Old 05-24-2010, 01:54 AM   #1
tempest24
Member#: 197772
2007 STi
new formula red
Default JDM Exhaust
hi all,
i want to install an Amuse Powerhouse exhaust...but i know the downpipe from usdm and jdm are different...i was told i need to change a bunch of things....just wanted to know wat i need to convert into jdm to do this...
i have a 2007 usdm STi
thanks
tempest24 is offline   Reply With Quote
Old 05-24-2010, 09:42 AM   #2
nito822
Member#: 50490
07 097/800 UGM STI
Dirty
From what ive read on this site, the JDM length DP's are shorter than USDM. So the JDM Amuse cat-back will be longer than the OEM USDM piece.
You can either modify the DP/Cat-back lengths or try to source a JDM DP that has the proper flange for your turbo.
nito822 is offline   Reply With Quote
Old 05-24-2010, 11:03 AM   #3
yaya20
Member#: 130354
^Correct. I'm going through this right now trying to mate up a JDM catback. My USDM downpipe is about 4" too long and we'll be shortening it to work with the JDM catback.
yaya20 is offline   Reply With Quote
Old 05-25-2010, 12:01 AM   #4
tempest24
Member#: 197772
2007 STi
new formula red
so its just the DP...? i was told by someone in philippines for usdm to run a jdm exhaust u need to change the DP turbo manifold from single scroll to twin and oil pan...
true?
Old 05-25-2010, 08:35 AM   #5
yaya20
Member#: 130354
Depends on what your car has and what you are trying to fit to it. Do you have a single scroll or twin scroll turbo/downpipe? Is the Amuse exhaust a turboback, catback, etc...?
The USDM downpipe is single scroll and longer than the twin scroll JDM downpipe.
Old 05-25-2010, 08:39 AM   #6
tempest24
Member#: 197772
2007 STi
new formula red
hi all i just spoke with my local dealer and the tech there explained it a little bit just wanna see if everyone here would agree.
jdm = twin scroll up-pipe, shorter downpipe due to shorter cat & exhaust 101"
usdm = single scroll up-pipe, longer downpipe 4" & exhaust 97"
so i would need to change to an unequal length exhaust manifold with a twin scroll up-pipe and jdm length downpipe to install a jdm exhaust...
now i heard the jdm exhaust manifold is a different size from the usdm so you would need to match the oil pan to be jdm spec as well...
can some clarify regarding the oil pan issue...dealer tech said no need...true?
Old 05-25-2010, 10:16 AM   #7
yaya20
Member#: 130354
Dude, a twin scroll downpipe will not mate up to a single scroll turbo. The flange on the hotside is different to accomodate the dual wastegate flappers.
It's sounds like your car is USDM spec, correct? If so, then you would also need a twin scroll turbo. That's a lot of stuff to change out for an exhaust...
Old 05-25-2010, 08:38 PM   #8
tempest24
Member#: 197772
2007 STi
new formula red
i see...i knew i had to ask cuz it didnt seen correct...thanks and yes its usdm and yes it is a lot to change out for an exhaust but i really want to put on a amuse exhaust system...
Just a random thought on JDM exhaust vs USDM exhaust Kevex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-14-2004 06:35 AM
JDM exhaust system, which downpipe rupert Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-01-2003 01:08 PM
looking for the quietest JDM exhaust BlueWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-23-2003 12:08 AM
JDM exhaust question... KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-16-2002 06:30 AM
will jdm exhaust bolt onto stock USDM WRX? DV Motorsports Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-01-2002 07:34 PM
