then I'm going to get a twin turbo exhaust manifold made up, similar in design to the SYMS one. I'm still in the process of working out what would be a suitable turbo in terms of size/flow/spool/EVERYTHING RAAAAAAARG and then have a matching pair.
Old 08-11-2013, 10:00 PM   #144
Bots10
Member#: 364467
2015 WRX
ISM
Looking to do this, have been lurking for awhile now and have some basic questions. I know I have the phase 2 MAP OBS (99). Single port heads.
What up pipe would I use? I know i need to custom fab a down pipe, with my brother being a welder thats not a problem.
Up pipe is tieing me up though.
Bots10 is offline   Reply With Quote
Old 08-11-2013, 10:00 PM   #145
Bots10
Member#: 364467
2015 WRX
ISM
And no I don not want to switch the heads.
Old 08-13-2013, 10:03 PM   #146
PinkSTI550CC
Member#: 331903
It will be much more easier if you swap your head, good shape ej205 head cost 250-300$ so... Ecu, intake, headers up pipe will be a direct bolt on after that!
Old 08-16-2013, 08:39 AM   #147
matt_platt
Member#: 356405
96 impreza
red
What are the advantages and disadvantages of an ej22 turbo? Whats the best set up for it? And whats a quess on the cost?
matt_platt is offline   Reply With Quote
Old 08-17-2013, 11:08 AM   #148
PinkSTI550CC
Member#: 331903
Advantage: 0.2L more of displacement , the reliability is the same as the 2.0, so more durable than a 2.5L. Price is the same as building a 2.0 or a 2.5L
Disadvantage : Full open deck, some will said it will be easy to break headgasket... but under 400whp I don't see any problem..
Old 08-30-2013, 09:00 AM   #149
thorne
Member#: 130063
2003 WRX
Silb
I love that there are people still doing this! It's a great option on a budget.
The 2.2e is one helluva motor.
thorne is offline   Reply With Quote
Old 08-30-2013, 08:08 PM   #150
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Reddevil and his antics got my attention about the engine. YOU sealed the deal by putting DOHC heads on it.
I'm going one further and attaching two turbochargers.
boosting on an ej22 shortblock not a ej22t sime Normally Aspirated with bolt-on Forced Induction Powertrain 10 09-11-2014 06:05 PM
Whose boosting an EJ22 NA? Turbo GC4 Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-11-2014 04:07 PM
New EBCS Pro From PERRIN - Boost Control Solenoid PERRIN Vendor Announcements 19 09-16-2010 07:35 PM
FS : Defi Racer Boost and EGT gauges Faster_Gun Interior/Dressup/Audio & Security 7 06-09-2010 09:37 PM
Less boost. higher atmospheric temp? COBB AP2 joosky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-07-2010 03:38 PM
