Old 05-26-2010, 09:11 AM   #1
paul_charles
Member#: 220379
Default 18x9s will they fit?
Hey ya'll! I'm about to add some 18x9" wheels to my 1996 Legacy. My only concern is the tires clearing the struts. I haven't received the tires yet so I can't test fit. So before I order the drop springs, does anyone know if my tires will clear my struts? Thanks so much!
_Paul
paul_charles is offline   Reply With Quote
Old 05-26-2010, 06:04 PM   #2
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
You may have to roll the fenders to get them to work, and its a possibility the tires may rub the strut in an area. Thats pretty wide, depending on what your exact tire size is, you'll be cutting it real close.
runninstrong is offline   Reply With Quote
Old 05-26-2010, 07:11 PM   #3
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Tires clearing the struts? You nuts, they are going to clear fine, because I'm sure those rims are going to be a +35. Your question should be, will they rub on my fenders.
Louie is offline   Reply With Quote
Old 05-26-2010, 07:31 PM   #4
paul_charles
Member#: 220379
Yup, they're +35. I'm planning on cutting larger arches. What size tire would I run? 225/40/18? I know a lot of folks run 245/40/18. I'm completely unknowledgeable at this stuff so I really appreciate the two answers.
Old 05-26-2010, 09:10 PM   #5
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
This is my opinion and only my opinion. I found that 255/35-18 tires cheaper than 245/40's, so I would go that way, I know that its a good fit for your speedometer if you are compatible to the 225/45-17's sizes.
I am not sure about having to cut arches, but assume you'll have to roll your fenders, probably pull them. Post pics though, I've seen some older leggy's that look great rockin some aggressive fitments.
Old 05-26-2010, 09:56 PM   #6
paul_charles
Member#: 220379
You're a great help Louie! Thanks. I'll throw some pics on here once they're fitted.
Old 05-27-2010, 04:47 PM   #7
girodisc
Member#: 177674
Your going to have to roll your fenders and camber in for sure. I did a but of rolling on a set of 18x8.5 +38 and it was minimal but this is a lot more on a stock body lego. Of course its nothing compared to the 18x9.5 +15 I am running now but I had to flare it to clear that. You won't hit the strut I know that. I can go all the way up to a 19x10.5 +32ish without hitting my strut.
Johann @ Girodisc
girodisc is offline   Reply With Quote
Old 05-27-2010, 11:19 PM   #8
paul_charles
Member#: 220379
Johann, you did some amazing work on that Legacy. It was fun to watch you build it. You're 100% correct, they cleared my struts just fine. I didn't have to roll the fenders just yet, once my drop spring get here I will. I ended up purchasing 225/40/18 +35. Here are some shots from my test fit.
As you can see I'll need to come up with some sort of way to cover the tire. I have some ideas but nothing concrete quite yet.
18x9.5 +22 offset will they fit?? bugeye1257 Tire & Wheel 19 02-05-2010 02:42 AM
02-3 seats in a 04, will they fit? are they lower? soulbazz Interior & Exterior Modification 4 06-04-2008 02:15 PM
If 8" Rims fit a STi will they fit a RS? fluxwl Tire & Wheel 3 08-12-2004 02:58 PM
18" wheels, will they fit? The Wraith Brakes, Steering & Suspension 12 06-14-2001 07:57 AM
Diamond Audio components. Will they fit in a WRX? Code-7 Car Audio, Video & Security 0 04-13-2001 02:32 AM
