Old 05-30-2010, 01:00 PM   #1
lambowrx
Member#: 126588
Default there may be this thread already. engine swap
i was thinking of putting the 2.5L sti motor in my wrx. i blew the head gasket. i know i'll need the motor, tranny, and ecu. i did a bunch of upgrades to my wrx with a 16 g turbo and etc. i was thinking of keeping the turbo and whatnot. or upgrading to a bigger turbo, but the question is, what all do i need? and a rough estimate of cost? or would it just be easier to fix up and bore out the 2.0L to 2.2L and stroker kit? please i need help. i'm leaving for the navy monday and i'm just hoping i can get an answer and whatnot before i leave so i know what to do when i have the time.
lambowrx is offline   Reply With Quote
Old 05-30-2010, 03:14 PM   #2
Thug Nasty
Member#: 128492
Chapter/Region: HIIC
2002 WRX - Hybrid
Well, long story short, if you want an EJ257 in your 2.0 WRX, you can A) Swap just the shortblock and use your WRX heads (No need tranny or new ECU). B) Full EJ257 w/ STi heads (No need tranny or new ECU (unless you want to run AVCS)).
Why can't you just replace your blown head gasket?
What year WRX do you have now?
Thug Nasty is offline   Reply With Quote
Old 05-30-2010, 03:29 PM   #3
lambowrx
Member#: 126588
2005. since i need to pull my motor out, why not upgrade. ya know? i was thinking of taking it to a performance shop and seeing what it'd cost. plus i'm not exactly sure if it's the head gasket
Old 06-02-2010, 09:55 AM   #4
kheff46
Member#: 66739
2002 WRX wagon
install a 255/257 block and get your heads matched properly for it. get your tune. be happy with TQ! thats the easy way, and the most cost effective. then sell your short block for a couple extra bucks afterwards.
kheff46 is offline   Reply With Quote
Old 06-05-2010, 12:51 AM   #5
bigz41
Member#: 248095
i want to do a sti swap into my 05 wrx..!! i need to keep reading in here tho to get some facts straight...
bigz41 is offline   Reply With Quote
Old 08-16-2013, 05:36 PM   #6
lambowrx
Member#: 126588
Bigz I'm in the same boat as u then
Old 08-18-2013, 12:57 PM   #7
jonny02wgn
Member#: 365559
2002 wrx wgn
blue
we,re all in this big sinking ship, (nothing to do with the navy)
i've read so much, i had to upgrade my glasses
jonny02wgn is offline   Reply With Quote
Old 08-18-2013, 01:26 PM   #8
vicious_fishes
Member#: 158864
2003 SOHC destroker
dude that's a 3 year old post?
vicious_fishes is offline   Reply With Quote
Old 08-19-2013, 08:27 AM   #9
lambowrx
Member#: 126588
Considering I was off in the military, yep. 3 years it sat.
Old 08-19-2013, 04:23 PM   #10
bugginout
Member#: 365002
Since this is along the same lines I thought id chim in..my olan is too swap an extra 2.0 I have in my swap ready 95 impreza. If been in contact with east coast swappers and im aware ill need a merged wire harness from a wrx and a section of my impreza. But heres my question. ..does anyone know if the 95's tranny will bolt up too the 2.0? The imprezas tranny has a shorter gear ratio than the wrx's = faster 0-60 im not concerned about top end. Postive input would be apriciated thanks guys.
bugginout is offline   Reply With Quote
Old 08-19-2013, 07:19 PM   #11
kheff46
Member#: 66739
2002 WRX wagon
It bolts up fine, no issues.
--Keith
Old 08-20-2013, 02:55 PM   #12
bugginout
Member#: 365002
Thanks man @keith another question I know someone woth a merged harness from a 97 2.5rs will this be compatible for my swap? Thanks
Old 08-20-2013, 03:09 PM   #13
kheff46
Member#: 66739
2002 WRX wagon
RS harness would be similar to your 95. as long as that RS harness was merged with a wrx engine/ecu portion, it will be fine
Old 08-20-2013, 03:16 PM   #14
lambowrx
Member#: 126588
Cool well I still need to figure out my problem
Old 08-20-2013, 06:25 PM   #15
kheff46
Member#: 66739
2002 WRX wagon
255/257 block with your wrx heads works fine for a quick swap. Easiest too. Otherwise, you're into swapping heads, harness etc to run a full longblock swap. What are you trying to do, save money? swap quickly? Theres plenty of ways you can get rolling again.
--Keith
Old 08-20-2013, 07:40 PM   #16
lambowrx
Member#: 126588
Both save money and swap quickly. My wrx valves are pretty ****ed. If I was to keep the heads and change to the 255/257 block what would need to be done with the heads?
Old 08-21-2013, 06:54 AM   #17
kheff46
Member#: 66739
2002 WRX wagon
Some have just used the heads as is. iirc with an odd compression ratio compared to stock. The downside being less efficient at moving exhaust gases out of the chamber. The bores are different, but the heads still seal the cyl properly.
The other option is having the heads cnc'd to match the bore like millennium does.
--Keith
Meridock wants a new car. So the STi may be FS Thread. meridock MAIC Private Classifieds 59 11-03-2008 09:32 PM
warning signs that there may be a problem? bearings 386kustoms Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-07-2008 04:30 PM
I think it may be time for an engine swap (EJ20) in the ol' RS. Siper2 Mid Atlantic Impreza Club -- MAIC 50 07-13-2006 11:33 AM
Are there any websites that document Impreza engine swaps? AndrewT Normally Aspirated with bolt-on Forced Induction Powertrain 3 02-18-2002 10:27 PM
MAS question...I think there may be some hp in there....(read this) Keith Technical Forum Archive 2 05-20-2000 08:56 AM
