Old 05-25-2010, 06:38 PM   #1
Goodfellow
Member#: 226551
93 s13 coupe
many colors
Default HKS highpower catback
So I just purchased a HKS highpower catback, Kinda big for my taste but it should do for now. It came in two peaces and does not have any gaskets at all. I got it used. Does anyone know if this will bolt right up to the stock DP (Down pipe) and what gaskets I need for the mid pipe and down pipe?
Thanks in advance, Cody.
Goodfellow is offline   Reply With Quote
Old 05-25-2010, 06:43 PM   #2
SueBaroo
Member#: 140838
2002 WRX Wagon
03WRX/06STi/07FOZ/08LEG
EDIT: It should mate up. Take out the donut gasket.
See the second DP to the right? That circular thing coming out the bottom end is the donut gasket. I just comes off.
I have the same exhaust except it's a TBE. It sounds ok, but I'm waiting to mod my RSR
SueBaroo is offline   Reply With Quote
Old 05-25-2010, 07:53 PM   #3
WRBlueGDB-F
Member#: 170013
2006 WRX
VF39'd PDX Tuned
You'll need two 3 inch two hole gaskets.
Example: http://www.grimmspeed.com/catalog/pr...products_id=62
WRBlueGDB-F is offline   Reply With Quote
Old 05-30-2010, 01:54 PM   #4
Goodfellow
Member#: 226551
93 s13 coupe
many colors
Yes but my hks highpower is 3'' all the way back, wont I need a 3'' Down pipe aswell to mate up correctly?
Old 05-30-2010, 03:19 PM   #5
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Not exactly, there are ways to mate the flanges together
happs subi is offline   Reply With Quote
Old 05-30-2010, 05:05 PM   #6
PD5015
Member#: 198372
2006 WRX TR VF43
WRB Camo
no you dont, just the gaskets. Ive had mine on without a downpipe for like 6 months and it works fine. just got my hks bellmouth so thats changing soon
PD5015 is offline   Reply With Quote
Old 06-03-2010, 09:00 AM   #7
Goodfellow
Member#: 226551
93 s13 coupe
many colors
So I got it all on last night. The two bolts holding the DP on to the catback blew apart. Apparently there is a spring or something. I used two random bolts and some washers grinded the hold Gasket off. Put the Mid pipe on the DP hung it, tightened the two bolts that I had to get washers and the sealer ring. Leaks like a F***ing siv. I dont know if I need a donut gasket, if those two bolts that sealed it just suck. If I need those springs on. IDK IDK all I know is its taking 40% of my sound away.
Old 06-03-2010, 11:02 AM   #8
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Did you throw them away? Those are there to allow a bit of movement in your exhaust, you definitely need to buy new ones.
Old 06-03-2010, 01:51 PM   #9
WRBlueGDB-F
Member#: 170013
2006 WRX
VF39'd PDX Tuned
The spring bolts allow the exhaust to move slightly when using the donut gasket.
The stock donut won't work with the HKS CB though. You need a 3 inch 2 hole flat gasket.
Old 06-04-2010, 09:26 AM   #10
Goodfellow
Member#: 226551
93 s13 coupe
many colors
Where can I get some 3-2 inch. and If I put the spring on, wont it leave a huge gap in between the two exhausts?
Old 06-04-2010, 09:33 AM   #11
Drowner
Member#: 49297
17 WRX Limited
Its never going to work right. The stock DP is a donut style, while the HKS is a flat flange, meant to bolt up to another flat flange. Even if you manage to mash it together with bolts, it will eventually leak again. IN the picture above, you would want something similar to the DP on the far left.
Drowner is offline   Reply With Quote
Old 06-04-2010, 10:15 AM   #12
WRBlueGDB-F
Member#: 170013
2006 WRX
VF39'd PDX Tuned
Try ImportImage Racing. He has the best prices around on the Grimmspeed gaskets.
Mine worked fine for a couple of years.
WTT: HKS Highpower catback for stock cappa NWIC Private Classifieds 3 05-23-2009 01:31 AM
hks highpower catback ppericfe Tri-State Area Private Classifieds 4 04-25-2009 04:07 PM
hks highpower catback $350 wagoneee Engine/Power/Exhaust 0 10-01-2008 10:19 AM
Hks Highpower Catback Junior2JZ Engine/Power/Exhaust 9 03-10-2007 08:24 AM
FS HKS HighPower Catback, Less than 100 miles 1fastmr2 Private 'For Sale' Classifieds 1 01-31-2005 04:53 PM
