Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC > RMIC Vendor Classifieds
Old 05-24-2010, 06:47 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Talking STRi DSD Gauge Special! Combo Prices, or Individual Deals!
Buy 1 Gauge get 15% off!
Buy 2 Gauges Get 17% off!
Buy 3 or more Gauges and Get 19% off!
ALL GAUGES AVAILABLE IN A 52mm and 60MM!
Boost 45PSi $229.99
Boost 30PSi $209.99
Fuel Pressure $234.99
Oil Pressure $234.99
Oil Temp $174.99
Water Temp $174.99
EGT $204.99
Voltage $139.99
Stri DSD warning gauges offer full function, features, and extreme accuracy.Driven by rugged stepper motor, control by advance microprocessor, DSD is the latest technology in precise monitoring device. DSD gauge series is equipped with laboratory grade sending units.
DSD = digital stepper drive
Control and operates by Advance Digital Microprocessor Stepper Motor Driven (PM Type Gearless)
1. Micro Stepping Movement high resolution and accurate readings
2. Super high torque maintains the pointer accurately in toughest racing environments / prevents pointer from overshooting at high speed movements
3. Fast response eliminates reading lag / real time display
4. Gearless noiseless operation / more durable
Special Note
1. Unlike conventional gear type stepper motors which are noisy and respond in slower reaction speed.
2. DSD stepper motors have been test proven in the toughest vibration environments which is a general characteristic of race tuned vehicles.
The following standard features can be found in all DSD series:
*Open / Closing Ceremony in sequences
*270 Degree Sweep
Wide viewing angle for higher resolution reading
*Warning Setting User Preset
User preset warning values alarm by LED
*Peak Recall
On demand, view highest value achieved
*Automatic Self Calibration
Each DSD meter is equipped with self calibration function that resets the pointer position after each installation. Or can be manually activated by shutting off the constant power source.
*Short-Circuit Auto Detect
If the sensor wire is incorrectly connected or the signal extension wire cut, the meter will detect the error and alarms the driver. (Backlighting will go off / pointer flashing)
*Dimmer (DSD-SLM II Only)
Reduce backlighting brightness for night time driving.
*Extreme Accuracy Racing Spec Sensors
All DSD are equipped with racing spec sensors for accurate reading.
*Gorgeous Titanium Color Finish Casing
__________________
RallySport Direct is offline   Reply With Quote
STRi DSD Gauge Special! Combo Prices, or Individual Deals! RallySport Direct Gauges & Electronics 10 10-18-2010 07:47 PM
Can a 60mm stri dsd gauge use the senders from a 52mm sti robot Interior & Exterior Modification 1 03-18-2010 07:20 PM
Defi BF, Imperial, and Racer Series Gauges Killer Combo Prices!! Spun Autosports Gauges & Electronics 154 11-18-2009 06:47 AM
Defi Gauges! Special package pricing! PRICES LISTED! RallySport Direct Gauges & Electronics 7 02-04-2009 12:19 PM
