Old 05-28-2010, 06:09 PM   #1
Viperguy324
Member#: 121108
2006 06 Spec C
Default GD caged weights...
Post up your weights and equipment that may add or subtract that are not standard. please no truck scale type crap.
My last weight in 1282kg's with 1/2 tank, Kaps sss, and full 12L water tank Hydra mist sys. This was fully wet in dual trim. 50kg's of ballast was in the car.
I'm looking for solo weights and more ideas of sheding weight.
Viperguy324 is offline   Reply With Quote
Old 05-28-2010, 06:32 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
When I had my car corner blanced it came in at 3210. That's with a full cage, fire system, 2 Racetech seats, and harnesses. Most of the interior has been stripped. Doors gutted. AC Removed. Lightweight battery.
Old 05-28-2010, 06:44 PM   #3
Viperguy324
Member#: 121108
2006 06 Spec C
Thats pretty heavy... but same equipment as mine. weird
that makes1456kgs ....
Old 05-28-2010, 10:54 PM   #4
555ideways
Member#: 36652
Kilo's only guys. Let's make easy to relate for everyone
555ideways is offline   Reply With Quote
Old 05-29-2010, 08:06 AM   #5
MSI
Member#: 95419
we will weigh our bare shell once back from paint to give a starting point as well.
Aluminum fasteners ?
MSI is offline   Reply With Quote
Old 05-29-2010, 09:09 AM   #6
Viperguy324
Member#: 121108
2006 06 Spec C
I have been using them on non-structure/safety spots.
Even my Harness is chopped.
Old 05-29-2010, 12:24 PM   #7
MSI
Member#: 95419
You should be able to shave more off in my opinion ... what exhaust, intercooler rad are you using (material and size) ... some of those front mount units that are poorely thought off weight over 50 lbs ... massive for nothing ..
Same thing with look a like carbon wings ...
Old 05-29-2010, 04:12 PM   #8
Viperguy324
Member#: 121108
2006 06 Spec C
Standard Radiator, Standard Top Mount. exhaust is Spec-C Hi flow cat to Invidia N1 cat back. Not many options with TS..
Old 05-29-2010, 04:34 PM   #9
mav1c
Hoodbridge!
Member#: 560
I'm running a Koyo Aluminum radiator and APS TMIC. Also running the MadDad dual dump downpipe w/cat, and Perrin catback, so it's definitely not the lightest setup. I've been contemplating getting a custom straight exhasut from the DP back, but haven't looked into it yet. I've also got the Oswald Performance front bumper beam that will be going on soon, so that'll shave off some weight from the front.
Old 05-29-2010, 07:26 PM   #10
MSI
Member#: 95419
Well, if you can get someone to work with inconnel, you can save a bundle of weight on the exhaust. We are going to contact griffon to help us out with the rad and intercooler I think.
Since we are going to make the front end removable, we can put the units top to bottom or side to side ... make them more efficient, so smaller = lighter.
Were did you get the aluminum fasteners from?
Old 05-30-2010, 08:08 AM   #11
Viperguy324
Member#: 121108
2006 06 Spec C
Pro-Bolt.. also known as tastynuts.com
Old 05-31-2010, 01:17 PM   #12
toomuch
Member#: 76497
2006 Impreza
My stage rally car is about 3000lbs, It is 3100 with a spare (60lbs) and required saftey gear, 2 fire bottles, tow strap, spill kit, 3 triangles, spill kit, jack.
2006 STI Rally America Super Production Class so it retains most of the stock accessories less A/C, anti-lock brakes, still has door bars, door cards, stock dash, bumper beams. We went to great lengths to lighten the car were it is allowed. We are required to run at 3200lbs, I have two lead ingots we bolt to the rear floor board to get to 3220 with a 1/4 tank fuel.
toomuch is offline   Reply With Quote
Old 05-31-2010, 05:10 PM   #13
Viperguy324
Member#: 121108
2006 06 Spec C
Heavy
to cage...or not to cage...? IllNastyImpreza Motorsports 24 05-14-2007 08:58 PM
GTSPEC Trunk Cage for GC/GD Impreza keirnna Brakes, Steering & Suspension 0 01-04-2007 09:05 PM
BC / GC / GD FIA Group N Roll Cage Kits Shipped to You Starting at Just $829 Safe Drives Interior/Dressup/Audio & Security 3 01-13-2005 02:03 PM
MazWorx Harness Bar, Drag Cage, Drift Cage, etc, etc GSCMotorsports.com Vendor 'Group Buy' Classifieds 15 01-06-2005 06:56 AM
Pre-moving sale: Weights/bench, bird cage mexicanpizza Bay Area Impreza Club Forum -- BAIC 2 08-04-2003 07:44 PM
