Old 05-25-2010, 03:15 PM   #1
rpatte18
Member#: 243227
2004 2.5rs
Default engine help!
My 04 scube 2.5 RS's engine is knocking INCESSANTLY. I'm pretty sure it's not oil related because i change it religiously every 3k miles. Anyone have any suggestions on what the problem could be?
rpatte18 is offline   Reply With Quote
Old 05-25-2010, 04:32 PM   #2
mr_subaru_rs
Member#: 142872
1999 Impreza 2.5RS
Silverthorn
is it metal on metal sounding? when you change the oil is there ANY metal particles in it? Subaru engines have some history with weak rod bearings....
mr_subaru_rs is offline   Reply With Quote
Old 05-25-2010, 05:36 PM   #3
rpatte18
Member#: 243227
2004 2.5rs
i have never seen any kind of metal in the oil. the sound as far as i can tell is coming from the back of the engine. it's most obvious at just an idle, once i'm up to speed you can hardly tell. it's an automatic as well if that helps at all.
Old 05-25-2010, 06:01 PM   #4
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Are you sure it'd not just the boxer motor making it's normal noise? Over the years the noise will get louder (a lot of ticking from the valves and other misc rattles). How many miles are on the car? Does it feel and drive the same?
Mike
GrimmSpeed is online now   Reply With Quote
Old 05-28-2010, 07:01 PM   #5
AlaskanProtege
Member#: 217112
1998 GC8 modified
black and orange
The ej2.5sohc engine has big problems with piston slap. Specially around 40-60k on up. There was a short skirt piston design in thoes motors which is what is causeing the sound. Keep an eye on ur oil level. And pressure. My 02 rs has been slapping for bout 2 years. Still runs fine. It's a buru. Run it till it blows!!!
AlaskanProtege is offline   Reply With Quote
Old 05-30-2010, 02:09 PM   #6
rpatte18
Member#: 243227
2004 2.5rs
it's still driving great... there's about 120 K on the car so the piston slappin's probably the deal. If that is the case should i be alarmed at all or just go with the flow of it all?
Lotus Engineering Helps Develop Ultra-Efficient Direct Injected Hotfire Engine AVANTI R5 Non-Subaru News & Rumors 27 03-20-2009 03:19 PM
Tranny housing is stuck to engine - Help! syborg_97 Service & Maintenance 2 03-12-2002 05:09 PM
Need Engine help Greg 99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-30-2001 08:12 PM
Engine help!! Getting engine back on mounts!! SFsube Technical Forum Archive 1 09-13-2000 12:17 AM
Need Engine! Help! Chuck Technical Forum Archive 4 06-17-2000 12:23 AM
