Old 05-29-2010, 08:38 PM   #1
overdrivex
Member#: 220581
2010 Impreza
camilia red
Default check engine codes
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
how do i know which one it is? also anything other than a bad cam sensor can cause this?
overdrivex is offline   Reply With Quote
Old 05-30-2010, 09:31 AM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
the wiring to the sensor can mess with things. I'm not sure the the ECU will complain about that specific thing if timing is off, can't hurt to check it. Fill out your profile.
Old 05-31-2010, 06:54 PM   #3
overdrivex
Member#: 220581
2010 Impreza
camilia red
its not the sensors cause its still throwing the code. i reintalled the timming belt twice and its still misfireing and throwing the code. ive replace spark plugs, wires and coil pack. it ran fine couple of times and now it doesnt. its a 2000 impreza 2.2heads on 2.5 block.
Old 05-31-2010, 08:50 PM   #4
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
there's your problem.
XanRules is offline   Reply With Quote
Old 05-31-2010, 09:36 PM   #5
overdrivex
Member#: 220581
2010 Impreza
camilia red
its a hybrid high compression engine alot of people do this with success. the fact that it ran perfect one second and completely horrible the next shows it most likely electronic.
check engine codes gpd323 North West Impreza Club Forum -- NWIC 9 10-17-2001 06:17 PM
Help with check engine code Meche 2.5RS Normally Aspirated Powertrain 1 10-10-2001 06:20 PM
Check engine codes Wildman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-21-2001 07:04 PM
Check Engine Code P0302, "#2 Misfire" hillman Legacy Forum 5 06-26-2001 03:14 PM
Check engine codes Kruf General Forum Archive 1 12-17-2000 05:46 AM
