Old 05-26-2010, 01:20 PM   #1
Quick
Member#: 17704
2009 STi
Default Fuel cell placement
Alrighty guys/gals, I have a 2009 STi that I'm building into a track/race car. I have a 15G ATL fuel cell that I'm putting in soon and need some opinions on placement.
The first idea is to mount it in the truck area, behind the rear suspension. Due to the length of the cell, I'd have to either a) mount it above the frame rails in the floor, or b) cut out the rear wall to move the cell back a few inches to allow it to be fully submerged into the floor. This would also mean it's not within 12" of the original tank (which violates some sanctioning body rules).
The second idea is to mount it where the stock tank sits, but it would have to be much higher (due the driveshaft/exhaust). The downsides to this are it being closer to the driver, and I'd have to setup some sort of external fill as climbing through the cage to refill it would be a pain.
This car is fully caged, btw..
Thoughts?
Quick is offline   Reply With Quote
Old 05-26-2010, 02:19 PM   #2
MSI
Member#: 95419
sell it and modify your OEM tank. Better weight placement and fit.
If not, sell it, and get the proper grpN kit that mounts in PLACE of the OEM tank.
-mark
MSI is offline   Reply With Quote
Old 05-26-2010, 02:22 PM   #3
Quick
Member#: 17704
2009 STi
-mark
Were money not an object, perhaps I would do that. As it is, this is what I have, and what's going in the car.
For reference, the group-n cell costs $9823, to get it from ATL directly.
Thanks for the helpful reply.
Old 05-26-2010, 06:48 PM   #4
Web Foot STi
Member#: 39086
2004 STi
No help, but $10,000 is OUTCH. I'll hold your ankels...
Edit: We both know that a low CG and a short poler moment of inertia is good. Just mount the affordable cell as best you can. I'd go for low CG first.
Web Foot STi is offline   Reply With Quote
Old 05-26-2010, 07:15 PM   #5
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
http://phoenixperformance.net/articl...ing%20Team.pdf
This article has pics of how SRRT mounted their cell. It's far back in the trunk, almost as far back as you can go, with a metal bulkhead separating it from the cockpit.
boost junkie is offline   Reply With Quote
Old 05-26-2010, 07:47 PM   #6
MSI
Member#: 95419
if you are not in a rush, I will show some pics of how we modify the OEM tanks ... give me 2 weeks to get something up?
-mark
Old 05-26-2010, 09:52 PM   #7
Quick
Member#: 17704
2009 STi
Nice!! It's also tilted, for the extra clearance the rear suspension needs. That's awesome.
Old 05-26-2010, 09:53 PM   #8
Quick
Member#: 17704
2009 STi
-mark
Sure, I'm not in a rush.
Old 05-27-2010, 12:36 AM   #9
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
surge tank
cheap, easy, effective and keeps the fuel weight lower and more centrally mounted (load changes between full and empty).
Old 05-27-2010, 08:55 AM   #10
Quick
Member#: 17704
2009 STi
Originally Posted by Homemade WRX View Post
surge tank
I already have the fuel cell, and it has the built in surge tank as well.
Old 05-27-2010, 09:42 AM   #11
Quick
Member#: 17704
2009 STi
Did you happen to notice that the pics of the fuel cell has it canted towards the front of the car in the first picture, but in the underneath picture it seems to be tilted in the opposite direction?
Old 05-27-2010, 09:52 AM   #12
Quick
Member#: 17704
2009 STi
Actually, that cell from Phoenix looks really small. The distance from the edge of the top plate to the front edge of the cell is really short. And the side only has 3 bolts holding it closed. That's probably why they don't have the fitment issues I have.
Old 05-27-2010, 10:16 AM   #13
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
It's a 22 gallon cell so not small by any means. It looks like it's pretty deep to allow the other dimensions to be smaller. Better to sell yours and get one that fits properly rather than compromising CoG and/or driver safety to shoehorn something in that doesn't belong there.
Old 05-27-2010, 01:28 PM   #14
Quick
Member#: 17704
2009 STi
The current plan is to go with a mounting similar to this, with a proper bulkhead built to comply with the various rules.
Old 05-27-2010, 08:00 PM   #15
Quick
Member#: 17704
2009 STi
This is STi's Nurburgring 24hr car. It looks like it has a rear mounted cell as well (thought it doesn't look like it protrudes below the floor)
Old 05-28-2010, 08:19 AM   #16
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
Theirs is actually mounted in place of the back seat, and it sits up pretty high. Personally, I would feel a little nervous with the fuel cell that close to me, even though it's covered with an aluminum shield.
Old 05-28-2010, 08:39 AM   #17
Quick
Member#: 17704
2009 STi
I don't know how you come up with these pictures, but you're freaking awesome! Thanks...
The nervous part is what makes me hesitant to mount it there as well. There's that, plus it's more difficult to refuel without a remote fill (mine currently has the standard fill top plate on it)
Old 05-28-2010, 08:49 AM   #18
Quick
Member#: 17704
2009 STi
Check this out. It seems they changed that car around at some point.... From these pics you can see that the dry break is in a different location, and from looking through the window you can tell the fuel cell is behind the cage..
Perhaps they moved it???
Old 05-28-2010, 10:20 AM   #19
Web Foot STi
Member#: 39086
2004 STi
The nice thing about this mount is that the fuel cell is inside the cage. That's a biggy.
Old 05-28-2010, 12:37 PM   #20
DeatschWerks
Member#: 87358
...and between the axles. Not a fan of having an ever-changing 100 lb weight outside of the rear axle.
DeatschWerks is offline   Reply With Quote
Old 05-29-2010, 04:24 PM   #21
savsuby300
Member#: 189232
1995 Nissan 240SX
Dead in the shed.
That was my thoughts, that you would want the fuel cell as close to center as possible and as low as possible. I would put it in the backseat area so your handling doesn't change as much as on the back of the car. Just a thought.
savsuby300 is offline   Reply With Quote
GM Fuel Cell System With Gen-5 Fuel Cell Stack Could be Commercialized in 2015 AVANTI R5 Non-Subaru News & Rumors 0 09-25-2009 08:19 AM
Fuel cell + Stock Fuel tank...Possible? mtcs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-30-2008 06:36 PM
US Fuel Cell Council Publishes FAQ on Fuel Cell Tax Incentives FunkerVogt Political Playground 0 11-03-2005 08:50 PM
Fuel Cell in a fuel injected car? SJwrx General Community 4 03-25-2004 02:29 PM
Removing fuel tank & Fuel cell foam dbrown Technical Forum Archive 3 08-13-2000 08:16 AM
