Old 06-10-2002, 05:08 PM   #1
CTP
Member#: 16835
Blaze Yellow
Default Plastic edge at the driver and passsenger side windows
Anyone else got this also?
Triangular shape plastic edge at the driver and passsenger side windows
pictures are in ::
http://www.geocities.com/tingpongchau/damage.html
If the geocities link does not work, please use the Yahoo link
below
http://photos.yahoo.com/bc/tingpongc...Damage&.src=ph
How much do you think it would cost to repleace that triangle plastic edge?
Thanks
CTP
CTP is offline   Reply With Quote
Old 06-11-2002, 04:48 AM   #2
Bimmer
Member#: 4116
2002 Impreza TS
I don't get it... Do you mean that the rubber molding is splitting around the top edge of the window?
Shouldn't cost anything, should be a warranty repair...
I'd wait until it gets worse, and until it's actually a problem because of wind noise or water leakage, then get SOA to fix it... this should fall under the 3-36 bumper-bumper stuff...
Ben
Bimmer is offline   Reply With Quote
Old 06-11-2002, 11:46 AM   #3
#522
Member#: 2185
Mine split about 3 inches right after I got my 01 RS. Subaru Replaced it under warranty. The window was also rolling up too far causing it to split, so they adjusted that too. I would just call a dealer and ask them about it. When I called on this same problem (and about my tranny being low on fluid 2mo's after I picked up the car) they told me to bring it in because the warranty will cover it.
#522 is offline   Reply With Quote
Old 06-11-2002, 08:14 PM   #4
GDA
Guest
Member#:
It is a warranty issue. Its from the window being adjusted too high on the tracks, and causes the rubber to strech and eventually tear.
dealer should take care of you no problem.
good luck
GDA
Old 06-17-2002, 05:18 PM   #5
minix42@
Member#: 548
'98 Impreza RS
dinged up faded black
I didn't look at the pics, but from what you described it sounds like you are refering to the ~3"x3" plastic panel on the inside of the side mirrors. If this is the case, I broke mine while removing the door panel and IIRC it was a $7-15 part from the dealer.
minix42@ is offline   Reply With Quote
WTB: Driver and passenger side power mirrors and control unit Osus14 Private 'Wanted' Classifieds 3 10-29-2007 11:48 PM
Comment made at the drivers meeting at Road America this weekend... JM530 Mid West Subaru Owners Club Forum -- MWSOC 11 10-16-2007 06:35 PM
Are the drivers & passenger side STi motor mounts same part number? lstepnio Newbies & FAQs 0 12-27-2002 03:15 PM
Driver and Passenger side rails the same? Idjiit Interior & Exterior Modification 2 08-06-2001 10:33 PM
Help! Window guides in both driver and passenger sides are scratching the windows! Michael General Forum Archive 7 03-16-2001 09:23 AM
