Old 05-26-2010, 07:23 AM   #1
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
Default Cel P0410
06 wrx with sti swap, stage 2 protuned. I am getting a CEL P0410 Secondary Air Injection. I cant clear it, it will stay off for a couple days and then come back. Also not sure if its related but recently been having trouble starting the car as well. So this is what will happen.
In morning turn key hear all electricals, fuel pump, etc but not like the engine is cranking and car won't start. Do it again and again and again and eventually it will start. Once it starts sometimes the CEL will come on sometimes it won't. Regardless once car is on no problems period. Car runs fine and no CEL will come on while driving period. So I will get to work then during lunch/breaks I will go on to try to turn on car again to see if it has same issue and nope works peferct the first time, multiple times and no CEL.
So not sure if the 2 problems are related or where to start looking now.
talvai is offline   Reply With Quote
Old 05-30-2010, 11:40 AM   #2
MonsterSubie
Member#: 246931
2006 Impreza WRX
The 4 first hand causes of the p0410 cel are in order as follows:
1. Air duct system fault
2. Open or short circuit condition
3. Poor electrical connection
4. Secondary air pump faulty (aka smog pump)
hope this helps. Good luck.
MonsterSubie is offline   Reply With Quote
Old 09-12-2010, 12:29 AM   #3
teevik
Member#: 257166
2008 WRX
Rally Blue
I had this happen to me recently, only happened when I went to start the car when it was cold. I was poking around under the hood and it turns out the air pump had somehow come unplugged, you might wanna check all the connections to it.
teevik is offline   Reply With Quote
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 07:26 PM
HELP!! flashing cel tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-04-2010 01:38 PM
Cel P0410? LiDrummer Newbies & FAQs 3 01-23-2008 03:17 PM
P0410 CEL code LiDrummer Southern California Impreza Club Forum -- SCIC 5 04-08-2007 12:06 PM
CEL or no CEL? chuglobal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-25-2002 03:23 PM
