Old 05-29-2010, 12:26 PM   #1
hiroshima1320
Member#: 247841
1995 Legacy L
Green
Default newb questions
ok i've searched and seached and can't find the answers I'm looking for. i have a 95 legacy L 5spd and I am interested in doing a swap. what is the most powerful swap for the money that is the least complicated wiring adaptation. it's my daily driver and i need it to be reliable and to be done quickly. i' looking for about 250-300whp if possible. i really dont want to have to swap the trans and rear diff if I can get away reliably without doing so. i'm new to subaru but not to high performance cars. my last car was a small block chevy powered 86 rx7 with a t56. plus a few decent hondas and an ls1 240sx.
hiroshima1320 is offline   Reply With Quote
Old 05-29-2010, 01:26 PM   #2
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
ej20 out of a wrx is probably your best bet. ej25 out of an sti if you're feeling frisky.
fibuz is offline   Reply With Quote
Old 05-29-2010, 07:02 PM   #3
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Originally Posted by fibuz View Post
An EJ20 out of a WRX is probably your best bet. Maybe an EJ25 out of an STI if you're feeling frisky.
He got a STOCK 1995 "L" that might be putting out a tad over 80 Horsepower at the wheels... just how long is his tranny going to last with one of those mills ?
I am thinking he might be better off looking at a stock Phase I N/A EJ25 from a '96-99 Legacy with new cylinder head gaskets, timing belt and water pump. This should be a simple bolt on, with no swap drama.... not a whole lot faster... and how reliable it might be long term is a subject for debate... but for a daily driver it should be just fine for a few years.
Jonathan is offline   Reply With Quote
Old 05-29-2010, 10:24 PM   #4
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Not sure how he's going to get 250-300WHP on a NA subaru motor. As long as he doesn't drive like an asshat, the tranny should be fine for a while. Plenty of the RS guy's do a WRX swap without the tranny. Eventually everything breaks, but by then maybe he'll have the cash to rebuild with RA gears or something.
Realistically, not all of the criteria provided by the OP works together...without gobs of cash.
Old 05-29-2010, 11:33 PM   #5
Zues Marine
Member#: 193827
1995 Legacy Wagon
what?!!? i dyno d my 95 L (2.2) stock and i put up around 130awhp
then i swapped in the ej25de and got 164awhp
Zues Marine is offline   Reply With Quote
Old 06-01-2010, 03:21 PM   #6
hiroshima1320
Member#: 247841
1995 Legacy L
Green
read dont want to to have to swap tranny and diff. what year wrx should i look for for a swap? also i saw that they made a twin turbo legacy the same year as mine and i can get one shipped for about $1000 with a cut harness, no ecu, no tranny, no diff, and no axles. they also said they would be getting some v5 front clips with rear diff for around $4000. the $1000 sounds a lot more reasonable and adaptable.
Old 06-01-2010, 11:36 PM   #7
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
Don't bother with the twin-turbo swap. it's not easy.
Old 06-03-2010, 01:15 PM   #8
hiroshima1320
Member#: 247841
1995 Legacy L
Green
that's what i thought. ok what year wrx should i look for and how much should i look to pay???
Old 06-04-2010, 10:00 AM   #9
sqc151
Member#: 51432
best bet and the cheaper way would be to get an 02-03 wrx engine. some supporting mods and an open source tune will more than satisfy ur needs. im assuming since u have a 95 legacy that its obdII. if u have a 5mt u should be ok with it. its probly stronger than the 02-03 tranny anyway.
sqc151 is offline   Reply With Quote
Old 06-04-2010, 04:06 PM   #10
currystyle
Member#: 201621
96 Legacy GT Wagon
white
If it's a 1995 it most likely will actually be OBDI if it's anything like my 1995 Toyota and the 1995 Nissan 240SX's. Locally in my area just the motor from an 02-03 WRX goes for about $3,000 from the local j-yards. In my research there doesn't seem to be any such thing as a cheap swap for a Subaru.
If you check out www.ridesafely.com they have a lot of totalled Subarus on the cheap. It looks like some sort of insurance auction site. Dunno if you have to have any special credentials to buy from there or not, but it warrants further investigation I think.
currystyle is offline   Reply With Quote
Old 06-04-2010, 04:25 PM   #11
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
My $0.02: buy a car that is actually fast.
Rule of thumb is that you can have a car that is fast, cheap, or reliable; but you can only pick 2 of those
GTWagon_Phreak is offline   Reply With Quote
Old 06-04-2010, 04:37 PM   #12
currystyle
Member#: 201621
96 Legacy GT Wagon
white
^ That takes all the fun out of it though. Anyone can buy a fast car. You are probably right though, for the fact that he seems to be wanting to do this on the cheap he would be much better off to find something decently quick that he likes and buy it instead of trying to swap this one. Motor swaps on daily drivers when you have no back up mode of transport are never a good idea.
Old 06-09-2010, 08:47 AM   #13
hiroshima1320
Member#: 247841
1995 Legacy L
Green
yea i think thats whats gonna happen. buy either a wrx or just buy a wrecked sti and fix that... putt putt it is for the time being. unless maybe a lgt swap would be worth it.
not a newb but a newb question about radiator caps yo14jman Newbies & FAQs 10 02-19-2009 10:14 AM
Newb with a newb question... dcon Newbies & FAQs 1 11-01-2007 07:21 PM
Newb question about Touring races... andywrx Motorsports 7 01-17-2002 12:25 PM
newb question about kartboy SS Wrx0R Newbies & FAQs 6 01-13-2002 05:10 PM
Couple newb questions. Damian Newbies & FAQs 9 01-21-2001 11:09 AM
Message Board Statistics All times are GMT -4. The time now is 07:28 AM.
