Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 05-23-2010, 08:13 AM   #1
Vinnyzwrx
Member#: 143616
2014 STI
WR Blue
Default new short block, bad timing belt tensioner?????
ok, i just put in a new short block from outfront motorsports and im getting a really weird noise that comes on around 2500 rpm and ends at around 3 - 3500 rpm. its a weird rattling noise,
it normally happens when i shift or am driving on light throttle in the above specified rpm range. The only thing i can think of is the timing belt tensioner besides some sort of mechanical problem with the new short block. The engine has about 300 miles on it and is about 5 days old so i really doubt that its a mechanical problem but the noise really sounds bad. help would be greatly appreciated!
Vinnyzwrx is offline   Reply With Quote
Old 05-23-2010, 10:57 AM   #2
2milehi
Member#: 81633
'98 RS-T
One way to check the tensioner is to take the timing belt covers off and use a screwdriver to apply some extra pressure to tensioner. If the noise goes away then you found it. Hopefully you have Outfront Motorsports aware of this noise.
Have you had this noise since first install or has it got progressively worse?
2milehi is offline   Reply With Quote
Old 05-23-2010, 11:26 AM   #3
Vinnyzwrx
Member#: 143616
2014 STI
WR Blue
i finished the install on wednesday and have had the noise since first startup. i thought that it may be some normal new block noise or something so i waited. i intend on calling them first thing monday morning to see what they think/find a solution
thanks for the advise, i will try it tomorrow.
Old 05-23-2010, 04:59 PM   #4
jaironsti
Member#: 203699
06 STI
Sounds like a rattle to me in the audio when you rev it up. I have never heard a tensioner sound like that, but I could be dead wrong as well. Just my 2 cents.......
jaironsti is offline   Reply With Quote
Old 05-23-2010, 05:49 PM   #5
prometheum
Member#: 92003
04 bicycle!
happened to my friend's wrx after his 2.5 swap; timing belt tensioner exploded 250 miles later
prometheum is offline   Reply With Quote
Old 05-23-2010, 06:02 PM   #6
Vinnyzwrx
Member#: 143616
2014 STI
WR Blue
i dont think that the sound is being produced by the tensioner but rather something else, caused by the bad tensioner.
thanks, i really hope that its just the tensioner.
Old 05-23-2010, 09:12 PM   #7
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
sounds like one of the timing belt pullies squeeking to me vinny. take the belt off and spin the idlers ect and see if they are gritty. the smallest one is the one I normally see that goes bad.
robbieshonda is online now   Reply With Quote
Old 05-24-2010, 10:31 AM   #8
Vinnyzwrx
Member#: 143616
2014 STI
WR Blue
there all fine, i actually had to replace that small one because it was starting to go bad. i made sure to check them because i have had to replace them before for that reason. im about to head out to see if its the tensioner, i will post my results
Old 05-24-2010, 05:06 PM   #9
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
also could be the idler pulley on the AC belt. I had one go bad and it sounded similar to this so check it before going through the trouble of popping off the covers...
Fongers is offline   Reply With Quote
Old 05-24-2010, 08:40 PM   #10
Vinnyzwrx
Member#: 143616
2014 STI
WR Blue
the ac tensioner is new.
i popped off the timing belt covers and the belt is very tight, the tensioner is fine as i suspected it to be since its only 5k mile old. any other ideas?
i didnt realize that was you robbie, it sounded weird that someone would reply using my name but i didnt think much of it until i just saw that it was you when i read throught the forum trying to think of ideas.
Old 05-25-2010, 11:39 AM   #11
Vinnyzwrx
Member#: 143616
2014 STI
WR Blue
could all this be a result of a bad front o2 sensor? i know the sensor is really hurting because 2 of the wires are almost disconnected. i accidentially hit the sensor when i was removing the engine from the car. im not getting any check engine light or anything so it seems fine. also today i logged the car with ecu explorer and noticed that the ecu, at a minimum is pulling -14 degrees of timing and -2 knock correction. under acceleration the numbers are all positive, im not sure when these number came about because i just noticed them as being the minimum of the range from max to min. i guess i can attach the log, im not sure if it matters though.
Old 05-25-2010, 07:26 PM   #12
SteelDragonSTi
Member#: 124912
2006 Subaru STi
CGM
Apparently the timing belt tensioner has to be replaced along with the new timing belt. I found out today when my mechanic was starting the car for the first time after a fresh full engine build. The car was idling fine and then it shuts off. After further inspection he finds the timing is off and the belt jumped 3 knotches. He tells me the tensioner failed and needed a new one. I might have possible valve damage as well.
I wish I had known this prior to the build.
SteelDragonSTi is offline   Reply With Quote
Old 05-26-2010, 08:38 AM   #13
Vinnyzwrx
Member#: 143616
2014 STI
WR Blue
Could this be a bad throw out bearing?
can i Subaru tech tell if a timing belt tensioner is bad by looking at it? BlackoutWRX Newbies & FAQs 9 10-18-2012 10:09 PM
FS:Brand New OEM Timing Belt Tensioner & Timing Belt jsnm Engine/Power/Exhaust 5 04-06-2010 12:58 PM
bad timing belt tensioner? double07 Service & Maintenance 12 03-30-2008 01:59 AM
Bad Timing Belt Tensioner Haelan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-10-2007 11:14 PM
Driving with a bad timing belt tensioner BlackoutWRX General Community 7 06-07-2005 10:27 AM
