Old 05-26-2010, 11:50 PM   #1
BlackSun
Member#: 93591
2007 WRX STi Limited
UGM
Default Loud Howl at 75MPH-80MPH freeway driving...
Not sure if this is the right place for this, so here goes.... I'm having quite the loud hum-howl at speeds around 75 to 80 MPH during freeway driving.... I'm hoping it just my Falken RT 615's that my be the problem.... I guess what I'm worried about is that I might have a Transmission or Rear Diff issue..... I have no other noise like the one I described during any other form of driving.... Hard acceleration, high speed over 80 (not that that ever happens ).... Thanks for any input fellas.....
BlackSun is offline   Reply With Quote
Old 05-27-2010, 12:28 PM   #2
ZaQSTI
Member#: 142543
05 STi
Specs on the car? Why do you think it is the tires?
ZaQSTI is offline   Reply With Quote
Old 05-27-2010, 02:32 PM   #3
Senfinger
Member#: 110912
2015 STi
ISM
Mirrors Whistle at 70 Plus... STi Spoiler makes loud vibration/howling at 90 Plus...
Senfinger is offline   Reply With Quote
Old 05-27-2010, 03:11 PM   #4
mapleleaf
Member#: 103399
2009 Stripped STI
Dirty White
Mirrors.
mapleleaf is offline   Reply With Quote
Old 05-27-2010, 03:23 PM   #5
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Mirrors, wing, brake ducts, inner wheel well liners.
Worst case scenario.. a wheel bearing.
NitroTrike is offline   Reply With Quote
Old 05-28-2010, 11:25 AM   #6
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
If it sounds like it is only coming from one corner of the car, I say wheel bearing.
TEK112 is offline   Reply With Quote
Old 05-28-2010, 07:03 PM   #7
BlackSun
Member#: 93591
UGM
Seems to be coming from all around the car... I cant pin point it.....
Old 05-28-2010, 07:06 PM   #8
SoCalMonarch
Member#: 142752
2008 WRX STi
i have used the RT615s... they didn't make that bad of noise. Video/sound clip it.
SoCalMonarch is offline   Reply With Quote
Old 05-28-2010, 07:08 PM   #9
ohm
Member#: 178468
2007 UGM STI
IAG Built
Like mentioned above, it is the mirrors. The first time I heard this I thought it was the turbo, but upon further research I found out it is a common sound coming from the mirrors.
Here you go:
Mirror Howl - At speeds above 100mph (+-10mph depending on wind) you may start to hear a loud howling noise. It resembles the noise an open chimney makes in a storm. It has something to do with the airflow around your side mirrors. The way I fix it is to fold them in while at the track/drag strip, as they're not needed there.
This was taken from: http://www.iwsti.com/forums/faq-newb...ould-know.html
ohm is offline   Reply With Quote
Old 05-28-2010, 07:40 PM   #10
SoCalMonarch
Member#: 142752
2008 WRX STi
Is OP really asking this if it was his first time at that speed? Wouldn't that be the only way it could be the mirrors...
Either a) It's not the mirrors or spoiler if the noise just started occurring recently.
or
b) It's the first time OP has gone this fast... how would he know what his car is supposed to sound like at that speed? Why make the post if this were the case?
Giving the benefit of the doubt to the OP... it's not something that has always been there on the car.
Old 05-28-2010, 08:08 PM   #11
BlackSun
Member#: 93591
UGM
I dont think its loud enough for a vid clip.... Lets just say is sounds like a tuning fork hum inside the car at 75-80....
Old 05-28-2010, 08:23 PM   #12
BlackSun
Member#: 93591
UGM
Well.... According to Discount tire its a combo of the design of the Falkens, and the slight negative camber of the rear of our cars.... Apparently the noise will be pretty noticable after a tire rotation (which I just had done this week) because of the way the tire wears on the rears.... I guess it will take up to 3 thousand miles for it to go away..... Interesting... This will be the last time I buy Falkens again thats for sure....
Old 05-28-2010, 09:56 PM   #13
SoCalMonarch
Member#: 142752
2008 WRX STi
Two things.
1)
2) You're asking a discount tires employee a question about your performance car making noise... and trusting him? Unless your running the tires down to the carcass or are leaning on the reinforced sidewall EXCESSIVELY (Don't make me repeat that I've used the tires before) then I don't see how the tires are whats making the noise.
Again OP, and I'm asking seriously, was this your first time going that speed in your car on that road?
