Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 05-27-2010, 03:25 PM   #1
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
Default Intake Manifold Swap
hey guys i just had a question on whether it's worth it to put in a stock STI intake manifold on a wrx.
I have a 06 WRX limited and i'm planning on putting on a stock STI Turbo, stock STI injectors and a stock STI TMIC, is there any worth to the engine to invest in a stock STI intake manifold?
what are the differences between the stock WRX and STI manifolds?
pointblink19 is offline   Reply With Quote
Old 05-27-2010, 03:45 PM   #2
25rsti
Member#: 166324
3 turbos &n NA
@DBlockSTi
they're identical internally, and it wont work without customizing the throttlebody flange.
Old 05-27-2010, 03:46 PM   #3
THEVERGE
Member#: 127421
2002 Subaru WRX
Not worth your time or money. I'm almost positive the main difference is the color.
If you found a TGV-less JDM manifold, that would probably be worth it.
THEVERGE is offline   Reply With Quote
Old 05-27-2010, 04:12 PM   #4
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
ook thanks guys, i guess i wont go with it then. got a great price on an 04 intake manifold used only 4k for 150 so i thought i'd ask.
Old 05-27-2010, 07:14 PM   #5
turbofied
Member#: 239813
the STI TGV's are different also but basically all you will end up with is a red manifold.
everything else is the same.
Do the turbo though! great daily driver mod for real power
turbofied is offline   Reply With Quote
Old 05-28-2010, 01:04 AM   #6
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
will i need to get a tune? bc if i do i'm probably gonna throw on the TMIC before the turbo and keep the TD04 on for a little bit before i have time to get a tune.
and if i do that i heard the Y pipe for the STI turbo wont reach to the TD04, is that true or will it reach?
Old 05-28-2010, 09:31 AM   #7
kheff46
Member#: 66739
2002 WRX wagon
get a tune no matter what you change. these aren't mid '80's cars anymore. you waste gas if you don't get a tune, and make less power than you're hoping for(tune=power on newer cars)
same manifold, and not worth sourcing a TGV-less manifold as you can delete them on yours for free! lol
--keith
kheff46 is offline   Reply With Quote
Intake Manifold swap on a 99 SOHC 2.5L ??? chrismindless Normally Aspirated with bolt-on Forced Induction Powertrain 4 06-14-2005 12:42 AM
04 Intake Manifold Swap? Zen Normally Aspirated Powertrain 4 10-20-2003 11:43 PM
EJ20/EJ25 Intake manifold swap Really_Soaked Normally Aspirated with bolt-on Forced Induction Powertrain 3 07-25-2002 10:28 AM
butterfly valves in intake manifold? swap! Otaku64 General Community 14 02-16-2002 12:10 PM
2.5 intake manifold swap fourbanger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-23-2001 10:28 AM
