Old 05-28-2010, 07:37 PM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Question low idle need some pointers
I am working on a 01 forester. I was told I have a idle control valve problem. Is there a cleaning procedure. I wiped it off but not sure how this item works. Is there also a way to test if it's bad?
thanx
Old 05-28-2010, 11:31 PM   #2
oli2.5RS
Member#: 50510
1996 Legacy wagon
green
what do you mean, you wiped it off? Anyways, if there's an IAC problem, you might be able to clean it by removing it and using throttle body or contact cleaner. You can remove the entire housing, and you'll need a new gasket or you can remove just the plastic control unit and you'll need to manually readjust you're idle, which is not as hard as it sounds. You'll notice the holes for the screws on the unit are slotted, so the unit can be adjusted.
If a lot of black **** comes out, its carbon build up, from th PCV valve, which is supposed to be normal.
oli2.5RS is offline   Reply With Quote
Old 05-28-2010, 11:39 PM   #3
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
try a seafoam cleaning... put about a 1/3d of a can in the intake and let sit per directions.
Then crank and smoke out the neighborhood
dstan is offline   Reply With Quote
Old 05-29-2010, 12:03 AM   #4
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Is there a write up on this with a few pics?
Also new engine. Cleaned throttle body, intake and everything. I just avoided the sensors. Engine now has 850 miles on it.
Old 05-29-2010, 12:56 AM   #5
oli2.5RS
Member#: 50510
1996 Legacy wagon
green
http://forums.nasioc.com/forums/show...highlight=iacv
there you go. What do you mean "new" engine? from the dealer? or rebuilt? Sensors like the IAC valve get transfered from the old motor onto the new one pretty often.
Old 05-29-2010, 12:57 AM   #6
daleyswanson
Member#: 205604
87J Robinson
R22
is it throwing a cel? i had a p1501 which is an idle control solenoid. it idled super high at cold start and almost stalled at stoplights
daleyswanson is offline   Reply With Quote
Old 05-29-2010, 10:57 PM   #7
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I had the code p0506. Rebuilt engine but old sensors.
Old 05-30-2010, 12:39 PM   #8
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
When I removed the IACV from my '00 Legacy, it was full of all sorts of gunk. I don't know if "intake and everything" includes removal of the IACV by itself, but it might make a difference. (Remove, let soak, new gasket per above.)
LetItSnow is offline   Reply With Quote
Old 05-30-2010, 12:49 PM   #9
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Yes I understand the wrx version of this part. What about the n/a version?
Old 05-30-2010, 02:36 PM   #10
oli2.5RS
Member#: 50510
1996 Legacy wagon
green
I sold my '00 NA about 3 weeks ago so I can't go check, my 2.2 is probably different, but if you do a search, even on google, you'll probably find a picture to help you.
on the 2.2L its on the passenger side of the throttle body.
Replacing Turbo Tomorrow; Need some pointers!!! Flyin_Hayn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 03-05-2010 04:51 PM
Need some pointers on waxing. Wrx KidD Car Care & Detailing 31 05-07-2009 01:23 PM
Finally getting my hands dirty, need some pointers. Tedde22 Newbies & FAQs 8 04-13-2009 11:50 PM
New to Texas & need some pointers. Call_me_Tom Motorsports 7 01-13-2007 02:29 PM
New to Texas & need some pointers. Call_me_Tom Texas Impreza Club Forum -- TXIC 10 01-12-2007 10:27 AM