Old 05-28-2010, 10:18 PM   #14
BlackSun
Member#: 93591
UGM
Two things.
1)
OP??? And no man, it was a joke...... Not to mention, your case with the 615's might be different than mine.... Most of the IWSTI members are having the same problems I am.....
Old 05-28-2010, 11:29 PM   #15
06Limited
Member#: 118112
Do you have any upgraded rear bushings? My car howls like a banshee between 75-80 too. Mine gets louder every time I add more bushing upgrades. I wouldn't worry about it
06Limited is offline   Reply With Quote
Old 05-28-2010, 11:51 PM   #16
BlackSun
Member#: 93591
UGM
No sir, shes stock but thanks for the info......
Old 06-01-2010, 12:30 PM   #17
hock2k5
Member#: 207437
2006 WRX
BLACK
Originally Posted by mapleleaf View Post
Mirrors.
Yeah Mirrors really howl.
My Dunlop Direzza Star Spec Z1's also added noticeable road noise, but I would think you would be able to tell the difference.
hock2k5 is offline   Reply With Quote
Old 06-01-2010, 04:59 PM   #18
inCLINEd
Member#: 204785
06 sti
obp
Check your tire pressure if you haven't already. If the are off, left to right, by more than 3 psi you will hear the diff a bit more. I was getting the same noise in my 06' sti (yes different rear diffs, I know) and checked my tire pressure. One side was 25ish and the other was 32. Added air to balance it and the noise was gone. Hope that helps.
inCLINEd is offline   Reply With Quote
Old 06-01-2010, 05:59 PM   #19
muffintop
Member#: 247741
99' unicorn
purple
Wheel bearing
muffintop is offline   Reply With Quote
Old 06-01-2010, 11:21 PM   #20
simonella_virus
Member#: 183875
2007 WRX STi Stg2
if you hit the clutch pedal, does it go away? does it vary with vehicle speed? does it vary with engine rpm?
simonella_virus is offline   Reply With Quote
Old 06-02-2010, 01:01 AM   #21
BlackSun
Member#: 93591
UGM
yes... it starts @75 and stops at 80.... Dones not vary with rpm..
Old 06-02-2010, 09:07 AM   #22
simonella_virus
Member#: 183875
2007 WRX STi Stg2
see, if the sound stops with hitting the clutch pedal, then it can't be a side mirror or anything exterior-related. and if it varies with vehicle speed, it's likely something final drive ratio and downstream.
i had a problem [that sounded] like this and after some basic troubleshooting (akin to the questions i'm asking you), the local dealership actually replaced the entire transmission. they said it was one of the bearing systems and that it was too much bother for them to crack the transmission open, find it, replace, rebuild, etc.
though, let me tell you, that even with the new tranny (which still feels stiff), the noise is somewhat still there, though a lot quieter. i'm not sure if to some extent, all of the STi's have some whine/ howl.
Old 08-11-2010, 03:40 PM   #23
jakedademon
Member#: 157764
2002 '02 SZ55 hyb
2002 v9 EJ207 VF22 wagon
Go 74 or 81 mph, i fissed it!
jakedademon is offline   Reply With Quote
Old 08-12-2010, 01:13 PM   #24
zk6760
Member#: 246398
2006 wrx tr stage 1
SGM
Could your shifter be vibrating - I think that would be more RPM related, but maybe b/c you said it stops when you depress the clutch?
I remember test driving my previous VR6 and thinking WTF is that noise???!?!? Turns out it was the mirrors! I kept asking the guy if he heard it..thought I was nuts.
zk6760 is offline   Reply With Quote
Old 08-12-2010, 01:18 PM   #25
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I am putting money on the tires, could be slightly low on air, out of alignment, not worn correctly, not balanced perfectly.
Will
GrimmSpeed is offline   Reply With Quote
So I am cruisin' at 75mph then... Nakioki Newbies & FAQs 10 09-13-2007 03:13 PM
Roof Rack Flew Off at 75mph Local_Skater Interior & Exterior Modification 25 02-05-2007 08:39 AM
BLOW OUT at 75mph RSKwannabe Legacy Forum 24 12-25-2005 01:04 AM
Loud howling noise @ 120 Teedub's STI Off-Topic 107 11-21-2005 12:37 AM
Loosing Boost - Loud howling dyswtric27 Normally Aspirated with bolt-on Forced Induction Powertrain 5 04-19-2002 10:56 PM
