Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 06-10-2002, 10:39 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Exclamation Update on my FPR stuff. some interesting info inside.
OK, so Today at work I decided to try something crazy so I hollowed out my stock FPR because I couldn;t figure out what to put there in its place and I couldn;t get the SVX regulator today.
So, I did that and put it back on the rail. Now, I am effectivly only running the Cartech RRFPR. After some adjustment of the top spring I got it to idle at 33psi (where I want it.) Now with the side screw (the fuel psi/# boost screw) all the way out it raised to about 85psi at 5# boost. More than I wanted.
I couldn;t get it any lower than that and then I remembered that the kit came with some sort of plastic piece you are supposed to put in the vaccum tube to only allow a certain amount of vaccum to the RRFPR. At least I think I remember that because I couldn;t find it. anyone know for sure?
So, since I couldn;t find that, I jerry-rigged how much boost and vaccum can go through that line by putting a tie strap around the vaccum hose and almost clamping it shut.
Now, after some playing with different settings of the tie strap (hehe) I got it to where it goes up to about 48-50psi under normal acceleration and up to 70psi at 5#'s of boost. If I had that little dohickey that came with the kit I;m sure it would have been easier but, there you have it. With some tweaking, you can make the Cartech RRFPR a stand alone piece. I wonder if Cartech offers any other internal springs that would make tuning easier so I don;t have to use the tiestrap. Anyone know if they do or don;t offer other springs? A spring with a little more tention would be perfect!
Eric
Eric SS is offline   Reply With Quote
AHAHHAA update on my car....ie, OT help me decide on my next move. Keith Off-Topic 58 02-25-2009 03:46 PM
my updates on my 04 honk if it makes you horny... djmoye' Member's Car Gallery 4 09-01-2004 06:35 PM
Update on my motor build if anyone is interested STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-27-2003 12:43 AM
Some interesting info for WRX owners GTBGUY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 03-22-2001 12:11 AM
