Old 05-27-2010, 08:42 PM   #1
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
Default grimmspeed gaskets
I would like to replace all my gaskets with grimmspeed gaskets because they are thicker than stock and I have a couple leaks.... only problem is they "don't seem to have any for the 2.5i" but I am sure some from the WRX/Sti have to fit.... has anyone done this and know which gasket, from them, will fit between the: headers and engine, between the headers and a track pipe, and between the axel back and mid pipe. THANKS!
RoxyTheImpreza is offline   Reply With Quote
Old 05-28-2010, 10:32 AM   #2
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Email Justin at Grimmspeed and find out what will and won't fit.
Gr3en is offline   Reply With Quote
Old 05-29-2010, 11:52 AM   #3
GrundleJuice
Member#: 165749
only the header to head gaskets will fit the stock 2.5i exhaust. the other STi gaskets are too big for 2.25" exhaust, not sure about the WRX gskets or if they are even different.
Old 06-03-2010, 07:33 PM   #4
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Are you still running the stock exhaust? The header gaskets will work and we probably have something that will work for the rest of your system. Feel free to give us a call and we'll get you what we can!
612 379 0000
Mike
GrimmSpeed is offline   Reply With Quote
Old 06-04-2010, 08:27 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
I keep meaning to throw another singleport exhaust manifold gasket in the mail to y'all so you can expand your offerings, I always walk out of the garage without it..... sadbannana.
Jay
Old 06-05-2010, 04:05 AM   #6
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
1) I have yet to find ANY NA gasket that won't seal properly (unless there's mechanical damage to the flanges or the gasket) if you spray it with Permatex Copper Spray-a-Gasket before install.
2) If you still feel like you want to buy high-zoot gaskets anyway, the big dogs in the market are SCE Gaskets. They make solid copper embossed gaskets that will seal against high pressure gradients even over large-ish gaps. You can find their list of products for the 2.5L Subarus on their website.
Helix 660cc injectors, TD04, Grimmspeed gaskets, stock wrx exhaust foxracr10 Engine/Power/Exhaust 25 06-06-2010 01:13 PM
socal: PNP Header and Grimmspeed gasket set mcganz121 Engine/Power/Exhaust 0 12-15-2009 10:47 PM
grimmspeed gaskets on gt spec headers fourage20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-13-2009 10:51 PM
